Can't link up
I have a Toshiba satellite laptop and a sharp XG-P25X projector. My laptop does not like to talk to the projector. I hit FN and F5 keys but have a hard time getting a CRT option. sometimes I never get it. I don't have this problem when I use and second screen at home. gene
    President:
  • 1,383 Answers
U have screen resolution problem
Wehn u power up the computer press F8 key then enter in enabvle vga mode.
then change screen resolution to 1024*768
Posted on May 08, 2009
I would like to boot a toshiba satellite m105-s30401 with an external monitor as the laptop screen is busted and i would like to use an external monitor until i get a replacement screen, how do i get
Connecting an External Monitor or Data Projector
You can switch to an external monitor or data projector by two methods. 1. Connect the external monitor to the laptop's video port, power up the external monitor first and the laptop. The video information will automatically switch to the external monitor. 2. If you power up the laptop first then you can switch the video output to the external monitor by pressing the Fn key and one of the Function keys, depending upon your make and model laptop. You can also toggle between the external monitor or both LCD screen plus the external monitor or back to LCD screen only by pressing the Fn key plus one of the function key a few times. Here is a list of key combinations for some of the laptops :- IBM ThinkPad = Fn + F7 HP and Compaq = Fn + F4 Toshiba = Fn + F5 Dell = Fn + F8
Mar 03, 2013 | Toshiba Satellite M105-S3041Notebook
Having problems getting my powerpoint slide to show from the laptop onto the screen. Not sure what the function key is?
try Fn key with F5 or F8. depends on your model of laptop.
Look for the screen symbol on one of the function keys and try pressing that once and wait several seconds to see the screen changing video. Then press again if not correct.
If nothing is appearing on the projector, then connect a lcd monitor on the laptop and try the function keys intil it works thyen swap the monitor for the projector, and start the input scan for the active video input.
Mar 31, 2011 | Sharp Notevision XG-P10XU Multimedia...
We are needing a manule for a projector model number is xg-p25xconference series. It is a sharp. Can you please tell me how we can get this manule?
I can't find any free service manuals for the XG-P25x (you can get owner manual for free)
The cheapest way on the web is http://www.free-service-manuals.com/Projectors/Sharp_XG-P25X_Service_Manual_L57531/
They require a membership 7 days for $5 or I believe I signed up for a month for $8.
Hope this helps
May 20, 2010 | Sharp Conference Series XG-P25X Multimedia...
Getting the lenovo m500 dlp projector to work
Solved ....when it projects it says to push Fn and F7 simultaneously for Lenovo laptops. The symbol for the F7 on Lenovo is the computer screen and keyboard plus a screen with a line attaching. On the Toshiba it is the F5 key. Pressing the Fn and F5 keys on the Toshiba simultaneously gives 5 box choices, the middle is CRT and the correct one to transfer from computer screen to projector.
Jun 13, 2009 | Lenovo M500 DLP Projector
Need to see display on both laptop and projector
On most laptops pressing the Fn key plus the F5 key (in your model laptop) several times will cause the video to switch to different options
In the various laptops I've used with data projectors it is the same.
If you plug in the data projector and power it up then the laptop then the Windows image will be on the data projector (provided the laptop's screen resolution matches the data projector).
To toggle between the data projector only, the LCD screen, then LCD screen plus data projector, and or back through this sequence, just press the Fn key and the F5 key to get the displays you want .
May 20, 2009 | Toshiba Tecra M10 Notebook
Sharp XG-P25X - only white screen, no OSD, no response
It sounds like you tripped the tamper switch? Factory or authorized service center and reset via rs232 Sorry.
Apr 02, 2009 | Sharp Conference Series XG-P25X Multimedia...
Auto shutdown sharp xg-p25x projector
This would seem to be heat-related as these lamps get hot rather quickly. The first quick and dirty solution - try cleaning the filter which is under a panel on the bottom of the projector. Another fix - be sure the projector is plugged into an image source; i.e. computer or DVD player. Sometimes these units will go into standby mode without a signal. More difficult fix - be sure the fan is runningn. When it shuts down, the fan should keep running until the lamp cools, then it will shut down. If the fan isn't working the temperature build-up with shut the projector off. Replacing the fan may be a job for a tech.
Jan 10, 2009 | Sharp Conference Series XG-P25X Multimedia...
SHARP XG-P25X PROJECTOR PROJECTOR RUNNING THEN IT IS AUTOLOG OFF AFTER 2MIN. WHEN PROJECTOR IS RUNNING ITS SHOW GREEN LED AFTER LOG OFF IT IS SHOW RED LED ON LAMP AND POWER LED
either the lamp hours are close to or exceeding 1400 hrs and the lamp needs replacing, or the ballast is starting to fail. with the projector on, check the lamphours in the menu. after you replace the lamp (if it needs it), reset the lamp timer by holding down the down arrow, right arrow, and enter buttons, then press power.
User manual
Solution for Sharp projector
with the function button on the laptop and the lcd button, F5 for toshiba, the screen will display both sides. if not then give the details of ur laptop.
Dec 11, 2008 | Sharp Notevision XG-C50X Multimedia...
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
