Question about Carrier Heating & Cooling
Horizontal louvers The horizontal louvers on my reverse cycle split system air conditioner were forced down to adjust the airflow. this has damaged the top horizontal louver as it now remains open all the time. The lower horizontal louver is opening and closing as normal. Can I fix the problem myself?
    Genius:
  • 1,198 Answers
Get yourself up to the machine on a safe platform. Remove any covers that will come off easy, or tie them up out of the way. Remov e the filters. Often the whole front can be removed by just taking out a couple of screws.
Once exposed, look for something out of place. Put the louver back where it belongs to see how the hinge works. It may have jumped out of it's proper position. Ease it back in position and check it for freedom of movement. If it looks good, put it all back together.
Posted on Nov 26, 2013
4 Suggested Answers
  • 143 Answers
SOURCE: GE air conditioner with air louvers on top of case - problem?
Most fan motors are allergic to water. You should carefully examine the places where rain could go and decide whether GE has sold you a risky situation. After all, they have left it up to you to make the decision.
I wouldn't buy one with openings on the top and I wouldn't keep one after GE has demonstrated that not responding is the kind of help you will receive.
Posted on Jul 25, 2008
  • 400 Answers
SOURCE: GE mini-Split Error code
Replace the indoor pc board and thermistor.
Posted on Mar 20, 2009
stevespigle
  • 14 Answers
SOURCE: attic fan problem
The belt may be slipping and reducing the flow of air
Posted on Aug 16, 2009
Is Conia air conditioner CA24001 split system reverse cycle I cannot get heat?
Sounds like either bad reversing valve or to get you going during the summer someone may have wired it to stay energized all the time which would have been a thermostat problem.
May 30, 2016 | Dometic Heating & Cooling
How does plastic head cover pull off on a head split system Panasonic split system air conditioner
Look for 2/3 small plastic covers for screws just under the louver(s) one at each end of the air discharge opening and one in the centre (maybe). Pry these off gently with a small screwdriver and you will see the screws underneath. Remove the louver first to make access easier. There may also be a screw in the centre just above the louver.
Once all the screws are out, the cover should lift up easily from the bottom and then release from the top clips. If it doesn't come off easily, you may have missed a screw.
Jan 26, 2016 | Panasonic Heating & Cooling
Why does the split unit blow hot air in air conditioner mode, when switched on with the remote control.
because you have the temperature set at 28 degrees celcuis . Change the temperature to 18 degrees and it will cool 28 is hotter
It is a reverse cycle air conditioner it will warm the room if you set temperature to 28 degrees . Set it lower and it will blow out cold air.
Have exact same air conditioner as I recognise the remote control.
point it at the air conditioner when altering the temperature setting.
Check under the slide compartment also on the remote for more advanced settings.
Jul 02, 2015 | Cfm Daikin R410a Split System Air...
RETAIL PRICE FOR ONIX REVERSE CYCLE SPLIT SYSTEM
contact shops that install units and get quotes. retailers generally have contractors that will give quotes for installation on new units.
Jan 01, 2015 | Heating & Cooling
Ductless split LG LS240CP keeps cycling on and off every 3 minutes without reaching room temperature
Any number of reasons. Low freon pressure is one. Dirty filter (wash with plain water) obstructions causing airflow problems. Don't confuse temp on remote with temp on face of unit. LG in the Philippines means "el gigawa" translation: fixalot! I owned 5 LG products all repaired multiple times. Now replaced with Samsung. If the unit is old, replace with Samsung $3000 or less but worth it.
Sep 25, 2013 | LG LA185HV Split System Air Conditioner
Goodman air condenser is humming but the fan does not come on
The most likely cause is the fan motor has failed. If it turns free then see if the capacitor is bad. Turn off the power remove the capacitor. Your local supply houses can test it for you.
Feb 15, 2013 | Goodman Manufacturing Goodman GSC130181...
My indoor fan motor comes on even when the thermastat is off
Is your thermostat perhaps programmed with a circulation option. Many modern thermostats have this option. check your fan options. They may be On,Auto,Circ. If it has a Circ or Circulation option, your indoor fan will still periodically turn on according to ASHRAE standards, even if your stat is turned off. if you poke the fan button you should be able to choose auto and this will solve your problem. Hope this helps.
Dec 17, 2012 | Goodman Manufacturing Goodman GSC130181...
Jul 22, 2008 | Heating & Cooling
Heating & Cooling Logo
73 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
