Question about Garden
How to replace chainsaw chain - Garden
  • 4 Answers
The bar is usually clamped with two hex nuts, you usually need to remove them, this allows the chain cover to come away, then wind back the tension adjusting screw ( with a flat blade screwdriver on a Husqvana other brands may be different ) back until the chain is loose enough to come off, the bar will also come off at this point.
It is a good opportunity to give everything a good clean at this stage and make sure the oil ways to the bar are clean and not blocked with wood dust, check the nose wheel on the bar spins freely and maybe grease it.
Put the new chain over the drive pulley the same way as the old chain came off, line it up in the bar slot and if you have the tension adjust wound back far enough for a new chain the bar will just flop over the two clamp bolts, replace the cover, and just do the nuts up finger tight so the tension adjust can be wound up to take the slack out of the chain.... not too tight ! it should still spin by hand without too much friction and you should be able to lift a link up half way out of the slot in the middle of the bar with your fingers.
Check the oil is getting to the chain by running at full speed with the end of the bar held just above a flat piece of clean wood, it should throw off a faint line of oil from the chain onto the wood.
Keep your chain sharp...
Happy sawing !
Posted on Dec 02, 2013
I have a McCulloch 2618 cav chain saw and the chain adjusting screw has broken. How do i replace it.
[PDF]IPL, McCulloch, Mac 2618 CAV, 952802079, 2008-05, Chain Saw www.mcculloch.com/ddoc/MCCI/MCCI2008.../MCCI2008_AAaa__545014313.pdf
  1. Cached
  2. Similar
CHAIN SAW MODEL(s). 545014313. Mac2618CAV. DATE. 3/04/08. Replaces. PARTS LIST. 545014313 -- 5/31/07. Ref. Part No. Description. Ref. Part No.
McCulloch MAC2618CAV - Chainsaws
www.mcculloch.com > McCulloch International > X-ref > Chainsaws > McCulloch
  1. Cached
  2. Similar
Newsroom · Parts & Accessories · Chainsaw parts & ... MAC2618CAV. Select model, 006 · 050 · 10 ... McCulloch MAC2618CAV ' Bar Length - 18 inch/45cm ...
McCulloch MAC 2618 CAV (952802079) Chainsaw Spares & Parts ...
www.ransomspares.co.uk > Parts > Garden Spares > Chainsaws > McCulloch
  1. Cached
  2. Similar
Buy genuine replacement McCulloch Chainsaw MAC 2618 CAV (952802079) spares from an authorised supplier. Price match promise and next day delivery.
McCulloch Chainsaw Parts List Directory - Small Engine Parts
www.barrettsmallengine.com/mcculloch/chainsawpartslist.html
  1. Cached
  2. Similar
Download illustrated parts list for your McCulloch chainsaw model below to find OEM part numbers. ... McCulloch MAC 2618CAV Chainsaw Type 1 and 2
McCulloch Trimmer Parts List Directory - Small Engine Parts
www.barrettsmallengine.com/mcculloch/trimmerpartslist.html
  1. Cached
  2. Similar
Download illustrated parts list for your McCulloch trimmer model below to find OEM part numbers.
Mac 2618CAV - McCulloch Spares, Parts & Accessories
www.4mcculloch.co.uk > Chainsaws McCulloch Mac 2618CAV SGO002 Spark Plug. Genuine spare part. Suitable for: McCulloch Mac 2618CAV. Type: SGO002 Commonly used in small handheld ...
McCulloch Mac 2618CAV Chainsaws Chain ' BuySpares
https://www.buyspares.co.uk > Chainsaw > McCulloch > Mac 2618CAV
  1. Cached
Buy your McCulloch Mac 2618CAV chainsaw Chain at BuySpares - choose from an extensive range of McCulloch chainsaw parts and McCulloch accessories. McCulloch 2618 Google Search
Nov 29, 2016 | McCulloch Garden
The chain came off and I cant get it back on
As it is a new chainsaw it should be returned to the supplier to be repaired or replaced free of charge.
There was clearly something wrong with it as the chainsaw chain should not be able to come off.
A chainsaw is potentially very dangerous and the user is most at risk; a kick-back or a flying chain is likely to cause serious injury or *****. There have been many fatalities.
A chainsaw should not be used by anyone not proven competent to do so and learners should be supervised at all times. Part of being competent is being able to check the safe condition of the saw before use, carry out essential maintenance and adjustments to the saw and to know when to take the saw to an expert.
For your own safety I strongly suggest you get yourself some formal chainsaw instruction.
Jul 18, 2016 | Ryobi Garden
I changed the chainsaw chain on my Blue Max chainsaw. The kick-back seems to be locked
Bob take the chain off again and remember to tighten the tensioning bar so that the chain is slightly loose. Enough to pull a few cm of the bottom just to stop it being tight.
Aug 30, 2014 | BLUE MAX 14" Chainsaw replacement...
Troubleshooting chainsaw
You need to clean the chainsaw areas where the dirt has gone with a water hose. You may have clogged up the oil thing that puts oil on the chain. Hope this helps! And yes, dirt will make a chain dull. You might have to replace the chain or have it sharpened.
Jul 20, 2014 | Echo Cs-310, 14" Replacement Chainsaw...
Silver Streak chainsaw bar and chain
Replacement Silver Streak Bars For McCulloch Chainsaws Find your Chain Saw model, then click on the link to get the ChainSaw Bar and Chainsaw Chain for each model!
Special! Get 30% off when you buy bar and chain together!
http://www.jackssmallengines.com/chainsaw_bar_silver.cfm?manu_name=McCulloch
Jul 19, 2012 | McCulloch Garden
How to change a chain
First of all, make sure the saw is off. Also, before removing bolts, make sure the chain brake is not engaged (the chain should move freely).
Remove the guide bar side panel. Using a scwrench or wrench, unscrew the nuts and remove the plate to access the chain.
The side plate on most chainsaws will be held on by two nuts. Loosen the blade adjustment screw (a pin that is usually driven by a screw and pushes the blade out from the chainsaw to keep the chain tension tight).
The old chain is ready to be removed now that the sprocket plate is off of the saw. Pull the nose of the chainsaw's bar away from the chainsaw to release it from the tensioner.
Remove the old chainsaw chain.
The chain will easily remove from the guide bar with all that slack in it. Note the orientation of the cutting edges of the chain so you put the new one on the same way.
Pull the drive links out of the guide bar and slip the other end of the chain around the clutch drum.
Steps to Install a New Chainsaw Chain
Thread the new chain onto the saw.
Carefully thread your new or recently sharpened chainsaw chain around the chainsaw's clutch drum, making sure that the drive links engage in the sprocket.
Thread the rest of the drive links into the guide bar and around its nose, making sure all links are in the guide bar slot.
Align the guide bar.
With the chain properly threaded along the clutch drum and guide bar, put some tension into it by pulling on the nose of the guide bar away from the chainsaw.
While pulling the guide bar, make sure to seat it onto the saw's adjustment pin.
Replace the side plate.
The side plate is ready to go back on as long as the guide bar is properly positioned beneath.
Replace the plate and the nuts that hold it into position, but do not tighten the nuts down all the way yet. The guide bar must be allowed to move a little while the chain is tightened to the correct tension.
Tighten the chain to the correct tension. Use the tensioning screw to the side of the guide bar to adjust the tension on the chainsaw chain.
Finish tightening the side plate nuts.
The chainsaw chain replacement is now complete.
And here is a great overall reference guide to keeping a chainsaw sharp and running. Sharpening a chainsaw chain is a great way to extend the life and is less expensive and easier than replacing a chain. There are small grinding tools (like a dremel) that can be run off a small 12v battery or your vehicle battery that allow for quick 'tune-ups' on your chain if you are out cutting and need to sharpen your chain.
http://www.pcta.org/pdf/STUCHAP2_web.pdf
Aug 28, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Need to replace chain on 450s mcculloch chain saw
You might want to purchase a combination set with a new bar and chain, if so, Oregon #108764 is the 16" length set.
If you only want either a chain or bar, then the following are the correct ones for your chainsaw:
Chain 16" @ 3/8" pitch = #91VX054G (low profile, semi-chisel)
Bar 16" = Oregon #160SDEA318 (w adjustable chain tensioner)
Bar 16" = Oregon #160SDET318 (no adjustable bar slot for use on chainsaw originally equipped with the Intenz bar only)
Hope you find this very helpful and best regards!
Aug 16, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
HOW TO INSTALL A NEW CHAIN ON POULAN 16'' BLACKHAWK CHAINSAW
hi likniz
unlock the lock nuts,take off the chain cover,change the chain,adjust the screw tightening chain,back the cover and the lock nuts.
best wishes savumihai71
Nov 16, 2008 | Garden
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
