When lg lcd 32inch tv is cold, there are lines from left to the middle of the screen. When it warms the lines are gone, when you tap on the side panel it comes back and go away again. Pls help.
    Top Expert:
  • Televison & ... Master
  • 75,178 Answers
There is a loose contact to the flat cable {LVDS} cable, that connects the T'Con board to panel. Check it. Re-seat this cable once at both ends and check. This must rectify the problem. For more information go to http://electronicshelponline.blogspot.com/
Posted on Nov 26, 2013
BMW Rider
  • 232 Answers
SOURCE: LG 20LS7D flat panel LCD TV
Hi, go into your menu and turn off closed captioning, sometimes listed as "CC" instead of spelled out "closed captioning", this will fix ya, Happy Holidays, BMW Rider
Posted on Dec 01, 2007
SOURCE: LG flat panel plasma with red line
I had the same problem and fixed it by replacing the control board. It's a little nerve wracking, but required only simple hand tools. If you'd like to see detailed pictures of the repair check out my blog.
http://greenrenovation.wordpress.com/du-42px12xc-repair/
Posted on Feb 04, 2009
SOURCE: I have an LG 42" LCD tv with blurred image on half the screen
lg 42 in lcd tv power button blinks nine times before staying on and has sound but no picture
Posted on Feb 05, 2010
SOURCE: Vertical colored lines on left half of screen.
I had this problem on a 37" Viewsonic LCD. Pulled it apart and through a process of elimination, I traced the problem back to a small board with several flat white ribbon cables coming out of it. The board was near the top center of the screen and under a ton of other equipment requiring almost a total disassembly.
This small board was clean but I noticed one of the rubber standoffs had slipped down and was making contact with one of the outputs running to the LCD. It also happened to be the output running to the section of the screen with the problem.
I postulated that the sticky glue on the rubber standoff may have just enough conductivity to cause a problem. Moved it so that it was no longer touching anything electrical and then reassembled the TV.
Afterwards, I turned it on and was pleased to see the problem has gone away! If you're having the vertical line problem, then maybe this could be your problem too, especially if you have a Viewsonic since it could be a manufacturing defect.
Posted on Mar 22, 2010
  • 8457 Answers
SOURCE: when my LG 42inch LCD tv is off for a while and
This problems it is the causes by the board that call the T-CON decoders board,this board sit at the bottom in the middle of the LCD screen panel.This T-CON decoders board is started dying to causes these problems or the fibers opotic cable connections is loses or frail damges to causes slightly signal tranmittion from the T-CON decoder board to the LCD screen panel.Just used the tv,when the problems is there for good.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoders board for the replacement.
Posted on Jan 27, 2011
Connected to cable box sound no picture reboot left tv on 3 hrs. fine. turned off. 2 hours later turned on now no pic just sound. When the tv is cold no pic. when warm pic. ???
https://www.Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc
May 13, 2017 | Sony Televison & Video
Sony BRAVIA KLV-37U300A 37 In LCD TV with shadow background on screen
That sounds like a defective LCD panel tab, Sony's and Samsungs are notorious for this problem. Does the problem go away when the set warms up or when you tap the screen?
Dec 07, 2012 | Sony BRAVIA KLV-37U300A 37 in. LCD TV
Samsung TV Screen faulty
t con board failed if its half and half. can also be a lose cable on the screen to the tcon board from the lcd screen side. Tcon is in the middle off the screen on the back.
Nov 18, 2012 | Samsung LE46M51B 46 in. LCD Television
I have a 42 lg lcd tv when i switch it on the right side of the screen is darker than the left also there is a vertical bar about 1" at the edge
Be careful using this TV. There is a fault somewhere. No TV should ever do that, cold or not. Replace or repair it
Nov 24, 2017 | LG 42LC2D 42 in. LCD HDTV
LG - 32LD350 - 32" LCD TV - 720p is the type of tv
Hello
It has been permanantly damaged, and is not repairable. To get it work perfectly, you have to replace the screen. OK.
Aug 03, 2011 | LG 32LD350 32 in. LCD TV
We purchased a Sony KDL-46W3000 LVD TV in May 2008. Just recently the left side of the screen has started having problems with hortizontal grey bars and white lines and the screen jumping around when the...
Hi I have an old school solution for your problem with your tv. Hit it!!!!! When you turn on your tv, go to it and lightly tap on the middle of the left frame. You should see it affect your screen. Do it until your screen is perfect. Hope it works.
Jun 22, 2011 | Sony BRAVIA KDL-46W3000 Television
Mines a LG RZ42PX11 it intermittently gets a black vertical line down the middle of the screen.
Hi I have a LG RZ42px11 there are 6 vertical thick black lines running down the middle off the screen, when cold the TV seems OK but if it has been on for around 10mins or on standby the lines stay on screen.
Thanks.
Douglas.
May 13, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
Feb 04, 2010 | LG 42LC2D 42 in. LCD HDTV
My 8 yr old daughter thru the remote and broke the screen on my 32in LG lcd tv. All black now, looks like broken glass on left side. Can it be repaired for less than new?
your lcd panel is bad most of the time that is the most expensive part on the tv. cost on a 32inch lcd panel is 650.00 not including labor . this lg panel is not aviable now.sorry.
thanks doctor video leadng edge electronics since 1987
May 11, 2008 | Televison & Video
HP OmniBook XE3 display problems
it is your logig board that turn defect.
Apr 20, 2008 | Gateway FPD2275W LCD Monitor
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
