Question about Philips SHD8900 Wireless Headphones
When removing headset from dock they wont connect
My motorola elite charging dock when it's charging the light on the charging dock blinks green and yellow it will not charge the earpiece unless I'm holding it down
Will:
Sorry you are having an issue. How long ago did you purchase the headset? If within 1 year and you have proof of purchase, please CONTACT US for options.
Mark
Motorola Support
May 26, 2015 | Motorola Mobility ELITE SLIVER Bluetooth...
Sound Still Play through Speakers when Headset Connected
Most computers will only pair this earpiece as a headset for voice calls. You need to make sure the headset is paired with your device as both a phone headset and media headset. Check your settings on your computer or smartphone to make sure it is paired properly to play media sound.
Apr 13, 2014 | LG HBS-700 Bluetooth Headset
Connected to Laptop but Sound Still Coming Through Speakers
What happens when you un-dock the laptop? It could be that the external speakers in the dock over-ride any attempts to pair with the headset. Can you configure where the sound output goes from the laptop?
Nov 02, 2017 | LG HBS-700 Bluetooth Headset
A friend connected a android phone's bluetooth to my itower. it worked, but now my iphone bluetooth does not connect. Can anyone please help me!
Pairing with iPhone
  1. Connect the iPhone Dual Dock or iPhone Bluetooth Travel Cable to a USB 2.0 port on your computer (not on the keyboard).
  2. Connect iPhone and the headset to the dock or cable. The headset pairs with iPhone automatically.
Pairing iPhone Bluetooth Headset with another Bluetooth-enabled deviceTo pair the iPhone Bluetooth Headset with another wireless device, such as a Bluetooth-enabled phone or computer.
Step 1: Set the headset to be discoverable
  1. Turn off the headset.
  2. Press and hold the headset button for about eight seconds, until you hear the startup tone and then five quick high beeps.
    The headset is now discoverable and will remain so for about five minutes. The status light blinks while the headset is discoverable.
Step 2: Turn on Bluetooth on the other device and search for devices
  1. On the device, turn Bluetooth on and set the device to search for other Bluetooth devices.
  2. On the device, choose iPhone Bluetooth Headset and enter the PIN code 0000.
See the instructions that came with your other Bluetooth-enabled device for more information about pairing it with Bluetooth devices.
Apr 13, 2013 | Apple Soundlogic Itower Speaker Works W/...
Isymphony v1blue docking system, the bluetooth pairing function is not working, any ideas? Thanks
  1. Settings
    • If the Plantronics headset was working before, an unintentional change in settings may have resulted in the headset not pairing. Access the Audio Device Settings menu in Settings, and restore the default settings for headsets.
    Re-Pair
    • Resetting the connection between the headset and PS3 may solve the pairing issue. USB headsets only need to be connected to a USB port to be paired. A Bluetooth headset must go through the pairing process (see Resources).
    Functionality
    • If you're using a Bluetooth headset, confirm that it has fresh batteries and is receiving power. If possible, sync the headset with a cell phone or another PS3 to confirm that it works.
Jan 20, 2013 | Audio Players & Recorders
Jabra gn9350 base lights are not coming on.
There are a number of steps you can try to fix this issue:
1. Confirm the power supply is plugged in correctly, and the power socket to which it is connected is turned on and receiving power.
2. Remove the battery from the GN9350 headset and ensure the copper contacts on the battery and the headset itself are clean - a quick blow on both parts will be OK. You remove the battery by taking off the earhook or headband, and sliding the speaker section down towards the microphone boom - it will unclick. Reconnect the battery after you've blown on the contacts and re-pair the device as per step 3.
3. Re-pair the headset to the base: ensure the headset is docked in the base. Locate the button with two grey arrows pointing towards each other which is located on the side of the circular base section. Hold this button down for approximately 5 seconds, until you see a blue light flash on the headset itself - you can release the button once the light flashes. The headset is now paired again.
4. If the lights are still not showing up you may have a faulty battery, or a faulty headset/base.
Aug 30, 2012 | Jabra GN9350e Wireless Headset
Ear peice wont charge from the charging dock
If it is under warranty (1 year) Plantronics will replace the headset and charging base case for you. Package up both the headset and the charging case and include your return address, phone number and a copy of your receipt and send to:
Plantronics ATTN: Service Center 345 Encinal Street Santa Cruz, CA 95060
Good luck from Headsets Direct - 800-914-7996.
Aug 24, 2011 | Plantronics Discovery 975 (8164001 P)...
Well there's not much more to tell the charge port and the charge connecter seem to be losing the embrace to one another unless I find a position where it will stay on and keep charging but it's...
if there is any corrosion in your connections using a pencil eraser to clean the contacts could help. Just take an eraser (like on the back of a #2 pencil) and erase the corrosion from the contact points, both on the headset and on the charging dock. Once the contact points look like new, give it a shot ... this might clean up the power connection and help you out.
If the connection where the headphones meet the charging dock has a spring in it (usually on the charging dock side of the connection) then you might have a worn spring. Sometimes pulling on the spring loaded connector (VERY Gently, to stretch it back to where it should be) can help ... but this is a last resort method as if you pull too hard you can pull the connection too hard and disconnect it inside the dock.
If neither of these works, you will probably have to either bring it to a repair shop and see if they can help, or buy a new charging dock (though if the problem is on the headphone side a new dock might not resolve the issue. If you are able to find a position that you can sit the headphones on the dock that will still charge the phones, you probably just have a dirty or loose connection, though.
Jun 07, 2011 | Logitech ClearChat Pro USB Headset
Cannot hear anything out of the earpiece of my GN netcom 9120 wireless headset
I was also experiencing the same problem (also after a power failure / storm) -- apparently good battery charge, connections ok, etc. I then tried removing the battery from the headset itself, waited 30 seconds, and then reinstalled the battery. This seems to have resolved the problem.
It is fairly easy to open the clamshell, but you will need a very fine Phillips screwdriver to remove the battery hold-in (it's really not a hold-down, it just keeps the battery in place. Reassemble the same way -- be sure to keep positive to positive and negative to negative.
Sep 01, 2007 | GN Netcom (9120-48) Wireless Headset
Philips SHD8900 Wireless Headphones Logo
42 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
