Question about Precor C846i Experience Series Commercial Grade Recumbent Bike - Refurbished
The precor c846i upright bike does not power up when the pedals are turned
My precor efx 546 makes noise like a squeaking in left pedal it seems I tried to tighten pedal but I the whole bolt and screw turn together and the other pedal makes no noise
This squeak is normally caused by a bad bearing in the wheel. In order to provide you with the correct wheel, I will need your serial number. The following link will take you to our Precor EFX 546 page.
Repair Parts for Precor EFX 546 Ellipticals SPORTSMITH net
May 29, 2014 | Exercise & Fitness
Panel will not light up.new battery did not help
On C846 version 1 units, set the on/off switch in the "on" position. It will be necessary to start pedaling for the bicycle to "power up".
For any other units, we recommend checking for any loose, crimped, or visually bad wires.
Make sure the speed sensor on your bike is working.
You can run a quick test by using a magnet to swipe in front of the sensor to see if it is sending signal to your console.
For any further troubleshooting please do no hesitate to call our Tech Support Team 888-713-2880
Or check us out online
https://www.sportsmith.net/
Jan 30, 2014 | Precor Exercise & Fitness
I have a Precor C846i which started to display 'STUCK KEY' after using it the other day. Tried to use it again and the display still has 'STUCK KEY'. Need to find out the issue and how to troubleshoot or...
It sounds like the stop switch cable has come loose from the upper display. There are four screws on the back of the console. Remove them and pop the front display loose. Check the the small green circuit board that is under the directional pad. Make sure it's cable is connected and attached to the main board.
Sep 14, 2013 | Precor C846i Experience Series Commercial...
C846 hard to pedal
follow this instruction. God bless you
Detach the ends of the pedals from the crank axles. Spread a layer of machine grease over the crank axles, then reattach the ends of the pedals.
Remove the bolts connecting the pedals to the swing arms. Detach the pedals from the arms, then spread a layer of machine grease over the axles on the swing arms. On some models, the bolts may also serve as the axles. Reattach the pedals to the arms.
Remove the bolts connecting the swing arms to the elliptical's upright. Detach the swing arms from the upright, then spread a layer of machine grease over the axles on the upright. Reattach the arms to the upright.
Jul 21, 2013 | Precor C846i Experience Series Commercial...
Precor elliptical keypad replace
Step 1:
please see the video for help in dissasembly the elliptical keypad replace.
Step 2:
please SEE the detail for dissasembly the console in elliptical.God bless you
Console
Remove the bolts or screws securing the console to the upright assembly. Lift the console and confirm that the cable connections are secure. Remove the cover from the console's battery bay and install a fresh set of batteries. Replace the battery cover.
Detach the ends of the pedals from the crank axles. Remove the left and right disc shields and side shields. Inspect the interior of the base unit and locate the flywheel.
Inspect the flywheel as it turns. Locate the magnet installed on the flywheel. Turn the flywheel until the magnet passes in front of the nearby reed switch. Loosen the screw securing the switch in place. Rotate the switch to reduce the gap between it and the magnet. Tighten the screw.
Replace the left and right disc shields and side shields. Reattach the ends of the pedals to the crank axles.
Jan 07, 2013 | Precor Efx 546 Version 1 Lower Body...
Precor C846i bike-cannot access Club features to make changes
adjust the magnet with the bolts, and move and tight very well.
2) proof the magnet with the magnet from your refrigerator for attraction and repulsion, if doesnot pass the test replace the magnet.
and proceed according with common sense.
God bless you
Jul 22, 2012 | Exercise & Fitness
Can't find the serial number -- there is no tag or it has been removed. It's a precor efx 546, MANUAL not electric and I either need a new battery or a battery charger. What do I do without the serial...
Precor Serial # Locations Type of Unit Serial # Location Treadmills Located on the label near the power cord entry and on the frame under the left rear of the treadmill. Upright Bikes Located on the front stabilizer. Recumbent Bikes Located on the front stabilizer. Ellipticals Located on the front stabilizer. Stair Climbers Located on the bottom side of one of the foot pedals. http://www.sportsmith.net/
Jan 22, 2011 | Precor EFX 546i Elliptical Version 4
Belt replacement for precor efx 645 verison 1
You may have to purchase the belt from a Precor dealer in you area, if you don't have one then call Precor directly @ 1-800-347-4404 and they will help you. Most of these part have not hit the secondary market yet and Precor pretty much call the shots.
Feb 26, 2010 | Precor EFX 546i Elliptical Version 4
Precor C846i Experience Series Commercial Grade Recumbent Bike - Refurbished Logo
18 people viewed this question
Top Precor Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
