Question about Philips SHD8900 Wireless Headphones
NOT CONNECTING TO STATION - Philips SHD8900 Wireless Headphones
Mains adapter for auto-xs power station not working
It could be that the internal battery is too discharged for the AC charger (as supplied with the Power Station) to work.
You could try charging the Power Station using a Vehicle (Car/Motorbike) 12 Volt battery charger, connecting the Crocodile clips on each unit.
I''ve just done that, although once 'I'd got the Power Station battery's voltage above 2 Volts, I used a 'special' charger (Optimate 5) that automatically applies several modes including 'Desulfation' for recovery.
Oct 05, 2012 | Cameras
Dell latitude D410 wont boot up when hooked to docking station can not use keyboard or mouse
Sounds like a compatibility issue between your Dell and the Docking station. I would say make sure the software for your docking station is installed properly, and update the software before connecting again.
Jul 10, 2010 | Dell Latitude D410 Notebook
WEP is not valid for the selected network
As you have reset your base station, reconfigure it again after connecting it to your PC via cable. There you can configure wireless settings and WEB key encryption settings. Then delete the old connection settings present in your PC via network connections window and try connecting your PC via wifi as a new connection.
I hope this is helpful to you
Thanks
Feb 07, 2010 | Microsoft MN-510 802.11b (L21-00002)...
Usb ports on the ibm docking station not active
Dear rajeshraja42,
Try to run the recovery CD from IBM Docking station, and reconfigure your system by connecting your docking station while you run them.
Or try this:
Connect your docking station to your Laptop then turn the Computer On!
Start>My Computer--- Then right click--- Choose 'Properties'>On the dialog box, ----choose the 'Hardware' Tab> Choose the Device Manager box by click them>Now You are in the DEVICE Manager Box>>>
Run the Scan For Hardware Changes... Then if you find that your docking station appear with Yellow Question Mark Then, right click on it and choose 'Uninstall' from context menu and answer YES! then Run the SCAN for hardware changes for ONE last time, Your System should find your Docking station as part of your system now!
GoodLuck!
Best Regards,
bionic23
Dec 07, 2009 | IBM (250410U) Docking Station for ThinkPad
My ipod is not connecting on Bose docking station.
Some of the older docking stations don't recognize the next gen iPods.
Refer to your user manual to see what iPods are compatible with your system.
May 18, 2009 | Apple iPod touch Second Gen (8 GB,...
Cable needed to connect SNY DCR-SR40 Hndycm N DCRA-C162 Handycam Station to computer
There are 2 cables,
  1. A-V Connecting Cable P/N 1-831-553-11
  2. USB Cable P/N 1-829-579-41
attached with Handycam Station DCRA-C162. Hope this info is helpful to you.
Aug 12, 2008 | Sony Handycam DCR-SR40 Camcorder
WACS700 NOT CONNECTING TO STATION
Mine did the same, the station was trying to connect on channel 1 wi-fi where the centre was on channel 11, check under information and wi-fi for both. I then did a restore on the station, put both into installation mode and they found each other after a few mins.
Hope this helps
Jul 08, 2008 | Philips WACS700 Shelf System
Wacs700
From HDD mode on the centre, press menu and select "Station Management".
If the option is available select "Delete Station" and delete any stations listed.
Select "Add New Station" and the unit will start searching.
On the station press menu and select "installation mode"
If this option is not available, try from another source setting, such as AUX.
Once the centre has found the station, press stop on the centre, as the station cannot connect until the centre has stopped searching.
If this doesn't work, you will have to reset both units to factory settings and start again.(Menu -----> Settings ------> Restore)
Feb 23, 2008 | Philips WACS700 Shelf System
Audioline cordless phone
answering machine not working on the base station
Jan 13, 2008 | Philips CD6452B/37 Twin Cordless Phone
Philips SHD8900 Wireless Headphones Logo
48 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
