Question about Frigidaire Dishwashers
Frigidiare Dishwasher Model FGHD2455LF0 will not stop.
Rinse only cycle works. Heavy and Normal cycles will not count down and continue to run for hours. China cycle count down to 47 minutes and then continue to run. Changed control board and user interface. Still same. Checked heating element for continuity. It is good.
4 Suggested Answers
SOURCE: Bosch SHU5300
If your heat cycle is not coming on, which it sounds like it is not, then you may have a problem with the heating system. There is a well known issue with many of the Bosch dishwashers that use the (266746) control module. Basically, there is a relay (which is a kind of electro-mechanical switch) that is used to turn on the built-in heater. There is a solder joint on the main Printer Circuit Board (PCB) that allow electricity to flow to the heater, that joint often will melt away and burn the surrounding area of the PCB. This is most likely a design flaw and appears to occur at about the 4-5 year mark. One way you can test for this is to run the onboard diagnostics routine that is programmed into the firmware of the micro-controller (brain) of the dishwasher. The way to do so it to press and hold the (Scrub Wash & Delicate/Econo) buttons at he same time and then press the on/off power switch to the on position. The LED lights above both those buttons should begin to flash, when they do, press them both again and the diagnostics program will start. It is a multi-phase program that will run for quite a while. Once it finishes, if it is a heating problem, it will end with a number 2 code in the display. If this is so, then it very well maybe the solder-joint issue on the control module and it will need to be replaced. It runs $128.10 US directly from www.bosch-appliances.com. Good luck.
Posted on Jun 30, 2009
SOURCE: whirlpool dishwasher ADP6000WH Error 3
Hi there i have found out that error 4 mean's two many soap suds and ths washer thinks there's two much water. Try less soap and clean the filters.
Posted on Mar 13, 2010
SOURCE: Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
Posted on May 25, 2010
Bosch dishwasher runs continuously
I would call Bosch with you.re model and serial number, they have had a recall on your model for the control board and that sounds like it may be your problem, if it is under recall Bosch will send someone out at no charge to install a new board (800) 856-9226
Jan 24, 2014 | Bosch Dishwashers
Kenmore dishwasher model #665 15872000 is stuck on time saver option for washing and I can't get it to switch to any of the other options such as normal wash
Similar Kenmore Dishwasher 665.18664000. Time saver and Quick rinse were the only programs that would run. I pressed "high temp scrub" then "air dry" then "high temp scrub" then "air dry" and the machine went into a diagnostic mode and counted down from 10 while running a series of tests. After about 10 minutes and various test cycles the machine reset and the "normal wash" light had come back on. If this doesn't work then you may have a problem with the controller which other threads have mentioned replacing yourself for about $120.
Feb 11, 2012 | Dishwashers
CDA dishwasher (model number CW496) , stops working at the rinse cycle, and does not empty, filter is ok, tried re-setting the programme but unless there is no water being held the programme won`t work
my dishwasher starts off with good intentions then a couple of minutes later it starts beeping non stop.I open the door to find it has turned on to the rinse cycle and will not do its job.I continue to start it again and then it repeats the problem again.Can you help?
Sep 21, 2009 | Dishwashers
Whirlpool dishwasher stops at rinse cycle and won't go
Aureley, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Aureley), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 18, 2017 | Whirlpool 24 in. GU980SCG Built-in...
Soap film on every thing..I'm using a rinse agent in every cycle
sounds like you may be using to much detergent.. put your dishwasher on a quick rinse cycle and see if it suds up.. if it does put a table spoon of vegtable oil in the dishwasher and continue running it. after that cut down the detergent and use it like normal.
Feb 28, 2009 | Dishwashers
Have Whirlpool dishwasher Gold Series, Model GU9805CGB1 which stops part way through wash cycle with the led indicator blinks on the normal cycle.....if we ope nthe door and shut ...it continues until part...
sounds like the door is losing contact with the door switch, first thing i would check is the door strike.Metal strike plate located on the tub itself that the door latch catches as it closes. its a spring metal striker, i would try bending it down a little bit to ensure better contact with the switches inside the door itself . next id open the control panel and check to make sure your door switches are secured well, wires are tight.
Mar 22, 2008 | Dishwashers
Bosch SHU5316
Sounds like the control module is out -- cost about $100 (I am on my third). I got a "lifetime" warranty when buying my second one. If you are handy, you can replace it yourself. You can call Bosch to confirm this (I did). It mounts inside the door.
Apr 15, 2007 | Bosch 23 in. SHU5302UC Built-in Dishwasher
Dishwashers Logo
54 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Garth Jackson
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
