Question about Frigidaire Dishwashers
Frigidiare dishwasher FGHD2455LF0 will not stop the cycle
Rinse cycle works and count down. Heavy and Normal cycle will not count down and continue to run for hours. China cycle count down to 45 minutes and then continue to run. Error code LO is on display which may be low on rinse aid. Changed the main control and user interface. The same. Checked the heater element. Element has continuity and good. What is happening here. I am a repair guy.
  • 213 Answers
SOURCE: test bosch heating element
remove the kick plate at bottom of dishwasher, at the left leg there will be a wiring diagram. remove console and test element from there. diagram will show which wires to test
Posted on Nov 20, 2007
SOURCE: Bosch SHU5316
Sounds like the control module is out -- cost about $100 (I am on my third). I got a "lifetime" warranty when buying my second one. If you are handy, you can replace it yourself. You can call Bosch to confirm this (I did). It mounts inside the door.
Posted on Jul 23, 2008
SOURCE: Bauknecht GSX4756 dishwasher
I have this problem frequetly - it's an easy one to fix! Just press the programme button which changes the programme setting you want (on my built-in GSX4756 it's the last button on the right) and keep it pressed in until the beeping stops. Then start it again (will probably be on the rinse programme if it's like mine).
Posted on May 12, 2009
SOURCE: Bosch SHU5300
If your heat cycle is not coming on, which it sounds like it is not, then you may have a problem with the heating system. There is a well known issue with many of the Bosch dishwashers that use the (266746) control module. Basically, there is a relay (which is a kind of electro-mechanical switch) that is used to turn on the built-in heater. There is a solder joint on the main Printer Circuit Board (PCB) that allow electricity to flow to the heater, that joint often will melt away and burn the surrounding area of the PCB. This is most likely a design flaw and appears to occur at about the 4-5 year mark. One way you can test for this is to run the onboard diagnostics routine that is programmed into the firmware of the micro-controller (brain) of the dishwasher. The way to do so it to press and hold the (Scrub Wash & Delicate/Econo) buttons at he same time and then press the on/off power switch to the on position. The LED lights above both those buttons should begin to flash, when they do, press them both again and the diagnostics program will start. It is a multi-phase program that will run for quite a while. Once it finishes, if it is a heating problem, it will end with a number 2 code in the display. If this is so, then it very well maybe the solder-joint issue on the control module and it will need to be replaced. It runs $128.10 US directly from www.bosch-appliances.com. Good luck.
Posted on Jun 30, 2009
SOURCE: whirlpool dishwasher ADP6000WH Error 3
Hi there i have found out that error 4 mean's two many soap suds and ths washer thinks there's two much water. Try less soap and clean the filters.
Posted on Mar 13, 2010
Kenmore dishwasher model #665 15872000 is stuck on time saver option for washing and I can't get it to switch to any of the other options such as normal wash
Similar Kenmore Dishwasher 665.18664000. Time saver and Quick rinse were the only programs that would run. I pressed "high temp scrub" then "air dry" then "high temp scrub" then "air dry" and the machine went into a diagnostic mode and counted down from 10 while running a series of tests. After about 10 minutes and various test cycles the machine reset and the "normal wash" light had come back on. If this doesn't work then you may have a problem with the controller which other threads have mentioned replacing yourself for about $120.
Feb 11, 2012 | Dishwashers
CDA dishwasher (model number CW496) , stops working at the rinse cycle, and does not empty, filter is ok, tried re-setting the programme but unless there is no water being held the programme won`t work
my dishwasher starts off with good intentions then a couple of minutes later it starts beeping non stop.I open the door to find it has turned on to the rinse cycle and will not do its job.I continue to start it again and then it repeats the problem again.Can you help?
Sep 21, 2009 | Dishwashers
Soap film on every thing..I'm using a rinse agent in every cycle
sounds like you may be using to much detergent.. put your dishwasher on a quick rinse cycle and see if it suds up.. if it does put a table spoon of vegtable oil in the dishwasher and continue running it. after that cut down the detergent and use it like normal.
Feb 28, 2009 | Dishwashers
"normal cycle" light keeps blinking
The blinking button indicates the button is bad. The button console will have to be replaced.
If you need further assistance, let me know
Regards,
reg501
Jul 11, 2008 | Whirlpool 24 in. DU1050SS Built-in...
Bosch shu5315 06
it sounds as though the circulating pump may not be operating. if so fault is often due to the pump capacitor being faulty and this is a cheap part.
Jun 05, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Have Whirlpool dishwasher Gold Series, Model GU9805CGB1 which stops part way through wash cycle with the led indicator blinks on the normal cycle.....if we ope nthe door and shut ...it continues until part...
sounds like the door is losing contact with the door switch, first thing i would check is the door strike.Metal strike plate located on the tub itself that the door latch catches as it closes. its a spring metal striker, i would try bending it down a little bit to ensure better contact with the switches inside the door itself . next id open the control panel and check to make sure your door switches are secured well, wires are tight.
Mar 22, 2008 | Dishwashers
None use for 7 days
I have a fisher paykel dd603 dishwasher. If I select the normal wash setting on the top drawer, it posts the time in the lcd screen as 56 mins. The unit will wash as usual until it reaches the 28 min mark. At this point it will stay on 28 mins and continue to run, but it won't rinse or empty the drawer of water. Also it never counts down below the 28 min mark. It has flashed a F4 and F1 code. I've cleared them both, and checked to make sure that no water is standing on the bottom of the unit, and that the heating element is working. I should mention that the top drawer did overflow about two weeks ago, and that I did clean up the water. I don't know where to look from here. Any suggestions?
Sep 10, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwashers Logo
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
