Question about Matrix Commercial Treadmill: Mx-t5x
Matrix treadmill won't turn on - Matrix Commercial Treadmill: Mx-t5x
Treadmills are shutting down after persons are running on machine. The power is tripping, shutting down. After break or machine is turn on it works again
Chances are the treadmill started by shutting off in the middle of a workout and has gradually gotten to the point that it will not run long, or turn on at all, in some cases. This is most likely caused from a worn deck and belt. If the belt and deck is not routinely waxed, it wears down and causes friction. This friction builds up heat which can fry your electronics. The machines circuit breaker shuts the machine down to protect the major electronic components. This protective measure, built in by the manufacturer, will only help for so long. After a few times of shutting down due to the heat, it actually does damage to the electronics. The result and correction usually ends up being a new deck, a new running belt, and in most cases that have gone on too long, the motor control board. I am attaching a link for the service manual for further information. Parts for Matrix T3 Treadmills T3x T3xi Belts Rollers Decks SPORTSMITH...
Aug 27, 2013 | Matrix T3x Treadmill Deck Treadbed Parts
Matrix MX-3 error code 1
see the diagram attached for the speed sensor. test for open or faulty. clean it, and tight for plug or connector.
2) Test the input voltage motor, if there are the motor need repair
3) Test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Dec 16, 2012 | Matrix T3Xi Treadmill
Life of running belt in matrix treadmill
all depende how frequently you LUBE the deck belt, may you have a worn Deck. see the instr. manual and see the video.
God bless you
Aug 05, 2012 | Matrix MXT5 Treadmill
My Matrix T3X treadmill display doesn't work
tight the ribbon cable keypad, clean it +tight the wires connector from display board vs lower board and clean it.
2) adjust the reed switch, clean it and tight the wires connector.
see the diagram.
God bless you
Jul 19, 2012 | Matrix T3Xi Treadmill
My matrix MX-T5x start running and stop in seconds. With the error code E7. What is the problem ?
By E7 it means Speed sensor feedback missing. You have to check the speed sensor mounted near the motor pully. Remove the speed sensor and clean it well Then refix it then check the tread mill by powering ON. If then also the problem remains the same , You have to replace the speed sensor.
ok
Aug 02, 2011 | Matrix MXT5 Treadmill
Hi, i have an Error signal " 2 - 9 F " the treadmill stops and cant run anymore. thanks a lot!
I have a Matrix Treadmill t4. An error of "E1 and E3" occurs when it is started? Can you tell me the solution?
Mar 15, 2011 | Matrix T3Xi Treadmill
Matrix Commercial Treadmill: Mx-t5x Logo
76 people viewed this question
Top Matrix Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
greg kinsley
Are you a Matrix Exercise and Fitnes Expert? Answer questions, earn points and help others
