Hansgrohe iBox reversed hot & cold how to repair
Hot &cold installed in reverse hot is plumbed on thre right inlet and cold is installed on left
    Problem Solver:
  • 17 Answers
Swap the hoses at the shutoff valves on the wall
Posted on Dec 11, 2013
4 Suggested Answers
SOURCE: HITACHI WASHER SF 6500PX, COLD
hitachi washer sf 6500px lid for washer
Posted on Mar 07, 2008
abhishek33
  • 1239 Answers
SOURCE: GE WHRE5260E1CC NO HOT WATER
hi If the washer won't fill or fills very slowly, if it overfills, or if the water is the wrong temperature, the water inlet valves could be faulty. These components are easy to locate and very easy to replace, at little cost. When you suspect an inlet valve is faulty, first check to make sure the water faucets are fully turned on and properly connected to the hot and cold inlets of the valves. Then check the screens in the valves; if they're clogged, clean or replace them. If water doesn't enter the tub, set the temperature control to the HOT setting. If there is no water, set the control to the WARM setting. If all that comes out is cold water, the hot-water inlet valve is faulty. Reverse the procedure to test the cold-water valve, setting the control first on COLD and then on WARM. If the tub overfills, unplug the washer. If water still flows into the tub, the valve is stuck open. In any of these cases, the valves should probably be replaced. To check the valve assembly:
Step 1: Remove the back service panel and disconnect the hot-water and cold-water hoses to the valves.
Step 2: Remove the hoses connected to the valves inside the cabinet. Also disconnect the wires from the terminals. Back out the screws holding the valves to the machine. The inlet valves have solenoids (a coil of wire that carries a current) inside the housing. These can be tested, but chances are the valves are simply worn out.
Step 3: Tap the solenoids with a screwdriver handle. If this doesn't work, replace the entire inlet valve assembly. Repairs usually cost more than a new part. Make sure the replacement valve assembly is exactly the same type as the old one. Install it in reverse order of the way you disconnected the old one.
Posted on Sep 13, 2008
canbruce75
  • 1776 Answers
SOURCE: maytag performa washer hot/cold cycles reverse, hooked up correct
This sounds like a cold water supply problem that's usually caused by a problem at the water inlet valve. First, remove the water supply hoses and check the small screens inside the water inlet valve. Make sure they are not clogged with rust or debris. Next, check the solenoids using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty solenoid and the water inlet valve assy will need to be replaced. I will attach a photo for reference. Hope this helps and best wishes.
Posted on Aug 10, 2009
Washer fills with hot water on cold wash or rinse. Turned off the hot water supply during cold cycle and machine stopped filling. Checked that the hoses were connected to right inlet valve and they are.
typically hot is on the left and cold is on the right at the house faucets but in some cases they are reversed so if filling with a cold setting and the right side supply is hot the plumber reversed the lines when the house was built which while its semi rare has been seen numberous times
Sep 26, 2011 | Whirlpool GHW9250M Front Load Washer
Cold/cold cyle wash water not cold
try to do cold cycle first without doing warm cycle first
Apr 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I installed a dhc tankless heater, but when I open only the hot water everything is ok, but when I open the cold water at the same time the heater turns off.
Hi and welcome to FixYa, I am Kelly.
What is happening is that your cold water flow is greater in volume (gals per min) than your hot water. So when you open the cold water it is mixing with the hot water inside the faucett or shower plumbing and actually reverse flowing back into the hot water heater plumbing. The reverse flow slows the water flow sensing turbine inside the heater and it is thinking that there is not any water flow. (There isn't actually due to the equalization of water pressure when you open the cold water faucett) Since this is a safety feature of the tankless heater to keep it from overheating, it shuts off.
Somewhere in the hot water plumbing there is a major restriction. It may very well be the internal plumbing of the tankless hot water heater or the flow detector design.
There are 2 ways to correct this. The easy way would be to restrict the available cold water flow. You can do this by installing another shut off valve inline with the cold water plumbing and just not open the valve all the way. You would have to adjust the setting so that the hot and cold water can be on at the same time and the hot water heater stays on. The hard way is to locate the hot water flow restriction and eliminate it.
It is possible.... if you have a flow restrictor in a shower head or a screen in a faucett areator that they are partially clogged. Clean any flow restrictors and screens then see how the hot water heater performs before you start modifying plumbing.
Thanks for choosing FixYa,
Kelly
Apr 10, 2011 | Stiebel Eltron DHC-E 8 Tankless Electric...
I've been given an old (10+ yrs) Moen shower control valve that I want to use (it does apparently have pressure balancing built-in), but don't know which side is hot and which is cold. Does Moen always...
Moen and all shower valve manufacturers follow american federal guidelines. Hold the unit in your hand with the handle facing you - the left side is the hot water inlet and the right side is the cold water inlet.
Nov 25, 2010 | Moen & Posi-Temp Single Handle Shower Or...
My maytag washer has a water temp. problem I,ve replacrd the water temp switch (pt.# 37001263) 4 pole switch several times but the problem still returns I,m getting hot water insted of a cold water...
You say that you are getting hot water instead of cold on rinse... Does that mean that when you select hot water wash you get cold?
If so, the machine 'thinks' it is giving water that is the wrong temp.
You may be sure that the hoses are the right way round, but if the water temp is opposite to what it should be, there's obviously something amiss!
Try swapping the hoses and see what happens...If the hoses are 'right', it could be that the water inlet valves are 'wrong'. It could be that the 'cold' wires are on the 'hot' inlet valves!! & vice versa
Good luck....Nomess
Aug 05, 2010 | Washing Machines
Hot water comes out when i turn the thermostatic temp to the right. cold water comes out when i turn the thermostatic control to the left. Since hansgrohe is a German brand, is this correct? i believe...
no, someone probably reversed the water lines in the wall, or if the cartridge was replaced, it was installed backwards.
try removing the cartridge and flipping it, and try it out....
this works on almost all grohe faucets
Aug 03, 2010 | Hansgrohe Plumbing
Single-handle Glacier Bay shower faucet, hot/cold reversed
Hello. It sounds like your plumbing was installed wrong, with the hot and the cold supply lines reversed. If that is the case, those supply lines will have to be replumbed to make your faucet work properly. Often, if those lines are accessable, it is only a 20 minute job. Joe
Mar 18, 2010 | Delta & Single Handle Shower Faucet
Hot water on cold washes
To solve this problem simply reverse the water hoses from the way that they are set up currently. Then do a test again to make sure that when you select HOT you are getting HOT.
Nov 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Hot and cold water in shower comes out in a triclkle
shut off the water from the main pipe.
use a allen screw driver take the handle off the shower control.
pull of the wall cover.
pull out the pin that stablized the cartridge in the control body. (remember how it is, before you take it out. or take a digital pic of it). pull out the cartridge. and bring it to any home center or plumbing store.
install in reverse.
Jan 04, 2009 | Water Pik Waterpik& Elements& Handheld...
Hansgrohe shower
it's possible sometimes you can get brand new junk. one question is the thermo coupler in the right postion? i would check to make sure that it is indeed picking up the temp like it should.
Sep 02, 2008 | Home
Washing Machines Logo
140 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
