Cant stop dryer machine wont stop cant do nothing
    Genius:
  • 2,100 Answers
-Timer switch stuck. or did you recently rewire...?
Good luck
Mai
Posted on Dec 21, 2013
Model # fex831fso stackable frigidaire dryer wont start just humms
you may have applied high voltage/power or in appropiet current flowing through the conductors
Feb 16, 2016 | Frigidaire Washing Machines
MAYTAG 3000 F01 CODE
It's probably a weak or failed component on the board. It's a common issue on those machines and the Whirlpool Duets. It's usually burned at the motor relay or heater relay.
F01 error code flashes when there is a primary control failure.
The only thing which will solve an F01 error code is a new machine control board. These is a catastrophic control board failure. Nothing can correct it. The part number you require is W10205977.
Dec 17, 2013 | Maytag Dryers
Splendide 2000S Vented Washer/Dryer makes a bad noise once in the rinse cycle and water will not drain
Check the drain pump. There may be a coin, hairclip , button etc stuck in the blades of the pump. If the machine cant pump out, it wont go through the cycle.
Sep 17, 2017 | Splendide 2000S Vented Washer/Dryer
Last nite mid cycle my 90 series dryer quit and now i cant get it to do anything. changed the fuses in the fuse box but still nothing . might it be the thermal fuse ?
may be the thermal fuse but here is a website that can help:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Feb 10, 2011 | Kenmore Dryers
Press the start button on dryer, it hums but wont turn. With 2 people pressed the start button again, held the door switch, reached in turned the drum, it hummed stopped humming then no more nothing....
Sounds like a weak motor. You'll have to get a new motor installed. They are fairly inexpensive and easy to install yourself on that type of machine if you are handy. Motor is located in the bottom right of the machine, attached to the drum belt through a small pulley underneath the drum next to the motor.
Dec 27, 2009 | Dryers
Kenmore dryer wont stop buzzing
The ECU is faulty - or the timer.
Check/replace as needed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 10, 2009 | Kenmore 98702 Stacked Washer/Dryer
My dryer wont stay on.
you have a bad microcomputer or as some calls it (even heat board) thats needs to be replaced / if you cant find one contact me with the complete model number from the sticker inside door area and i will see if i cant help you with one / larry
Dec 12, 2008 | Kenmore 63942 Dryer
Reset childlock model mah2400aww
did you try to unplug the unit for 30 minutes
Oct 16, 2008 | Maytag EPIC MFW9700S Front Load Washer
Hotpoint aquarius wd440g washer/dryer
Hi claire your problem is the pump braking down check to make sure there is nothing in the pump if you still cant get the door open pull the mains plug out and turn off the water valves red and blue take off the top of the machine and get a basin take the drain hose out and put it in the basin and bring the two down to the floor empty all the water out you should now be able to get the door open remember to check the pump and the bearings
Jul 27, 2008 | Hotpoint Aquarius WD63 Front Load...
We have a washer dryer WD420 and the dryer has stopped working is that anything we can try and fix?
MOST TIMES WHEN A DRYER JUST STOPS AND DOES NOTHING IT IS EITHER THE DRYER DOOR SWITCH LOCATED BEHIND DRYER DOOR OR THE MAIN FUSE FOR THE DRYER IS BLOWN,MOST DRYER YOU CAN REMOVE BACK OF DRYER TO GET TO FUSE,ALSO SOME DRYER'S HAVE A SAFETY SHUTOFF IF BELT BREAKS IT IS UNDER THE DRUM,LET ME KNOW IF YOU NEED MORE HELP-MIKE
Jun 08, 2008 | Hotpoint Washing Machines
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
