Hoover se 148 no doing maximum spin
My hoover se148 is not doing the maximum spin, clothes still coming out soaking. Can someone help?
SOURCE: Clothes come out soaked
I have the same problem, but in my case it pumps all the water out fine. It just adds a couple of "rinse" bursts of water while spinning so the clothes come out soaked sometimes. Have you found a solution?
Posted on Sep 15, 2007
  • 26 Answers
SOURCE: clothes come out soaking wet
Is the Delicate or Hand Washables cycle selected?
Spin speeds can vary by the cycle that is selected. Your washer is designed so that in certain cycles, such asDelicate or Hand Washables cycles, the spin speeds are slower. In these cycles, more water is retained in the load at the end of the cycle to keep delicate fabrics from shrinking and wrinkling. Select the appropriate cycle based on the fabric being washed.
Was an Extra Low, Low or No Spin option selected?
Select the highest spin speed for the fabric being washed. If extra low spin or no spin was selected, the washer may not remove enough water from the load.
Were you washing one bulky item, such as a rug or large blanket?
Consider adding more items to help balance the load during spin. Select $FL-drainspin cycle and restart the washer. Your washer is designed to detect an unbalanced load and automatically lower the spin speed. Unbalanced conditions are more likely to occur with a single, bulky item.
Are excessive suds present?
Use only HE High Efficiency detergent. Using non-HE detergent or more than the manufacturer's recommended amount of detergent can cause excessive suds. The excess suds can cause the washer to run at a reduced spin speed, which will result in very wet loads.
See also: Why HE High Efficiency detergent is required.
Is the drain hose kinked or is the drain clogged?
Make sure the drain hose is not kinked. Straighten the hose for adequate water flow. Remove any blockage from the drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose. See the Installation Instructions for details; find them by entering your model number in the Manual and Literature search below.
Is the end of the drain hose more than 96" (244 cm) above the floor?
The drainpipe (standpipe) height requirements are: 96" (244 cm) maximum and 30" (76.2 cm) minimum. Your washer will not be able to adequately pump the water out of the washer if the drainpipe (standpipe) exceeds 96" (244 cm). In this case, the water may flow back into the washer. See the Installation Instructions for details; find them by entering your model number in the Manual and Literature search below.
Is your outlet voltage low?
Check electrical source or call an electrician.
Posted on Dec 19, 2008
SOURCE: hoover hnl 6166 not spinning
have you tried cleaning the filter at the bottom. remove the front plateat the bottom and there is a small round plate at the left. this has a screw in it. when you have removed this you give it a twist. a bucketload of water and gunk will come out. i found about 60p in 5's but when it was all removed it started to work again
Posted on Feb 05, 2009
  • 1122 Answers
SOURCE: clothes coming out of washer still soaking wet
is it a kenmore top load?if so the motor is not kicking in to 2nd gear for high fast spin,does it have a speed control on the head?are you using it on the reg. wash cycle?-mike
Posted on Apr 18, 2009
BIKER T
  • 909 Answers
SOURCE: will not do final spin cycle leaving clothes
Your drain pump has something lodged in it. Remove drain motor, open it up and inspect for obstruction. remove it then reassemble.retrywashing cycle.
Posted on Nov 12, 2009
Hotpoint WF250 clothes coming out soaking wet after spin?
The fast wash cycle is for a reduced capacity load of approximately 3kg , it does not pump or spin long enough for a full capacity load
Jun 15, 2016 | Hotpoint Washing Machines
Front loader spins at high speed, clothes still soaking wet? why?
I think the water is syphoning back from your waste outlet make sure the waste pipe is installed correctly
Jan 22, 2013 | Washing Machines
My Hoover 700 LA Top loading washer does not spin dry clothes after the was cycle ? The drum does not spin fast enough for the clothes to dry out as before.
Just got Hoover 700 la manual top loader 2. hand...it is taking maximum amount of water on low arrange, and takes an hour on delicates. it also spin dries very strongly, just ruined my clothes..what you would suggest folks..
cheers aysh
Jul 06, 2012 | Washing Machines
Hoover se 230 works perfectly except will not perform fast spin. (nothing happend when programmer dial is turned to fast cycle position
hello any spin problems can be caused by the module control board usually sits at the back of the washer may have a load of wires coming off it hope it helps
regards
shaun
Apr 22, 2011 | Hoover SE230 Front Load Washer
The washer doesn't spin out the water. Clothes come out soaked?
if it washes ,,check your lid switch,,if it doesnt wash and spin check your motor coupling...onthejob
Jan 10, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Hoover hnl 6166 not spinning
Jan 07, 2009 | Hoover Nextra HNL 3166 Z Front Load Washer
Washer not spinning right and not completing a cycle
Sounds like you need to replace the carbon brushes on your washing machine motor
Sep 26, 2006 | Hoover H130E Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
