Question about Bosch HME9760 Microwave Oven
Bosch microwave 10 amp internal fuse blown
Hi there where can i get one and is it likly to go again?? cheers
    Sergeant:
    Champion:
  • 214 Answers
They go once in a while Your can replace it make sure it is a ceramic fuse and the right amp.
Posted on May 09, 2009
Bosch microwave & exhaust fan trip fuse when on at the same time as the gas stove.
see the next steps: use the common sense and VOM
1. No power to outlet (overload or fault in microwave or other appliance).
2. Blown main fuse - likely due to other problems.
4. Defective controller or its power supply.
5. Clock needs to be set before other functions will operate (some models).
Jul 31, 2012 | Bosch Microwave Ovens
I have a samsung microwave oven,model smh 7185,does it have an internal fuse?
Most MW do have an internal fuse, most likly a 10 amp ceramic (HRC) You can replace with a glass one but if it blows it could rupture
Jan 30, 2012 | Samsung SMH7178STD Microwave Oven
The microwave turns off after about 30 seconds. It does not seem to heat at all for the 30 seconds that it is on. Electricity stays on as you can still see the time.
Hi mstgermai267,
I have the same problem on myBosch microswave HMT 9656/GB, which stops after 22 seconds and does not heat. Did you ever get to the bottom of your problem, which seems to have cropped up with a number of Bosch microwave oven owners? There is a suggestion that there is some sort of internal fuse that may have blown.
Brendan
Regards
Nov 26, 2010 | Bosch 500 HMB5050 Microwave Oven
Blown fuse 10 amp LG microwave oven model ms2127c it blown while im cooking a popcorn. what shall i do?
You can get a replacement fuse from almost anywhere ranging from Ebay to an authorised LG repair agent, but please remember a blown fuse can simply be the symptom of a larger problem, so my advice is to buy two, replace it, if it works then you have a spare, but if upon replacing the fuse,it blows again straight away, your microwave may have a more serious problem. PLEASE READ UP ON THE DANGERS OF A HIGH VOLTAGE CAPACITOR AND ALSO HOIW TO DISCHARGE ONE AS THEY CAN HOLD A LETHAL AMOUNT OF CHARGE AND CAN CAUSE FATAL INJUFRIES INCLUDING DEATH.
Sep 06, 2010 | LG Microwave Ovens
I have a blown internal fuse on my JennAir M170b microwave. The fuse holder says 250V, 15A fuse, but the fuse that was in there is a 125V, 15A fuse. The micro plugs into a normal 110V circuit. Which type...
The information on the fuse is the maximum rating. The holder may not match the rating.
The 'A' is the very important part of the size. You will need a 15 Amp fuse. The best fuse to use is 'ceramic'. You can find them at Radio Shack in the back of the store there are drawers with electrical parts.
15 Amp ceramic
Jun 10, 2010 | Jenn-Air M170 Microwave Oven
Microwave combination oven failureHME9750GB/03 FD8106 (/555350)
APPLIANCE HAS INTERNAL 8 AMP SAFETY FUSE IF THIS HAS BLOWN IT WILL NEED MAJOR REPAIRS AND POSSIBLY COSTLY THIS FUSE ONLY BLOWS IF FAULTS EXIST WITH HIGH VOLTAGE SIDE OF APPLIANCE SO NO NOVICE SHOULD ATTEMPT A REPAIR.
Jan 18, 2010 | Bosch HME9760 Microwave Oven
Viking Microwave Model VMOC205SS little over 4
9 amps is approx. correct. Does magnatron make an odd sound when running? If not, you will need to discharge cap then clean terminals with alcahol. Replace diode as well. Should run correctly.If blows again, replace magnatron. Suggest you put a 12 amp fast blow fuse in circuit and nor a 20 fuse.If you dont have a grill or an oven, use a 10 amp fuse.
Sep 17, 2009 | Viking VMOC205SS Microwave Oven
Microwave wont run, displays E 10 on the screen and also microwave fault, press stop to acknowledge, just changed the door.
e 10 is the internal safety fuse has blown this often happens if door is altered for any reason moving the door can effect the setting of the monitor switches these are set to a high tolerance to avoid operation of microwave with door open changing the door has shifted these settings and blown the fuse, replacing the fuse may be enough to get it going but it should be checked for leakage.
Jun 11, 2009 | Neff H5470 Microwave Oven
Bosch microwave HME9750
the sighn with a spoon inside is to alert you to the dangers of delayed boiling this is were the liquid in a container is heated on the outside quicker than the inside when you remove the liquid and expose it to the ambient air in your kitchen the liquid can boil over scalding your hand it doesnt have anything to do with your friends cup of tea this is pure coincidence the pop is the internal safety fuse blowing will need attn from service tech to sort high voltage safety fuse blowing means inverter or mag faults.
Aug 07, 2008 | Bosch HME9760 Microwave Oven
Bosch HME9760 Microwave Oven Logo
852 people viewed this question
Top Bosch Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Bosch Microwave Oven Expert? Answer questions, earn points and help others
