Question about 1960 - 1961 Dodge Pioneer Engine Coolant Thermostat 35476 Dodg
My Pioneer VSX-RS320K displays speakers off. With Speaker Test, all speakers work but as soon as I switch of the Test, it deplays speakers off again. How do I cancel the speakers off mode?
    Novelist:
  • 84 Answers
If the speakers are operational when display says "speakers off," then its a factory defect. If your model was manufactured in China, FYI they use prison labor on their assembly lines. If you still have the sales receipt showing it was purchased less than a year ago, then USA consumer protection laws require one year factory warranty against defects. Course, you have to pay for shipping/ handling, and put enough cushion and bubble wrap to protect from shock & vibration as the package goes through US postal system.
Posted on Nov 29, 2013
Ow do I het both Speakers A and B or toggle between on the PIONEER VSX RS 320?
http://www.pioneer-mea.com/en/manuals/12700251012VSX-RS320K.pdf
Apr 12, 2014 | Audio Players & Recorders
PIONEER VSX-RS320K DISPLAYS SPEAKERS OFF HOW DO I TURN IT BACK ON?
The Pioneer company has a 44 page manual going over several on off features of the speakers - you may find this helpful.
www.pioneer-mea.com/en/manuals/12700251012VSX-RS320K.pdf ·
Nov 26, 2013 | 1960 - 1961 Dodge Pioneer Engine Coolant...
I have a Pioneer VSX 452 receiver. I am trying to run a second set of speakers off the b channel and use the a and b switches on the front of the receiver. If only the a channel is depressed the two...
Thanks for the detailed explanation...
It seems to be there is a short or misplaced (+) (-) leads on the speaker connection you made..sometimes a tiny cable piece can make a short in between the leads and cause such problem..My recommendation is:
** take all the wires off..
** install only B speaker leads and test it..( make sure LEFT and RIGHT (+) and (-) leads properly
and individually connected to the right places on the back......it is important...This causes balancing problem..
** if it works fine...
** than go ahead and install the A speaker leads..and test it..
if you do everything properly both A and B speakers should work fine as independently ...
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Jun 22, 2011 | Pioneer VSX-454 Receiver
I have jamo sub200. I connect to pioneer vsx-rs320k audo video receiver. when I turn the volume of subwoofer to a higher value with the receiver, the bass sound becomes distorted and not satifieng to...
hi,
Do one thing set the control behind the sub. set the level and cutoff control at it half position. Set phase control at "0" position. Then test the sound. if you ate using tower speaker as front speaker then you have to set the position of phase control 180 ,
ok
Apr 11, 2011 | Jamo SUB 200 Subwoofer
I have a Pioneer VSX-917V. After using it for a couple hours and everything working good, the center speaker quits working. I can reset the unit, re-ajust all speaker settings to my prefrence and the...
If new unit, don't waste your time, sounds like a faulty "Sound Card". possibly a slight hairline crack which only shows up when it warms up, yet after a few mins switched off, cools reconnects and so plays?
Dec 26, 2010 | Pioneer VSX-917V-K Receiver
Pioneer VSX-45TX turning itself off
check all speakers and wire not short... you can try open each speaker testing....
Nov 12, 2009 | Pioneer VSX-45TX 7.1 Channels Receiver
New pioneer vsx-517 keeps going into overload
Fastest way to test is to disconnect all speakers and turn up the vol. If it clips it needs service, then re-connect 8ohm speakers one by one and test until you find the speaker or channel that shorts. Then take that same speaker and hook it up to another channel and test, if it shorts, you know now it is either the speaker or the wire. Now, use a new piece of speaker wire from the same channel that caused it to short, replace the old and test. If it shorts, you've got a problem with the speaker. If your handy with a multimeter, check the resistance at the speaker and you will have your answer. If you are not familliar with a multimeter, just hook up a different speaker where the bad one is and test. It's just process of elimination. Hope this helps
May 25, 2009 | Pioneer VSX-517
Pioneer vsx-d511
Clark, you MIGHT have a simple problem here. Let's keep our fingers crossed... This problem generally has more to do with the speaker WIRES or their IMPEDENCE than anything else, even though the receiver displays "AMP ERR." (Technically, it IS an amp error, but the source MAY not be the amp!) The very FIRST thing we need to do is check to make certain ALL of your speakers have an IMPEDENCE of 8 OHMS. (Pioneer says 6, but that's not necessarily a good recommendation, particularly if you listen LOUD.) Virtually all speakers of even modest quality will include this specification on a label on the back of the speaker. You CANNOT run more than (2) TWO speakers with 4 OHMs impedence on ANY amplifier (technical discussion too long!) [NOTE: Your receiver has internal overload protection systems to prevent permanent damage. On SOME Pioneer models, these can be "reset" but you can't do it yourself. Your dealer or authorized service center must do so.] But, before you take it in for service, there is one more "test": check for shorted and/or mis-connected/disconnected speaker cables/wires. 1) Visually inspect connections at the receiver AND speakers. You might find something obvious! Look for bare wires touching one another. Again, you must look both at the receiver, AND at the speakers. 2) If everything looks okay, then disconnect ALL of the speakers at the receiver; and reconnect and test them one at a time (at relatively low volume.) For example, reconnect the left front speaker, test the system; THEN add the right front, test the system, and so on, ADDING one more speaker each time - FIRST MAKING SURE EACH OF THEM HAS AN IMPEDENCE OF AT LEAST 8 OHMS! IF there is a short (or bad speaker) this will help isolate it. Hopefully one of these simple fixes will get you up-and-running. Good luck!
Jul 02, 2007 | Pioneer VSX-D511 Receiver
Pioneer VSX-D498
Perhaps the unit isn't switched to 5.1 Maybe the movie wasn't recorded in 5.1 or if it was perhaps the recording was faulty. Try a known good recording to check the system. Check your outputs and inputs plus your speaker cables. Check the fuse if there's a seperate one for left and right, which there should be. Try swapping the front speakers to the rear and the rear to the front and see if the fault is still with the rear sound. BMW
May 15, 2006 | Pioneer VSX-D498 Receiver
1960 - 1961 Dodge Pioneer Engine Coolant Thermostat 35476 Dodg Logo
48 people viewed this question
Top Stant Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Stant Vehicle Part and Accessory Expert? Answer questions, earn points and help others
