Question about Garden
Mover ran fine for 15 minutes then stopped trying to get it going again, it turns over but doesn't run afterward
    Scholar:
  • 79 Answers
Check for clogged air filter. However, if it is not the air filter, remove the spark plug and check for wettness. Could be soaked with fuel or oil. If it is oil, you have have bad rings or valves. To check this apply 30psi of air into the spark plug chamber with the engine at Top Dead Center, or valves closed. Check if you hear air coming from intake, exhaust, or breather. If air is coming out you intake or exhaust your valves are not seated right or worn out. If air comes from breather then you cylder is scored or rings are shot. However, if no air is coming out of these places then you might have weak spark. Replace spark plug first to see if this helps. If it does not help the ingnition coil will need to be replaced. But, before doing all of this, check to make sure your air filter isn't clogged with dirt.
Posted on May 08, 2009
RE LK 3504 (35 hp 4 wheel drive Tractor starts, runs 5=10 minutes under load, then slowly fades away running slower and slower until it stops. Restarts in 15 min, same result
Here is an idea.
It sort of sounds like there is a blockage after a while in the gas tank.
If there were sediment in the bottom of the gas tank, it would start and run fine sitting still.
However, when driving it, it would be a matter of a few minutes until the sloshing of the fuel would cause the sediment to mix in with the fuel, and clog the filter screen in the fuel tank.
When it stops, the sediment would settle back down, and in 15 - 20 minutes, it would be clear again.
God bless your efforts.
May 08, 2017 | Cars & Trucks
My 2.0td vitara starts good, drives well, but stops like turning off key. Engine management light comes on, but if leave car sit for 5 minutes, turn key, and runs perfect . Stop car, restart, all ok , with...
i had the exact same thing happen to me with my first car, a 1966 mercury comet.
i replaced the fuel pump, rebuilt the carburetor (twice), and finally rebuilt the entire engine! still, every time afterwards, the car ran ok, then would cut off again!
it turned to be just a $2 clogged fuel filter. i' suspect the same with your vehicle. after removing the filter, simply blow through it. any resistance, means it needs replacing.
Sep 03, 2013 | 2002 Suzuki Grand Vitara
95 accord intermittently runs
Bent valves- my 96 civic had that too. it's a manufacturing fault. Have you mechanic do a leak down test.
Apr 26, 2017 | 1995 Honda Accord
Mk4 gti vr6 has power but doesn't start, runs with pop start
Could be a number of things but may want to begin by checking wiring to starter, battery, or even the ignition switch. These components may not turn your engine light on.
Jun 17, 2017 | 2003 Volkswagen GTI
2002 Shadow: bike leaks gas from the carb, and runs with no gas going to it
Carbs have a reservoir in the base that will last for a few miles before it is drained. So turning the fuel off doesn't starve the engine immediately. This is normal.
Oct 06, 2012 | 2002 Honda VT 750 DC Shadow Spirit
2002 mercury grand marquis wont start when engine at normal temperature must wait 15-20 minutes
I have exactly the same problem started last winter, ran fine all summer then as soon as it got below freezing again if I start it and run for 15 20 minutes wont restart I have to let it sit for 20 minutes or so and then it will start again. no codes and just turns over without starting. cant be fuel pump like i said had this problem last winter then ran fine all spring summer and fall! Anybody got the answer for this one??
Mar 09, 2012 | 2002 Mercury Grand Marquis
2004 Ford Explorer won't start after battery recharge
A FORD MACHANIC HAS TOLD ME THAT IN FACT THE KEY HAS TO BE RECODED. MY SITUATION IS EXACTLY THE SAME. HE SAID TO RECODE THE KEY I HAD TO TURN THE IGNITION TO THE RUN POSITION, THE SECURITY LIGHT ON THE DASH WILL FLASH RAPIDLY AND CONTINUE TO FLASH FOR 15 MINUTES . WITHIN FIVE MINUTES AFTER THE LIGHT STOPS FLASHING I MUST TURN OFF THE IGNITION FOR ONE SECOND AND TURN IMMEDIATLY BACK TO THE RUN POSITION FOR 15 MORE MINUTES. THE LIGHT WILL GO OFF AGAIN . WITHIN 5 MIN. I MUST TURN OFF THE IGNITION FOR ONE SECOND AND TURN BACK TU RUNNING POSITION. 15 MINUTES LATER REPEAT STEPS AGAIN AND THE KEY WILL BE REPROGRAMMED, AND STSRT THE CAR. GOOD LUCK MY CONTACT IS A FORD MASTER MECHANIC.
Jul 17, 2009 | 2004 Ford Explorer
Runs fine for approx 15 mins,then stalls out and wont start again
sounds like coil problem, coils will start cold then get hot and stop. when coil cools will crank up and run till it gets hot, try to replace the ignition coil,dont think it would be a crank sensor, try a coil,thanks robert b.
Jun 19, 2009 | 1993 Jeep Cherokee Country
2001 pontiac grand will not start all of a sudden. ran fine this
The problem may be the security issue. Do you see a security light? Dust gets into the ignition tumbler and causes a bad contact with the sensor prompting a false security issue.
I had the same problem and thought it was a fuel pump issue, but after a $500 replacement ordeal, I later encountered the same issue again.
To resolve:
Insert the key and turn on ignition tumbler to ACC on (Position prior to engaging the starter)
Wait around ~15-20 minutes (The security light will change... I believe it will flash when the security reset...it's been a long time...sorry)
Afterward, turn the ignition tumbler and off
Your card should start there after
Tumbler maintain: Blow some compress air to prevent this incident from happening.
Hopefully this will resolve your issue without the need of spending any further $$$!
Dave
Apr 11, 2009 | 2001 Pontiac Grand Am SE
Garden Logo
76 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
