Question about Fluke 700PTP Pneumatic Test Pump
Pump failing to hold pressure
My pressure pumb Fluke 700 ptp pnuematic test pump is failing to hold pressure. help
    Problem Solver:
  • 31 Answers
Is a oneway valve inside check it if is block or broken
Posted on Nov 27, 2013
Re-assembling the piping on the pump of a bissell aroma pro 8910
I'm guessing you took it apart because it stopped pumping water. You shouldn't waste your time putting it back together because it still won't pump. These are the only machine my store will not work on. It is built to fail after 6-8 uses and they all fail. Replace it with a Hoover.
Aug 07, 2017 | Bissell Vacuums
Bisselll Proheat pump
If you can remove the rectifier, take it to an electronic shop where they can test it for you. They'll likely do it for free. Also, make sure ALL electrical connection to the pump and other related electrical devices are clean and un-broken.
Oct 14, 2013 | Vacuums
My steam cleaner pro heat 2X will not spray water. we have even tried the tool attachment and still nothing
sounds like you may have lost the pump prime turn the unit off and hold the trigger down the one on the handle for a full minute then turn the unit on if that does not do you might have a clogged pump hose or a bad pump hope this helps you out
Sep 23, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Machine will not dispense water even though reservoir is full. Soap is not dispensing either.
check the spray nozzles on top of the brushroll. these often clog. If those are clear could most likely be the pump as they fail frequently.
Jan 29, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
It is leaking water out the bottom when off and won't **** it back up through bottom chamber when on
I personally would dismantle the covers as much as possible. Look for any leaky hoses or tubes. Look for cracks in the canister that could leak. Any air leaks can cause lack of vacuum pressure and release the liquid that is already there. Or if the pump is faulty or leaking, it won't work to **** or to hold pressure.
Nov 12, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Pump motor sounds like it is running but is not pumping
The pumps in these machines are very simple and there's almost nothing to go wrong. If the problem is actually in the pump, the most likely thing is that there's something stuck in one of the valves, but this is unlikely as long as you've got an undamaged filter on the intake tube in the clean water tank. More likely is that the diode has failed in the live wire supplying the pump. The function of the diode is to act as an electrical one-way valve, and if it fails the pump will sound like it's working but it won't shift any water. I don't know of an easy way to check the diode, but replacing the pump lead-wires should be cheap. If that doesn't solve the problem, fit a new pump (they're not expensive).
Good luck! Please remember to rate this response, thanks.
Oct 29, 2009 | Bissell 1672 BIGgreen Wet/Dry Vacuum
Hoover steam vac..F7452-900. not working in wash-auto rinse mode
This problem sound like you hav a problem with the pump. I would take it to a shop for service
Sep 26, 2009 | Hoover F7452-900 SteamVac Upright Vacuum
Bissell Proheat only sprays for a few seconds.
When was the last time you changed the flat belt? Even if it isn't broken it could be so stretched out that when the brush hits the floor it slows or stops the pump from spraying. If its a new belt then and your sure there arent any clog's that usually means the pump is bad. Also if youve ever used anything other than bissell shampoo in the machine it could have ruined the pump as well.
Sep 15, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
I have a proheat 2x, and the pump will only spray water for a few seconds when unit is turned on, then nothing. The attachment is the same way. I think this is the pump failing, and the unit is only over a...
I just had my pump replaced for $66 and the repairman said this unit is notorious for this problem. He had 6 other units in his shop when we came in. Make sure you keep your clean water tank FULL, as he said the pump fails as soon as it runs dry.
Apr 04, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
How to replace pump for 7901 bissell pro heat steam cleaner
unplug unit first
take six screws out of housing.
lift of housing.
you can see pump at front of machine.
four screws hold pump in.
make sure all tubes are routed correctly.replace housing,
make sure no tubes are trapped
Jun 04, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Fluke 700PTP Pneumatic Test Pump Logo
32 people viewed this question
Top Fluke Vacuums Experts
JoeVacs
Are you a Fluke Vacuum Expert? Answer questions, earn points and help others
