Canon lide110 code:2,179,11
Code:2,179,16
If I do the scan, the scanner is warming up for about 10 minutes. after that it said internal error occured. Scanner driver will be closed. Code : 3,202,19
try to uninstall the driver then install it again
note:
1-after you uninstall make restart for computer.
2-don`t connect the scanner USB until the driver installer required this.
Mar 17, 2016 | Canon CanoScan LiDe110
I have problem with my canon Scanner 110 lide
Disconnect the USB (which is the power source) and install the driver. Then reconnect the USB. The driver should be detected automatically. Go into "Device Manager" to check.
Jan 01, 2015 | Canon CanoScan LiDe110
I slightly dropped my canoscan lide 110 Now it doesn't not working
Certainly a drop for today's electronics is nothing like the old days. Its good and bad. Good that it was only a slight drop; bad that nothing lights up; good that it wasn't big and bulky and cracked the entire body and frame and it didn't arc and spark like the elder generation of office equipt. generaly I check to see what I can do ( after looking around to see if any one saw me ) and I check to see if the pwr source just got rattled. loose cord batteries not making good connection.If still no go I evaluate if plan B is needed. B is physically getting into it. ie take the bottom or back cover off . some times B is solved quickly with say a loose soldier conn. or the small "coin" battery came ajar. I'm batting nowdays about 29%. In the 60's and 70's I batted about 85% of broken equipt. I'd get into I could fix fairly quickly with a mod or two(jury-rig) or a soldering. As the years roll on parts are added to others and/or no longer mechanical. It cheapens the product but simplifies it immensely. A simple switch is now three diodes and two transistors. When plan B isn't satisfying. it's either put it back together; trash it; or REALLY take it apart~ plan C. Looking for any thing that I can do. generally the last stop for I part it out. This time period to me is important. it helps me slowly accept that some things really are not made to last. ( especially slight boo-boo drops) good luck my friend.~~~SC
Oct 17, 2014 | Canon CanoScan LiDE110 Flatbed Scanner Inc...
I cannot scan with my scanner: " it says RELEASE THE LOCK SWITCH,DETACH THE USB CABLE
Hi ,
Disconnect your unit from your pc ( usb and power)
Insert your install cd and run the program
Restart your pc
When Windows has settled , connect scanner back to pc .
It should run normaly .
Best regards.
Aug 15, 2014 | Canon CanoScan LiDe110
Error code 2,179,11 cannon lidi 110
lide 120 release the lock button on the back side
Nov 01, 2013 | Canon Canoscan Lide110 Color Image Scanner
Scanner not Scanning
just check is copy from scanner or not
skype id johnwalker800969@gmail.com
Jun 05, 2013 | Canon CanoScan LiDe110
Canon Lide 110 scans the image in upside down. Is there a setting to flip it automatically?
Unfortunately, that's normal for this particular model. If you read the manual, or in this case the Quickstart Guide, you'll note that the top left corner is meant to go into the arrow corner. I'm annoyed with it too. You can always do it in Post-processing by doing two "turn image 90 degrees". If there would be a setting, it would be in the scanning program as the driver for this scanner has no settings available; you would have to check to see if there's a 'reverse image' setting in the program, though I doubt it.
Apr 08, 2013 | Canon CanoScan LiDe110
Canoscan Lide 110 driver
Perhaps you have forgotten to unplug the scanner before
scanning? That's what happened to me. I kept getting
different error codes, 5,202,63 or 5,202,52 or 5,202,54 and
also a message that the driver was not in the TWAIN folder.
According to the help file the problem might have been due
to my nfts file system. I also tried downloading various
new drivers. Nothing helped until I noticed that I had not
unplugged the scanner!
Jun 27, 2012 | Canon CanoScan LiDE110 Flatbed Scanner Inc...
I have no driver in canoscan lide 110, I wanted to download this driver but i dont know how
Hi! Welcome to FixYa,
You may download the driver for Canoscan Lide 110 by clicking this link: http://files.canon-europe.com/files/soft40595/software/sd68-win-lide110-17_0_2-ea24.exe after that. it will prompt you to download the driver, just download it and install. Evertying will be self-explanatory.
Thanks have a great day!
Jun 19, 2011 | Computers & Internet
I have a Microtek 9800XL scanner. I use Photoshop to scan items into my computer. Lately if I use a custom setting and try to scan an image over 300 dpi, I get the following error message (in Photoshop)...
your scanner can not scan above 300. you can try windows scanning, but i wouldn't recommend. New scanners are still a little pricey but are worth it.
http://www.amazon.com/Canon-CanoScan-LiDE110-Scanner-4507B002/dp/B003VQR1UC/ref=sr_1_1?ie=UTF8&qid=1304968981&sr=8-1
for $55 plus shipping
May 09, 2011 | Computers & Internet
88 people viewed this question
jasbo
jasbo
