Question about 1988 to 1991 Mercedes Benz 560SEC Overload Protection Relay
Looking for yaskawa overload rh to suit contactor 110v ha-100f
    Renaissance:
    An user who is expert in 3 categories / brands.
  • AM Auto Parts Master
  • 1,632 Answers
Rear counter auto parts
Posted on Dec 28, 2013
I have an old air compressor that I have replaced the motor magstart and pressure switch on the motor is a 220 / 240 volt 5 horsepower motor it also has a low pressure oil cutoff switch does anybody have a...
Control: L1-SS-P-O-OL-OL-M-L2 In series, L1 is line 1, SS is start/stop switch, P is pressure switch, O is oil switch, OL is overload contact, M is magnetic coil (solenoid), L2 is line 2.
The voltage of M must be rated for the control voltage, across the line voltage (240V) or of a control transformer voltage, e.g. 240v/24v. A control voltage would be wired across the line, to L1 and L2.
Power: L1-T1-OL-M1, L2-T2-OL-M2. Line one to Line 1 on contactor, T1 on contactor jumpered to OL (overload heater) and out the overload heater terminal M1 to the motor terminal 1. Same for line 2, Line 2 to L2 on contactor, T2 on contactor jumpered to OL (overload heater) and out the heater overload terminal to M2 motor terminal.
The heater overload relays needs to be chosen by the motor full load current, a chart is given with a motor starter on selecting heater size. If no chart is available, go 115% of the motor FLA (full load amps) to select a heater size. E.G. 25 FLA motor at 115% is 28.75a. Sorry, no schematic available now, draw your own from this info. If using 3 phase, add the third line as duplicating one other line1 or line 2
Mar 10, 2015 | Air Tools & Compressors
Wire a 220v heater to a transformer, contactor, and thermostat
one side of transformer secondary to one side of contactor coil. the other side of transformer secondary thru t stat to other side of contactor coil. line voltage 220v to l1, l2 of contactor . other side of contactor to load (220v heater. ) Make sure heater has some sort of overload /overheat safety either breaking line voltage or control voltage 24v.
Nov 27, 2013 | Heating & Cooling
Wiring Diagram
I think you would probably find what you are looking for by going to the manufacturer web site : www.yaskawa.com
There is no way that anyone here can find what you are looking for. Incremental encoders are used for anything from robotic assemblers to elevators - unless you provide a lot more information about what it is you are wanting a wiring diagram for, there is no way anyone is going to be able to help you.
Apr 06, 2012 | Cars & Trucks
I NEED YASKAWA MANUAL IN PDF MODEL NO: CIMR F7 U42P2
http://www.yaskawa.com/site/DMDrive.nsf/536df907f9fe9d5586256c4e0056b851/86256ec30069e43286256cd700570246/$FILE/TM.F7.01.pdf
Best regards
Jan 26, 2011 | Inverter Yaskawa F7 Drive
My model ACD2234HRQ is approx 90 days out of
you need to replace the rtc overload contactor located on the compressor body,there is also a run capacitor on the contactor,replace this along with the rtc contactor,this is your problem,the contactor and overload give the compressor starting power and run power to the windings,if the capacitor is bad it doesnt have enough torque to overcome the power to turn the compressor initially
Mar 13, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Both freezer and fridge compartment not cooling
you need to replace the rtc overload contactor on the compressor body by removing the spring wire that secures the contactor to the compressor,then unplug rtc overload and replug it into the compressor and replace spring wire
Jan 15, 2010 | Refrigerators
Overload prblem of inverter
PLEASE MAKE SURE THAT ALL THE LOAD CONNECTED TO THE INVERTER IS NOT MORE THAN ITS CAPACITY, BUT IF IT SHOWS OVERLOAD WITHOUT ANY LOAD CONNECTED TO IT MIT IS POSSIBLE THAT THE OVER LOAD CONTROL IS BAD
Nov 13, 2009 | Inverter Yaskawa F7 Drive
Omron inverter J7
try putting a load of 1 ton, if it trips , the overload control for your inverter is bad
Jun 10, 2009 | Omron Healthcare Omron Yaskawa...
Ruud heat pump outside unit trips circuit breaker
Check your wiring between the contactor and compressor for a short to ground, or check the compressor windings for short to ground.
With the Tstat off, the contactor should be open so the only way for the compressor to be trying to do anything is if the 110 volts from the unbroken side are traveling through the compressor to ground. Since 110v is not enough to run it, the overload is kicking it out, cooling off, and repeating the cycle. When you kick on the Tstat, the contactor is supplying voltage directly to ground without going through the resistence of the compressor windings and kicking the breaker.
Post back and let me know what you find.
Nov 20, 2007 | Ruud Central System Air Conditioner
1988 to 1991 Mercedes Benz 560SEC Overload Protection Relay Logo
Top AM Auto Parts Vehicle Parts & Accessories Experts
Todd Arndt
Todd Arndt
noagge
terry stevens
Are you an AM Auto Parts Vehicle Part and Accessory Expert? Answer questions, earn points and help others
