Question about NEC NP500WS LCD Projector
The projector projects dark shadows on the activeboard
How do I get rid of the shadow that appears to the left of the projected image ?
The shadow is caused by projected light from the unit outside the image field. I have the same problem, and I just tend to ignore it. I have tried various settings and sizes to minimize the effect, but some shadow always remains. This is true with any projector.
Mar 22, 2015 | Sanyo Plc-xp20n Video/data Projector
Parts illustrated breakdown
If it is the lens you have other problems that would let it get that hot. Can't be sure, but I would first check the bulb to make sure it has not smoked. If so it must be replaced. When handling the bulb let it cool down or you can get severly burned. Never let your skin touch it or the oils on your skin can damage the bulb. I usually use a t-shirt or something to wrap it in while handling it or you could just wear cotton gloves.
Aug 30, 2014 | Optoma HD20 DLP Projector
My unit seems to work fine, except there is a dark shadow covering the right third of the projected image. Is this a sign that the bulb is going out?
this is the light tunnel needing to be adjusted or replaced because is has collasped due to the heat given off by the lamp during the life of the projector.
Aug 27, 2010 | InFocus ScreenPlay 4805 Multimedia...
I have a 46 Toshiba DLP television
Hi,it does sound like it could be that mirror since thats what direct the light of the lamp.You will need to replace the light tunnel.
Oct 05, 2009 | Toshiba Televison & Video
Sanyo Multimedia ProX-III, but image projected its like a shadow
hi
I have similar problem with my Sanyo Prox III Multimedia projector.
Feb 18, 2009 | Sanyo Office Equipment & Supplies
Philips 55 inch hdtv rear projector
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
May 21, 2008 | Philips 60PP9363 60" Rear Projection...
Dark area on screen
sound if u might have what is called a crt burn
Jan 03, 2008 | Samsung HLN4365W 43" Rear Projection...
Shadow on right side of screen
check the connector of DMD module. Service all projector and reinstall.
Viren
Nov 18, 2007 | InFocus ScreenPlay 4805 Multimedia...
NEC NP500WS LCD Projector Logo
Top NEC Office Equipment & Supplies Experts
Electro Med Services...
Piyal Perera
Piyal Perera
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
