Question about Toshiba TZ50V61 50" Rear Projection Television
Need a new screen
I need a new screen for my tv but cant seem to find one tz50v61
  • Sintax Apr 05, 2008
    I have a replacement screen but can't figure out how to get the front piece off to slide in the two screens. Help?
Check out PACPARTS.COM..They have a lenticular screen in stock for 117.00..Type in the model number of the set and you can see a list of all replacement parts. Hope this helps
Posted on Dec 29, 2007
SOURCE:
Where can I Purchase a new Lamp for my Toshiba Rear Projection tv Model No 52JM9UA, [email protected]
Lamps are for DLP TVs, Tubes are in Projection TVs Red/Green/Blue.
Mats has Lamps for $89.00 1-800-628-1118
Tubes cost $450.00 and up Encompass Parts Distribution has service Manual/Parts for this Model
1-800-638-3328
What seems to be the Problem with your TV and what makes you think One of the Tubes is Bad?
Most common problem with this TV is the STK ICs STK392-110. Mats has them.
Jan 09, 2011 | Toshiba TZ50V61 50" Rear Projection...
Toshiba big screen modle # tz50v61 , power light comes on but tv does not , light keeps blinking . when i try to power it up , light comes on and then starts to blink again . tv will not power up . VERY...
that sounds like it could either be a convergence issue, or power supply issue. If you go to the following link and leave them a email with your model number and symptoms they will help you identify which part you need.
http://servicemanuals.vstore.ca/
Apr 20, 2009 | Toshiba TZ50V61 50" Rear Projection...
Hi, i would like to know where i can get a FREE service manual for my Toshiba TZ50V61 projection TV.
Did some lookinaround. looks as if you join the forum on the website you should be able to access and manual you need
http://manuals.electromaniacs.com/category.php?id=176
Jan 12, 2009 | Toshiba TZ50V61 50" Rear Projection...
Cracked screen on my Toshiba TZ50V61
maybe I can get you one but I need the sizes in inches by the way some tv has more than 1 screen can you tell me if all of them are broken? I was unable to singn in for a while due to a problem in the system
Oct 13, 2008 | Toshiba TZ50V61 50" Rear Projection...
I need to the outer protective screen for TZ50V61 too
did you make sure that the others screens are ok?I think there are three
Jul 28, 2008 | Toshiba TZ50V51 50" Rear Projection...
Toshiba tz50v61 replacement protective screen
Andrews Electronics
www.andrewselectronics.com
25158 Avenue Stanford
Santa Clarita, CA 91355
  • Phone: (800) 274-4666
  • Fax: (800) 289-03
Apr 09, 2008 | Toshiba TZ50V51 50" Rear Projection...
Toshiba rear projection screen
Hi Shaun. I just picked a new lenticular screen for Toshiba TZ50V61. I went to their Web-page and it showed me where there was Toshiba -based warranty shops according to Zip or area code. I went to one near my area and ordered a screen. It took three weeks to get to me and cost $170.00. I live in Canada so you might get one faster and cheaper.
Mar 24, 2008 | Toshiba TZ50V51 50" Rear Projection...
Toshiba model tz50v61 convergence
need to repleace convergence ic # stk392-110 or stk392-160 on hitachi brand
Mar 16, 2008 | Toshiba 42H83 42" Rear Projection...
Black lines and menu problem
Check for bad caps in vertical circuit. Solder any/all bad connects. REPLACE vertical o/p IC w/OEM or better quality. I usually use Tosh,Hit,or Pana. 2)Check/replace tactil switch (menu)on front panel.
Sep 28, 2007 | Toshiba TZ50V61 50" Rear Projection...
Toshiba TZ50V61 50" Rear Projection Television Logo
95 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
