Question about Mitsubishi HS-U445 VHS VCR
Can't get channel 3 on hs u445 - Mitsubishi HS-U445 VHS VCR
Unit will record by peressing the record button. But when programmed to record, the unit kicks on per the program, tape runs but does not record anything
Vintage VHS recorders can get quite messy. Probaly you need to take it to service. Presume it's time to convert your family tapes to DVD.
Sep 25, 2015 | Mitsubishi HS-U445 VHS VCR
Mitsubishi hs m50v
I forget exactly how this goes but there are two posts on either side of the mechanism that read a light signal and a center pole that goes through the round hole on the cassette that gives the light signal (no tape-end of tape). Put a piece of tape on the two side posts and see if that changes anything. Be careful: the tape now knows where end of tape is - do not fast wind/rewind to the end! The loading motor may have failed or a rubber belt has slipped off or is too loose or broken.
Oct 20, 2013 | Mitsubishi HS-U445 VHS VCR
Diagram for changing spark plugs in in 2003 alero, 2.2 l engine
http://www.google.com/search?q=2003+alero,+2.2&hl=en&client=firefox-beta&hs=9Sl&rls=org.mozilla:en-US:official&channel=np&prmd=imvns&source=lnms&tbm=isch&ei=u4GUT6TGD6TD2QWSo8GSBQ&sa=X&oi=mode_link&ct=mode&cd=2&ved=0CAsQ_AUoAQ&biw=1680&bih=876&sei=v4GUT-jYN6eW2gXYwtGhBQ#hl=en&client=firefox-beta&hs=ETl&rls=org.mozilla:en-US%3Aofficial&channel=np&tbm=isch&sa=1&q=2003+alero%2C+2.2+spark+plugs&oq=2003+alero%2C+2.2+spark+plugs&aq=f&aqi=&aql=&gs_nf=1&gs_l=img.3...29656.32821.0.33423.12.12.0.11.0.0.136.136.0j1.1.0.mWPsfb6VQE8&pbx=1&bav=on.2,or.r_gc.r_pw.r_qf.,cf.osb&fp=c5ba42d9662ee290&biw=1680&bih=876
Apr 22, 2012 | 2003 Oldsmobile Alero
Mitsubishi black diamond E4 fault
your VCR has a problem with the drive belt CAPSTAN, maybe is broken or fallen, you have to take it apart and check that the band is in order
Mar 16, 2010 | Mitsubishi HS-U445 VHS VCR
Mitsubishi VCR model HS-U430. Cable channels 2-6 fuzzy.
Looks that way,the signal is not getting through the vcr,time for an upgrade
Sep 15, 2009 | Mitsubishi HS-U430 VHS VCR
Getting E2 error flashing on vcr and can't rewind tape or anything.Don't have user manual to see what that error means.
E2 means: Loading motor locked in the unload direction. Usually(not always) happens with a going bad VCR tape on the rewind. Tape is becoming too difficult to rewind and/or VCR is getting tired. Eject tape. Discard tape as soon as practical, new tapes are cheap. To clear: Hold power on/off button for 8 seconds.
Aug 28, 2009 | Mitsubishi HS-U445 VHS VCR
E2 error
Just had the same E2 come up on my HSU-445. The only thing we could figure out was to try a different tape than the one that was in there when the error came up. That seemed to do the trick. Not sure how long that will work. Good luck.
Jan 11, 2008 | Mitsubishi HS-U445 VHS VCR
Mitsubishi HS-U445
Check batteries in remote- maybe they are weak/dead. Do the buttons on VCR itself do anything? Unplug VCR for a few minutes, perhaps this will clear the condition. Mitsubishi doesn't show your model, but perhaps this one will be close enough: http://www.mitsubishi-tv.com/j/i/18326/HSU449.html?cid=42
Sep 13, 2007 | Mitsubishi HS-U446 VCR
Error message E4 and stuck tape
Yes with care. Simply remove the cover and with care unwrap the tape. If you must break the tape - but make sure all residual tape is cleanly removed. Re assemble and put a tape head cleaner through- following the instructions.
Jun 22, 2007 | Mitsubishi HS-U445 VHS VCR
Vcr
unplug it for 30 minutes and retry...any luck?
Jun 01, 2007 | Mitsubishi HS-U445 VHS VCR
Mitsubishi HS-U445 VHS VCR Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
