Canon ir1020 Whenever I print or copy, it prints it out, but it also prints everything black on top of it. The document can't be read anymore. I don't know if it's a Tonner problem, or if it is dirty, or whatever else. Thank you
    Top Expert:
  • 12,223 Answers
You must open the utility from printing. Then make test or maintenance to the printer and follow the steps for fix it, section troubleshooting from the utility of the printer. If you can not do it. Go to the website from the manufacturer supplier of your printer, and get the support via ONLINE chat for free and fix it.
God bless you
Posted on Nov 26, 2013
5 Suggested Answers
spinal
  • 287 Answers
SOURCE: I just purchased an imagerunner 2200 from liquidation sale the copies come out black
Hello Platanon,
I feel confident i can help you. And I cannot praise you enuff for the sample you have offerred. Nice touch, and extremely helpful. The drum on your machine is toast. Good news is that it is relatively inexpensive, and comes with instuctions to install it. The fact that you were sharp enough to provide the sample page of the poor copy quality artifact makes me feel VERY confident you will have no problem ordering a new drum and successfully installing it. Just to bolster your confidence, check this out. Notice how there is a pattern to the worst yuck on the page you submitted. It correspondes with the diameter of the drum (@ every 3.7 inches). The linear streaks toward the center of the page are another sign of drum wear. Canon rates the drum @ 55k +/-. You are officially fixed :-) . But if you need more help let me know .Take care...........SPINAL.......
Posted on Mar 23, 2008
  • 9 Answers
SOURCE: D-Link DP-301P+ fails to print 2nd copy of same document
this probelm you facing from your operating system
Posted on May 08, 2008
  • 89 Answers
SOURCE: Problem printing PDF document
In Print settings if using PCL select Print as Image. Also Spool Printing. Use PCL5e or PS drivers.
Posted on Jul 24, 2009
canontech
  • 1219 Answers
SOURCE: our canon image runner 2800 is printing black
Check copy glass, drum unit, fixing film.
Posted on Jun 25, 2010
Whenever I try to print a document on Word, the top of each letter is cut off. Everything on the document looks normal until I print. It is the whole thing that it happens to, not just the first few lines...
This is usually a printer cartridge or printer head issue. Usually you can clean with rubbing alcohol and a swab. Canon printers usually need new print jets.
Jun 18, 2011 | Office Equipment & Supplies
I just installed a Canon mx300 on my Mac (runs 10.4.x) and all seemed to go well. I can print but the black letters don't print black (actually, the same happens if I have colored text mixed in). It's...
If the colors in your document don’t look right, you can change whether colors are managed by ColorSync or your printer.
To change color management options for printing:
Open the document you want to print.
Choose File > Print.
If the Print dialog contains only two pop-up menus and some buttons across the bottom, click the disclosure triangle beside the Printer pop-up menu.
Choose Color Matching from the print options pop-up menu.
Select one of the following options:
Select ColorSync if you want the application you’re using to control the color management of the printed output.
Select “In printer” if you want the printer you’re using to control the color management of the printed output.
If you select ColorSync and don’t believe the correct profile is selected for your printer, you may be able to change it. If you see a Profile pop-up menu, choose Other Profiles from the pop-up menu, and select a new one.
I hope this info will help to sort out your problem..Regards
Jan 08, 2010 | Canon MX300 Office All-In-One Printer
Printing with Black only mode is not working
There is an extensive support document for your question at Canon support: (copy and paste link into your browser)
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=11642
Type question: "How do I print using only the black ink and not the other colors"
Read solution(s).
Dec 05, 2009 | Canon PIXMA iP1600 Printer
Black bar printed in the center of copied document
try copying the document to your computer and then from computer take a print out.
Aug 23, 2009 | HP Photosmart 2575 All-In-One InkJet...
Canon B640 printing problem
The scanner lamp is not working. When making a copy, the lamp lights the source document, so if there is no light, the source document 'looks' black. Your machine will need to be serviced.
Jan 26, 2009 | Canon FAXPHONE B640 Plain Paper Bubblejet
The black, print quality when printing a document on white paper, is not 100%
Few questions, are you running true Canon Inks and refills are always a off black not a true canon black!
Have you tried doing nozzel check, does the top black squares all come out ok? if so it could be down to the paper and the inks!
if you use 80gsm paper does it print ok?
Hope this helps
Sep 30, 2008 | Canon MP610 Photo All-In-One Printer
CANON NP 7130
This is your drum unit or transfer unit that must be replaced.In what area are you?
Jul 14, 2008 | Canon NP 7130 Black and White Copier
Big Black not printing
Sounds to me your print head is plugged up. This is not usual though because the majority of people use black ink much more. So, in your printer utility, do a deep cleaning. If that does not work, there is a thing called a purge unit in it. This is a usual way of draining waste ink to a pad that soaks it up. if the hose, or other parts are clogged, it backs the ink up and causes the print head to clog. If this is the start of it, do not waste your ink cleaning, and try not to let it sit too long. Contact canon, and let them kno what you think it is.
Oct 05, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
