Question about Electrical Supplies
I have just bought a second hand wolf 2300lr generator but doesn't have a pull start. Where can I get spare parts for this generator please???Jordanhunt85@hotmail.co.uk
SOURCE: how to set up a hotmail.com e-mail address?
Browse for http://get.live.com/mail/overview, it will redirect you to a page where you sign up for hotmail ID
Posted on Feb 02, 2009
srinivasjr
  • 58 Answers
I can solve your problem, but a little bit intro of what's happening:
"Microsoft uses IP Geomapping to determine where in the world you are and then assigns you to your local e-mail address" means if your are in Uk you'll get to see only >@live.co.uk >hotmail.co.uk If u use proxy u'll get through.
So this link will redirect you to the US domain addressing @ Live/Hotmail.com
Dont forget to rate my answer :)
SOURCE: body sculpture BT2710 instructions
hi if you email body sculpture on sales@hi-markgroup.co.uk they will send you a free manual by pdf they are brilliant i know because i have used them for the same reason myself last week
Jules
Posted on Nov 17, 2009
  • 342 Answers
SOURCE: Wolf 800 generator. Engine will run but very electrical power is
is the engine running at the correct speed
3000 rpm to produce 50hz
3600 rpm to produce 60hz
Posted on Apr 04, 2010
  • 6277 Answers
SOURCE: I bought a second hand
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 03, 2011
Pull start
In all honesty, if it came loose once it will again. There are videos on YouTube showing how, but it is a real pig of a job to do, and the damaged to the spring or housing that made it fail could do it again (inspect).
Alternatively, you can replace it with a new complete Recoil. Parts Spares for Generators and Small Engine Machinery
Dec 26, 2016 | Electrical Supplies
Troybilt 5500 generator pull cord locks up...just had it for one year...cord was very easy to pull @ first...but lately it locks up when I try to start it...any suggestions?
your cord is too long is why its binding up ,,,on the tee hand where you put your hand on to pull,,,,take a screw driver and push up the tied knot out and away from the tee handle,,,,take and make another knot about 8 inches and pull the cord back into the tee handle then try it again. Most have a long rope, cord etc for maximum pull,,sometimes they go overboard on the length and it binds up on the rewind of the recoil system
Dec 08, 2011 | Briggs & Stratton Power Products 5,550...
Hi we have a wolf 950 generator that wont start,cleaned plug,is there anything else i can try,HELP!
are you getting spark. pull out your plug and with the wire connected. hold the plug about an 1/8 of an inch away from any metal on the motor and ensure your getting spark. also check to ensure your fuel is not bad..
Aug 14, 2011 | Wolf Manufacturing Electrical Supplies
My wolf 1200 starts but stops almost immediatly
check the ignition system for foreign metal parts stuck to magnetic ignition pick up
Mar 20, 2010 | Electrical Supplies
Electrical Supplies Logo
35 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
