Question about Xerox Office Equipment & Supplies
Faint blue pattern printing in backgroound 6280
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 77 Answers
If you have a new blue imaging unit, try replacing it.
Posted on Dec 10, 2013
Is there a way to get rid of horizontal streaks?
1) Inspect, clean and reinstall print cartridge.
2) replace the print cartridge
3) Replace the charge roll assembly. Some call this the fuser assembly.
Aug 15, 2014 | Dell 5130cdn Color Laser Printer
Prints pictures faded
On the pixma printer each time you remove a cartridge. you will need to do a clean of the nozles and print head. you can find instructions in your online operators manual. You hold down the wi-fi button and watch the
Home Click Here to Search
MG3500 series > Overview of the Machine > Maintenance > When Printing Becomes Faint or Colors Are Incorrect
Maintenance Procedure
Printing the Nozzle Check Pattern
Examining the Nozzle Check Pattern
Cleaning the Print Head
Cleaning the Print Head Deeply
Aligning the Print Head
Page top
error light flash. 1 flash release prints all saturation levels2 flashes prints the head alignment chart. 3 cleaning 4 flashes deep clean and so on. or its a transfer problem and this case do a transfer belt clean, and a head alignment.
Feb 28, 2014 | Canon Ink Cartridge for Pixma MP252
Test pgs print ok, jobs= no black only blue faintly appears.
Hi, check if the black toner is properly inserted and check the printing configuration
Dec 09, 2013 | HP PhotoSmart Office Equipment & Supplies
Refilling toner in xerox phaser 6280
I would not advise you to refill a toner cartridge becausethe toner powder is very fine and you do not want to breath in this tonerpowder.When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint.You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer.This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your model printer.A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
Mar 27, 2012 | Xerox Phaser 6280 Clr Laser Printer 26Ppm...
Xerox 6280 printing of blue looks like grey
There is a procedure called Tec Color correction. Go to Xerox.com. Click on support and drivers. Enter 8200, then search. then click support again, then in the search box enter tec color and it will give you the step by step directions. If that does not work then you would most likely have to replace the print head. If your using non xerox ink, then you may want to try replacing the ink with Xerox brand ink and purging out the old.
Jun 28, 2010 | Xerox Phaser 8200 Laser Printer
The colour is faint, a new catridge was installed
When printing becomes faint or colors are incorrect, even if ink remains in the ink tanks, the print head nozzles are probably clogged. Follow the procedures below to clean the nozzles.
Step 1 : Printing the Nozzle Check Pattern.
If white stripes are noticeable
Step 2 : "Aligning the Print Head"
If print quality is poor
Step 2 : "Print Head Cleaning"
if the problem remains
Step 3 : Print Head Deep Cleaning"
if the problem still remains
Step 4 : Replacing Ink Tanks.
Note : * If the ink tank replacement does not resolve the problem, contact the Customer Care Center.
* You will be alerted if low ink warning is enabled.
* When the Maintenace button on the operation panel is pressed, the maintenance mode is shown. Numbers and functions that can be selected on the maintenance mode as follows :
01 : Printing the Nozzle Check Pattern
02 : Print Head Cleaning
03 : Print Head Deep Cleaning
04 : Aligning the Print Head
05 : Reset the ink counter.
06 : "Display" or "Not Display" remaining ink volume.
07 : Date and order setting.
Printing the Nozzle Check Pattern : Print the nozzle check patterb to determine whether the ink ejects properly from the print head nozzles and to verify print head alignment. Use this function when printed results are blurred or the color is incorrect,
1) With the printer on, load a sheet of Letter paper in the printer.
2) Print the Nozzle Check Pattern.
a) Press the Maintenance button,
b) The Maintenance icon and 01 appear on the LCD.
c) Press the OK button. The nozzle check pattern is printed.
3) Examine the nozzle check pattern output by the printer.
a) Lines missing in this pattern indicate that the print head of black ink requires cleaning. Perform the Print Head Cleaning.
b) White stripes in this pattern indicate that the print head of color ink requires cleaning. Perform the Print Head Cleaning.
c) Uneven patterns indicate that the print head requires alignment.
Perform Aligning of Print Head.
d) Noticeable white stripes in this pattern indicate that the print head require alignment.
Print Head Cleaning : Clean the print head if you suspect that the nozles might be clogged. Cleaning the print head consumes ink, so perform print head cleaning only when necessary.
1) Ensure that the printer is on.
2) Start print head cleaning.
a) Press Maintenance button.
b) Press right arrow once to display 02 on the LCD.
Important : Do not perform any other operations until the print head cleaning finishes. This takes about 50 seconds.
Note : After the print head cleaning finishes, print the nozzle check pattern to verify that the print head nozzles are clean.
If the problem persists, perform printhead deep cleaning.
Print Head Deep Cleaning : If print quality does not improve by standard print head cleaning, try print head deep cleaning, which is more powerful process. Print head deep cleaning consumes ink, so perforn this procedure only when necessary.
2) Start Print Head Deep cleaning.
b) Press right arrow twice to display 03 on the LCD.
Important : This process takes one or two minutes to complete so simply wait until the Power lamp stops flashing.
Note : After printhead deep cleaning finishes, print the nozzle check pattern to verify that the printhead nozzles are clean.
If the printhead is still not clean after the second deep cleaning, replace the ink tank.
If ink tank replacement does not resolve the problem, the print head may be worn out. Contact the Customer Care Center.
Hope this helps.
Please rate my response.
Thanks.
Have a good day.
Dec 07, 2009 | Canon i475 InkJet Printer
My Epson CX8400 will not print black text?
1. Press Setup
2. Select Maintenance and press OK
3. Select Nozzle Check and press OK
4. Press Start
5. Check the nozzle check pattern that prints to see if there are gaps in the lines
6. If there are no gaps, the print head is clean and you can continue printing If there are gaps or the pattern is faint, clean the print head
Oct 20, 2009 | Epson CX8400 All-In-One InkJet Printer
Faint lines on printing
Keep running the nozzle cleaning. It should eventually sort itself out. Also try aligning the print heads.
Jul 07, 2009 | Canon PIXMA MP600 all-In-One InkJet...
HP 6280 printer - the black ink is not printing
You could try removing the cartridge and carefully clean all the little connectors. You can use a screen cleaner.
Mar 19, 2009 | Office Equipment & Supplies
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
