Question about Creative Technology SBS 245 2 Speakers
My sbs 245 jack is unconnected to cpu. how do i connect it again
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 101 Answers
Plug the green jack in the green inlet at the back of your pc and there wil be music
Posted on Nov 26, 2013
Hi there ive got wharfedale lcd dvd 19" and on the t con board a ic has blown but i carnt see number
It is likely a proprietary wharfedale chip and no info will be available. you will need to purchase a board assembly or replace the device.
May 06, 2014 | Creative Technology SBS 245 2 Speakers
Win 7 drivers for creative sbs a235 speaker
creative a 235 doesnot require any computer driver. Just plug into headphone jack and enjoy. If your headphone is working in the same jack and your speakers must also work. Use a working headphone to check the problem is with laptop or speakers.
Apr 20, 2014 | Creative Labs Audio Players & Recorders
Asus m4n78 pro no starting problem
check out power supply then cpu fan is running and video card works and ram is in all the way make sure that all the power plugs are in the right places as well on the board
Mar 15, 2013 | ASUS M4N78 PRO Motherboard & AMD Athlon II...
Polarity
usuall on speakers it does'nt matter other than both must be the same. If you do connect them incorectly 1+- other -+ you will notice a loss of bass but should not domage the speakers. However are you talking about connection to a power supply?
Sep 14, 2012 | Creative Technology SBS 245 2 Speakers
A creative speaker SBS A200 connector pin was damaged. we need to connect that cable directly into the board.so we need that pin details.
Hi, I hope this helps,
Pins look like this: (Top view, not copper side)
1 2 3 4 5
6 7 8 9
1 = Thin white wire from thick white cable (Left input)
2 = Gray (Speaker out)
3 = Orange (+V return from volume unit to bass unit)
4 = Not connected
5 = Thin Red wire from thick red wire (Right input)
6 = Blue (+V power from bass unit to volume unit)
7 = Black (GND - if socket removed, solder 3 socket shield holes to each other or solder black wire directly leftmost hole)
8 = Not connected
9 = Shield copper from thick red wire
Shield copper from thick wire : Solder to GND or Left unconnected
Jun 23, 2011 | Creative Technology SBS A200 2 Speakers
I have ceative SBS 245 speakers.2 das ago i did format my pc and install win7 .i have n sond.poblem find that no audio output device is install.please help us.
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Mar 18, 2011 | Creative Technology SBS 245 2 Speakers
My spekaer doesnt work.......it is properly connected to the cpu .............speaker problem or OS problem?
check to make sure you are getting power to the speaker system and that the audio jack is plugged into the green jack on your sound card. also open up volume control and make sure its not muted and that it recognizes it. when u turn the volume up if you dont see any green movement on the bar then you have a sound driver issue. go to device manger in xp right click on my computer properties then device manager and see if there is a red or yellow mark on your sound card on vista and win 7 go to my computer then system prop, then device manager.
Mar 14, 2011 | Creative Labs SBS 370 Computer Speakers
I just got my creative sbs 5.1 70 watt speaker 2 moths before.....everything was working fine but when other day i left the speaker on for 1 night the other day i tried to play it but the power was not...
Make sure all of the speaker wiring is seated fully in each connection point on the PC and speaker components themselves. Also, try leaving all of the speakers unplugged for a short while (1-2 hours), reconnect it all, then try again.
Feb 14, 2010 | Creative Labs SBS 580 Computer Speakers
Creative Technology SBS 245 2 Speakers Logo
65 people viewed this question
Top Creative Technology Audio Players & Recorders Experts
Jim Y
Jim Y
elvis nunex
Level 1 Expert
Tom Chichester
Are you a Creative Technology Audio Player and Recorder Expert? Answer questions, earn points and help others
