Philips 42PFL5603D/F7 LCD TV Logo
Posted on May 08, 2009
Tv is 5 months old sound is good but no picture at all???????
Picture went out last friday cant fix
2 Related Answers
Anonymous
  • 99 Answers
  • Posted on Feb 20, 2011
SOURCE: My TV has gradualy developed a blurred picture
guessing this is a rear projection tv. You did not provide a model number. Check the CRT fluid to be sure it is clear and not cloudy. Since you mentioned the problem was gradual over time, I'm guessing it is the fluid. This would be more obvious if you were seeing like a frosted look to the picture or dark areas and bright areas, which are caused as the fluid clouds up.
Your alternative is to try adjusting the focus of each bulb on the focus block of the tv. I think with an older Philips the focus block is in the back of the tv.
Anonymous
  • 1779 Answers
  • Posted on Jul 01, 2009
SOURCE: After 2years and 9 months the picture went black,
Most likely, capacitors in the power supply are bulged. It is not an expensive repair.
I have a 8 years old apex tv. while watching tv the picture went out but it still has sound. i can't see the channel numbers or volue bar is it worth fixing
I WOULD SAY NO ! THE PICTURE TUBE IS PROBABLY AS MUCH AS THE TV IS WORTH. i had a very nice sony trinatron tv. the picture tube whent on it at about 5 years so I CALLED FOR REPAIR AND THE PICTURE TUBE WAS 2-300 DOLLARS. good-day !
1helpful
NO SOUND GOOD PICTURE TV IS ONLY 5 MONTHS OLD
Unplug,replug the tv back about an hour later.Go into the tv menu,go to SOUND,go down to reset it to back to factory setting.The sound now should return,not,than ur tv the Tuner board have problems,call for warrenty serviced.
1helpful
Screen went black on my plasma tv
If the menu display isn't coming up either, then the odds are the power supply for the screen is the problem. Most manufactures call this a Backlight Inverter Board. Being that it's only 7 month old, it should still be under warranty by the manufacture. I would try to get it fixed by the warranty first if possible.
2answers
8 1/2 month old TV went out.
Take it back to where you bought it if it's still under warranty, they are obliged to fix it!
1helpful
Sony Grand Wega No picture and no sound
i think its the colorwheel you heard go pop... replace it and you should be good to go
9helpful
3answers
No picture
Hav 50 inch lg no pic but got sound wtf how do i fix it an there r 5 flashes b4 green light stayes on at the start
1helpful
Picture has green tint on startup
Jar-Head, bad news, the picture tube has a mild short in the green cathode, tech can come out and try to restore it but it`s usually a futile attempt on sony tubes, sorry to be the bearer of bad news, BMW Rider
3helpful
4answers
Customer service number for Trutech
I too purchased TV on Black Friday from target in 2006 and w/in the last month the picture went..The sound works, but no picture..cust service tel #:888-252-6252..I tried to call but was on hold so long...I'm actually on hold again...If you happen to figure out what the problem is, please e-mail with resolution..TV isn't even a year old..Can't find the warrenty...
[email protected]
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
