Question about Comet BXD2527 Pressure Washer Pump
I have a MTPAXR 8/120 PUMP THAT IS seized and I
I have a Comet MTPAXR 8/120 PUMP THAT IS seized and I want to remove the pump from the motor I loosened the 4 star screws on the motor drive end but the endshield between motor and pump do not come off Is there a special method or can you help Tanks Gert Aggenbach
    President:
  • 1,489 Answers
The best tool for this job is a gearpuller -- there are many types -- get one which matches your problem.
Posted on May 08, 2009
Y a t'il un niveau d'huile dans la comet bxd 2525
L'utiliser cette pompe sans huile est une erreur fatale:
[PDF]COMET PLUNGER PUMP SERVICE MANUAL INDEX
www.cometpump.com/_images/support/Pump_Repair_Manual.pdfLUBRICATION: Make sure crankcase is filled with Comet Pump oil. Running this pump without oil will cause damage and void any warranties. Change the pump ..
Mar 14, 2014 | Comet BXD 2525 G Pressure Washer Pump
Comet water oil
You have to take off the pump head. Here is the link to the service for comet pumps.
https://www.pwmall.com/PDF/CometServiceManual.pdf
Nov 03, 2013 | Comet GXD2527G Pressure Washer Pump
Comet tw 5050 mix oil and water
what you have is a bad seal or a crack within the pump crack more common if any water was left in it during the cold winter
Jun 22, 2012 | Comet Pressure Washer Tw5050 Triplex Pump...
My spa will hum when turned on but will not push water. The motor then turns off.
The pump seized up or the motor bearings went bad and seized up...
Bottom line is that you will need to remove the pump and motor and take it apart to figure out what is causing the problem....
heatman101
Aug 29, 2011 | Whirlpool Home
On our electric pressure washer. Nolonger works. Disconnected the pump from motor. Motor spins freely. My guess is pump is bad?mike
Good guess. You can find parts at: www.pressure-washer-parts.com
They handle comet pumps. See if you can find the number on the pump. Not a bad brand of pump,but they do wear out. Never run pump dry, never let idle more than a couple of minutes, the water recirculates in pump and gets hot. Install a temp relief vavle when you rebuild.
Jun 27, 2010 | Comet GXD2527G Pressure Washer Pump
Assembly
HI your machine would have been delivered with a blanking plug in the pump. You will need to remove this and fit a vented pump or your pump will build up too much pressure inside.
Apr 13, 2010 | Comet BXD2527 Pressure Washer Pump
Comet pump will not release from gas engine. Can you help? Thanks
Sometimes you can put the bolts on the pump loose and run the machine. The vibration from the motor will work the pump loose. If you do that, remove the brass head or the pump will overheat.
Dec 01, 2009 | Comet BXD2527 Pressure Washer Pump
Committed Cardinal Sin No. 1, ran p/w w/o water. Ran for about 20 sec. and quit. Now pull start is seized. I could understand how the pump might be damaged, but why the motor?
It's not damaged...just hydraulically "locked"...my guess is the recirc valve is shot or worn enough to put is where it won't release. Just carefully start taking stuff off the pressure head...till the pressure bleeds off
Good Luck
Jun 23, 2009 | Comet GXD2527G Pressure Washer Pump
Oil for Comet pump
aftermarket oil will be fine just use same grade of oil,all manufacturers want that extra kick,
May 12, 2009 | Comet GXD2527G Pressure Washer Pump
Comet BXD2527 Pressure Washer Pump Logo
254 people viewed this question
Top Comet Garden Experts
michael
michael
Joseph Hoffmann
John Trevino
Are you a Comet Garden Expert? Answer questions, earn points and help others
