Question about Transponder
How to add a transponder to str 3650
I have cable tv but i have lost some of the channels, i have deleted all and retuned thats when i lost 3 channels. i know the configurations but not sure how to get the channels back. can you help
When I retune my tv stations how do I get them them in order. Ie BBC1 =no1 BBC 2 = no 2. Other tvs seem to do this automatically ?
There should be an option on the menu screen for the TV or if you are using one of this digital converter boxes, it will be on that menu. Look in the menu and under Channel and you should see add/delete or move option.
However, as you mentioned, usually when you run an auto-scan it is supposed to pick up what your antenna picks up and put them in order. It's especially annoying when it picks up a channel and its blank or no signal. The menu were created so you can delete those unwanted channels. Hope this helps.
Mar 15, 2015 | Televison & Video
Lost ABC channels on retune, how do I regain reception
Try manually entering the channel number. Many TV's have, besides autoscan, a way to manually add or remove channels.
(Besides, what is worth watching on ABC? (;^D)
Oct 21, 2014 | Televison & Video
Samsung lcd tv problems
TV IS OK RETUNE THE SET TUNUNG CABLE CHANALS DIGITAL AND ANALOGUE IT IS ON SET UP MANU
Sep 07, 2014 | Samsung Televison & Video
Samsung retune
Hi, Try this go to menue on tv run the channel scan function.
If you are using a PVR or Tivo do the same with that, But you will have to set your TV to channel 3 to get your PVR/Tivo going. or in some TVs TV1 or TV2...depending how you hooked it up.or if you have HDMI cable... Good luck
Feb 11, 2014 | Televison & Video
How to retrieve lost channels on digital tv
To restore missing channels, you need to retune your digital receiver (box or TV).
The retuning process runs a scan and finds all the available channels. Your box may have an Add New Channels option that you can use, but this may not pick up other changes such as channels being moved to a different multiplex or removed altogether.
How to retune
  1. Switch on your digital box and/or TV.
  2. Press Menu on the remote control.
  3. Select the Setup or Installation option.
  4. Select the 'First time installation' option (sometimes called 'Factory reset', 'Full retune' or 'Default settings').
  5. Press OK if your equipment asks if you want to delete all your channels. Don't worry, this is normal.
  6. If you are prompted for a code, try 0000 or 1234.
  7. Channels will be automatically installed. This may take a few minutes and your equipment may shut down and restart.
  8. After retuning, you will have to redo your Favourites list and other settings. If you retune a digital TV recorder, you also should reset future recordings.
Feb 27, 2012 | Toshiba Televison & Video
Lost bbc2 on 2 tv's, how can I retune the bbc2 back to my tv's.
It is very odd that 2 of your TV's lost the same channel... This smells of the signal provider (cable or satellite) removing that channel from your available programming. You may want to check with them.
Jul 18, 2011 | Televison & Video
Bbc1 bbc2 have been deleted after retune why
When TV channels are moved from one frequency to another frequency that was previously used by a different channel (sorry, but there's no simple way of saying that !) as has happened recently in th UK, some digital TVs and digiboxes struggle to sort the channel list out properly and channels can go missing as you describe.
If your equipment has the option to delete all currently stored channels (normally in the tuning menu options) then do so and then do a full re-tune.
Sometimes, this solves the problem as the equipment is no longer aware of any previous use of a frequency and just loads every channel it finds.
If this doesnt work, or your equipment doesnt have the option, then there is normally the option soemwhere in the menus to retore the item to "factory defaults/configuration". This will clear all previously stored channels and after a full re-tune your missing chanels should be there. However, any other configuration changes you previously made, e.g picture size, output type (RGB/NSCT/etc), etc will be lost and you'll need to set these again.
NB. some regions of the country have lost some channels temporarily now until after the switch over programme completes at the end of 2012. If you visit the Freeview website, this will tell you if your area is affected.
Nov 08, 2009 | Panasonic TX-28DK2 TV
Can't tune TV to channel 3 inorder to recieve digital tv
go into the menu & add that channel back on
somehow you deleted it
go to menu channel add/delete
Jan 19, 2009 | Emerson EWF2004 20" TV
Lost Remote
First you want to go press the menu button on the front of the tv. Second, choose channel set. Third, choose add/delete and manually preset each channel. You can try just adding channel 3 if you have cable. This will turn the tv back on and out of game mode...
Feb 04, 2008 | Durabrand DWT1905 TV
Transponder Logo
15 people viewed this question
Top Adaptiv Radar Detector Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an Adaptiv Radar Detector Vehicle Part and Accessory Expert? Answer questions, earn points and help others
