Question about Yamaha Pdx-30 Ipod/iphone 30w Dock Speaker System, Blue Pdx30bu
Plastic on ipod doc broken. I pod no longer charging
Hi. There are 2 plastic spokes (not sure exactly what they are called) that go into the ipod from the doc. The right plastic bit has chipped off, so the ipod no longer charges on the Yamaha. It displays a red flashing light indicating no charge is happening. I'm wondering if this can be fixed? Thanks,
  • 4 Answers
SOURCE: volume fix problem
FIX ZONE @ SOUND - STUCK ON "ZONE 2 - FIX" 1. Press "Amp" button (right side of remote - 1/3 way down) 2. Press "Menu" button (center of remote - 1/2 way down) 3. Press "TV VOL" button (green letters) until "Manual Setup" is displayed on receiver 4. Press "Enter" button (green letters) 5. Press "TV VOL" button (green letters) until "3 Option Menu" is displayed on receiver 6. Press "Enter" button (green letters) 7. Press "TV VOL" button (green letters) until "D Multi Zone" is displayed on receiver 8. Navigate from there Good Luck! This worked for me.
Posted on Aug 04, 2008
Benimur
  • 6966 Answers
SOURCE: My battery isnt getting charged on my motorbike from engine
Hi and welcome to FixYa,
Almost always, your described problem indicates a charging issue. This points to the bike's battery not charging. Suspects would be:
  • voltage regulator (most likely);
  • connectors to voltage regulator (likely). Check/clean corrosion/burnt marks;
  • stator and/or the wires coming from it (least likely).
A CDI is a capacitive discharge ignition. This is an electronic module that fires the ignition coil.
Parts would depend on where you are. Often, other riders would provide information for parts source.
Good luck and thank you for using FixYa.
Posted on Feb 25, 2009
SOURCE: Yamaha FZR 600 not charging correctly with the lights on
I HAD THE SAME ISSUE. CHECK YOUR VOLTAGE OFF O THE MAGNETO, IT SHOULD BE IN THE 25V RANGE. IF THAT CHECKS OUT OK CK THE VOLTAGE IMEDIATLY AFTER THE VOLTAGE REGULATOR, I BET IT IS BELOW 14V. THE FZR IS PRONE TO HAVING THE REGULATOR GO BAD (THE OLDER ONES HAVE NO COOLING FINS AND THEY BURN THEMSELVES UP). THE BEST ONE TO BUY IS THE NEWER VERSION FROM A 1999 FZR, IT HAS COOLING FINS WHICH GREATLY PROLONGS THE LIFE. YOU HAVE TO DO SOME SLIGHT WIRING MODS, BUT NOTHING ANYONE COULDN'T DO. SEARCH FOR FZR REGULATOR UPGRADE AND IT WILL EXPLAIN EVERYTHING! I HOPE THIS HELPS! GOOD LUCK!
Posted on Mar 22, 2009
DickCanFixIt
  • 948 Answers
SOURCE: 2001 Yamaha V Star 1100A not charging battery
If you take a look at the parts microfiche (make sure this is your bike please), the voltage regulator and rectifier is a little under $70. Labor for installing it would probably be in the $200-300 dollar range at a dealer.
Have you checked the voltage while the bike is running? It could be that the lights are simply drawing more power than the charging system can put out. Put a voltmeter on the bike and start it. Rev engine to 2-4000 rpm (or just ride the bike if you can see the meter while riding). Check with extra lights off and extra lights on. If your voltage is 14+ while riding or reving the engine without the extra lights on I think your charging system is probably OK. If it is below 13 (again, without the extra lights on) I say the charging system is bad.
Posted on Apr 10, 2009
tartantyger
  • 73 Answers
SOURCE: how do i charge battery
First, I should explain the difference between most motorcycle batteries and the car batteries that people are more familiar with.
A car battery is usually a "lead-acid" battery, a design largely unchanged, except for the composition of the lead plates, since the turn of the century. The battery is composed of alternating plates of lead and lead dioxide in an acid bath. Adding plates increases the electrical capacity, dividing groups of plates into "cells" increases the voltage available. It's a very basic battery that has worked in stationary and vehicular applications for centuries.
A motorcycle battery is usually an Absorbed Glass Mat (AGM) battery, differing from the car battery in only one respect; the space between the plates is filled by a porous, fiberglass-like material that has been saturated by acid. The advantage of the AGM battery is that it is less susceptible to damage from the increased vibration experienced in a motorcycle or high-performance car.
New motorcycle owners are frequently tempted to use the same battery charger they're accustomed to hooking up to the family sedan, but this can, and usually does, cause premature failure of the battery. Because the motorcycle battery is smaller, it requires less current to charge it, and the excess current generates heat. Because the acid does not circulate between the plates of the battery and distribute the heat and gas generated during charging, the battery heats much more rapidly than the car battery. Heat interferes with the chemical processes the battery performs during the charging cycle, and may cause plates to bend, buckle or crack.
Now, you've probably seen "battery tenders" advertised in motorcycle magazines, at Radio Shack, in Walmart and Sears. This is what you should be using - look for a MAXIMUM charge rate of 2 amperes/hour (it's typically described as "amps"), and a reduced "trickle" charge rate (usually automatic) of 1/4 to 1/2 "amp".
To get to the battery, look under the operator's seat (either side) 1"-2" behind the back of the fuel tank; you'll see a nut holding a threaded shaft into tabs protruding from the frame. Loosen and remove the nuts on both sides, lift the seat up until the threaded shafts are completely free of the tabs, then move the seat straight forward. That will free a catch, molded into the underside of the seat, from a loop in the frame that holds the back of the seat down and keeps the seat from moving side-to-side. The seat may then moved out of the way.
Now you will see the battery in the frame; hook the red lead of the battery tender to the battery terminal with a red insulated boot over it, and hook the black lead of the tender to the opposite battery terminal. The battery tender may be left connected for days, weeks or months at a time, but unless the bike is well protected from the weather, it should probably be disconnected after 16-24 hours and the seat reinstalled.
Reinstallation of the seat is the in reverse order of its' removal (above): there is a specification for the nuts - 5 ft.-lbs. (7 nm) - but it's usually sufficient to tighten the nuts snugly on both sides.
Posted on Aug 07, 2010
My ipod 16 gb is disabled for 22406918 minutes & i forgot my password
Hi mythreebrats
If you have forgotten the code, you can unlock the IPod by doing the following:
Connect your IPod to the primary computer you use it with (the first one IPod synced with), and open iTunes.
When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock IPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod.
Afterwards, you can add your music and data back to your iPod.
If you want to change the primary computer that your IPod is associated with, do this:
1. Restore your iPod. WARNING: The restore process cannot be undone.
All of your songs and files will be deleted. Always make a backup of your important data.
2. Connect your iPod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize.
If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the IPod, which will erase all music and data.
Please take time to rate me
Bud
Oct 15, 2012 | Apple iPod Nano 6th Generation MP3 Player
Bought ipod (white) 1 gig, from ebay .. will not play, will not start, just blinking lights. held play for 3 sec to get green light, still nothing, all controls only render orange and green blinking ......
Hi, problem can be solved. You need t look out for two things:
1. the battery of the i pod,
2. the memory of the i pod.
Checking the battery, the battery cell of the i pod might be too weak to power up the i pod, so you need to test with another battery before purchasing a new one. It may also need to be charged properly for longer hours before it can be able to power up the i pod.You can also check that out.
Checking the memory of the i pod. The memory of the i pod can also be the cause. Virus or corrupted applications can cause to malfunction.
After checking battery, if it does not work that means you will need to flash the i pod for the memory to be restore back to normal again.
Take care.
Apr 14, 2010 | Apple iPod nano
My kid was playing with it and now i cant unlock my screen
Hello :
Connect your iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock iPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod.
good luck .
please rate !
Mar 30, 2010 | Apple iPod nano 3rd Generation
My ipod wont stay charged
This may not be the answer you are looking for but your I pod might not be fully charged, meaning that you are not plugging it in the computer/docking system long enough.( it takes much longer than 15 minutes to charge the battery. So you might want to plug it in/dock it over night) Or you may be playing a game that uses a lot of MB/GB so it kills the battery. And make sure that you press the play/pause button down for at least five seconds before switching the little switch at the top of your I pod. If you don't press the play/pause button for five seconds and just switch the switch at the top a little lock will appear on the left corner meaning you need to hold the play/pause button down for five seconds then the i pod screen goes black at that time flick the switch at the top off. -hope it helps owner of i pod nano and I pod touch.
Dec 30, 2009 | Apple Mini IPod
No picture on television when connecting s-video outlet from JBL radial and showing a film or pictures on a docked i-pod touch.
Hi, I have this problem and when I spoke to JBL techical support they told me that Apple have changed their software on the New Nano and the ipod touch and of course the iphone and regrettably the radial does not support S video for these products. I'm told it will work with first generation ipod classics. PS: i had to carefully cut off some of the plastic plug to make sure the connection goes all the way into the back of the radial
Dec 27, 2009 | JBL Radial Speaker Dock Docking Station...
How long should I charge my ipod A1137
iPods usually charge within 2-4 hrs. If yours is taking longer or not charging at all the battery needs to be replaced.
Nov 28, 2009 | Apple iPod nano
I Pod 4 Gb
Just charge the battery until the indicator says the battery is full.
well since its been connected for more than enought, disconnect it, you can also try reseting the ipod incase it has frozen
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Tip:
  • If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
  • If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
May 18, 2008 | Apple iPod nano
Ipod shuffel
Here are the tips to follow :
Charging your iPod battery
http://docs.info.apple.com/article.html?artnum=61127
Using the iPod Hold switch to prolong battery life
http://docs.info.apple.com/article.html?artnum=60951
iPod battery faqs
http://docs.info.apple.com/article.html?artnum=62018
Accurately determine your iPod battery life
http://support.apple.com/kb/HT1322
Tips and tricks for ipod battery
http://docs.info.apple.com/article.html?artnum=61434
If everything is fine then its time to replace the battery
Good Luck.
Live, Love, Laugh.
May 09, 2008 | Apple iPod shuffle MP3 Player
Won't sync
Beware....I have the same model bought off ebay and its a fake! The seller had a few to sell and now that people are getting them and opening them, many are posting negative feedback. Good Luck!
Oct 10, 2007 | Apple iPod nano
Yamaha Pdx-30 Ipod/iphone 30w Dock Speaker System, Blue Pdx30bu Logo
73 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
