How To Replace Memory - Computers & Internet
    Top Expert:
  • 12,223 Answers
You must opent the case from your PC, turn OFF , disconnect the power cord too. 2) proceed to see the MEMORY RAM BOAD, and take out with very care, and replace it or add, and then proceed in the reverse steps.
God bless you
Posted on Nov 26, 2013
What causes an acer aspire e14 gives memory error messages on start up
Try this solution... Step 1 - Remove the battery
  1. Slide and hold the battery release latch to the unlock position.
  2. Use your finger to lift the battery up and out.
Step 2 - Remove the memory module
  1. Locate the memory module cover on the bottom of the notebook.
  2. Remove the screw that covers the memory module.
  3. Use your finger or a flat head screw driver to lift the inside edge of the memory module and remove it.
  4. Push both tabs outward simultaneously to release the memory module.
  5. Grasp the memory module by the edges and pull gently to remove it.
  6. Align the keyed (notched) edge of the memory module with the keyed area in the expansion slot. Insert the memory module into the slot at a 45-degree angle until it is seated.
  7. Push the front edge of the memory module down until the retention clips snap into place.
  8. After reseating the memory module, replace the memory expansion cover and then replace the screw.
Step 3 - Replace the battery
  1. Insert the battery into the notebook.
  2. Push the battery into the base enclosure until you hear a click.
  3. Connect the AC adapter and turn on the notebook.
Sep 05, 2014 | Computers & Internet
Tip
Resetting the bios password for Toshiba Laptop
It working with the Satellite A135
Power unit off. Disconnect AC power. Remove battery. Remove the memory cover screw, memory cover and the memory modules. Peel back the black lebel back from memory module 1, I soldered PAD500 solder pads (to short circuit them), install one memory memory in slot 2 and turned notebook on, it erase the password and boot without asking for one. Then power off desolder PAD500, replace mylar. Replace memory modules. Replace battery. Power up unit, replace memory cover and screw. Whalá!! the password gone, and you can enter to bios setup to set a new password if you want.
on Mar 15, 2008 | Toshiba Satellite A135-S2276 Notebook
Laptop beeps 7 times
Try link: http://blog.parts-people.com/2014/06/27/dell-inspiron-m501r-m5010-beep-codes-diagnostic-indicators-2/ How to identify beep codes: When a laptop or computer first powers on, it goes through an initial set of diagnostic tests to make sure vital components are preforming correctly. These tests are called POST or Power On Self Test. When a test fails, the user is notified via POST codes, Light codes, or Beep codes. For diagnosing Beep codes you need to:
  • Power on the laptop or restart it if it is already on.
  • Listen to the number of consecutive beeps when the computer begins to boot. Restarting the laptop may be necessary and should not harm the laptop at this time.
Dell Inspiron M501R (M5010) Beep Codes # of Beeps Description Possible Cause(s) 1 BIOS ROM checksum in progress or failure System board failure, covers BIOS corruption or ROM errors. 2 No Memory (RAM) detected Memory or Memory slot failure 3
  • chipset Error (North and South bridge error, DMA/IMR/Timer error)
  • Time-Of-Day Clock test failure
  • Gate A20 failure
  • Super I/O chip failure
  • Keyboard controller test failure
System board failure 4 Memory read / write failure Memory failure 5 Real Time Clock (RTC) power fail CMOS battery failure 6 Video BIOS test failure Video subsystem failure 7 CPU Cache test failure Processor failure or motherboard failure 8 LCD LCD failure Most Common Fixes:
  • 1 Beep: Replace the motherboard / system board.
  • 2 Beeps: Reseat the memory or replace the memory.
  • 3 Beeps: Replace the motherboard / system board.
  • 4 Beeps: Reseat the memory or replace the memory.
  • 5 Beeps: Replace the CMOS battery.
  • 6 Beeps: Reseat or replace the video card or replace the motherboard / system board.
  • 7 Beeps: Reseat or replace the CPU or replace the motherboard.
  • 8 Beeps: Reseat the LCD cable or replace the LCD screen.
Jul 21, 2014 | Dell Inspiron M501r Laptop Computer (AMD...
Hello I have a problem with the work printer. It is a 3500 hp color laser jet and it is having a 10.10.00 supply memory error. I'm not sure what to do. Can you please help me?
10.10.00 SUPPLY MEMORY ERROR
Missing memory on supply
Black print cartridge
1. Open and close the front door.
2. Ensure the cartridges are fully seated.
3. Swap the cartridge for the color indicated with a cartridge in another slot to determine whether the error follows the cartridge or stays with the slot. If the error follows the cartridge, replace that cartridge, otherwise, continue with step 4.
4. Check the memory controller PCB contacts to the memory tag. Clean if dirty.
5. Reseat the memory controller PCB connector J201 and DC controller PCB connector J1025.
6. Defective memory controller PCB, replace the memory controller PCB.
7. Defective DC controller PCB, replace the DC controller PCB
Aug 25, 2011 | HP Color LaserJet 3500 Printer
My hp 5750 beeps 4 times what seems to be the problem??? thank u
This means that your memory is bad or not installed correctly. Open your pc up and remove all memory from the mother board, then dust it, place the memory back in and it should work. If you still have this problem, leave only 1 memory stick in and try starting up your pc, if your pc starts up then the other memory stick is bad and you will need to replace it, if your pc still does not start, remove the 1st memory stick and put the 2nd memory stick in its place and try booting once again. If this still does not fix it, then the memory slots might be bad, try putting the memory sticks in different memory slots and each time try booting your pc. If this does not work, try buying new ram, worst case scenario you will have to replace the motherboard. Or just replace the computer if both memory slots are bad on the motherboard, and i mean IF. Good luck!
Sep 02, 2010 | Computers & Internet
Memory card isshowing corrupt
That means that memory card is faulty and you must replace the memory card.
Test the memory card on a computer using a card reader and test a different card inside the phone.
If the phone returns same error with all memory cards, then the phone memory card slot is faulty, otherwise just replace memory card.
Jul 11, 2009 | Nokia N70 Cellular Phone
Need a password...
Found these instructions on another website...
Power unit off. Disconnect AC power. Remove battery. Remove the memory cover screw, memory cover and the memory modules. Peel back mylar from JOPEN1 solder pad. Short JOPEN1 solder pads for 30 seconds. Replace mylar. Replace memory modules. Replace battery. Power up unit. If all is well, replace memory cover and screw.
Hope this helps
Regards
Aug 18, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba satellite 310 series (china)
Aug 16, 2008 | Toshiba Satellite A135-S2276 Notebook
HAVE A TOSHIBA SATELLITE A135-S4677 NOTEBOOK AND HAVE FORGOTTEN MY HDD1 INNER BIOS PASSWORD & NEED TO RESET IT IF POSSIBLE.
This works only for some models.
Power unit off. Disconnect AC power. Remove battery. Remove the memory cover screw, memory cover and the memory modules. Peel back the mylar. there should be a set of solder pads labeled JOPEN1. Short the JOPEN1 solder pads for 30 seconds. Replace mylar. Replace memory modules. Replace battery. Power up unit. If all is well, replace memory cover and screw. Hope this helps.
Feb 29, 2008 | Computers & Internet
Help please!
Feb 22, 2008 | Toshiba Satellite A135-S2276 Notebook
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
