Question about Refrigerators
FREEZER FROSTING AND NOT LETTING FRIG. COOLING
Freezer is frosting and not letting cooling in the refrigrator
  • Victor
    Victor May 11, 2010
    Hi, There are three parts to the slef defrosting cycle. With a model #, I could help you locate each part and help you on testing each part.
    Vic
  • 544 Answers
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Posted on May 08, 2009
Freezer goes through a cycle and get warm. The ice will start melting and create a mess when the freezer start to cool agian. Temperture in frig and freezer does not hold cool.
Unplug, empty, clean and let set for 24 hours to defrost the cooling coil that is froze solid overwhelming the heater and not letting it work. if the air can't circulate it will not cool. Check door gasket, or tell kids to stop holding the door open as this will cause it to frost up and cause the problem you're having.. Trust me, It works.
Jun 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The refrigrator does not get cold or freeze
Check at the back of your freezer panel for excess icing / frosting this will affet proper cooling - if so, then you have a defrost problem - have it serviced - if no excess frosting and defrosting normally, and freezer is normal, then you might have a damper problem, not opening wide enough . have them check your control boards, defrost timer, and damper (if any)
Sep 18, 2009 | Kenmore 50522 / 50524 Side by Side...
Neither freezer or frig is cooling properly. The
yes you have a defrost problem.. whirlpoolpartssurplus.com free tech advice i can simply walk you threw the process i recommend you do not defrost intill you find the problem
Jun 24, 2009 | Jenn-Air JCD2389G Side by Side...
Freezer is "frosting over...refrig part not cooling????
it sounds like the defrost system is not operating and getting rid of the frost. the common fault is that the defrost heater has gone, or the heater cut out has gone or the defrost timer is faulty. how is the door seal in the area- that can cause frosting with warm air ingress.
Mar 16, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Refrigerator not cooling properly
need more info,is the freezer frosting up?is the freezer fan running?is it cold in the freezer at all?let me know more-mike
Oct 14, 2008 | Kenmore Refrigerators
Frig won't cool, freezer works fine
Defrost unit completely. You're frosting up. Then, avoid leaving the door open, leaving liquids and food uncovered. Clean condenser coils. If it happens again, you need refrigerant.
Jun 09, 2008 | Refrigerators
Frig not cooling and now freezer is frosting
Val sounds like a defrost problem..go ahead and defrost your freezer again... check your evaporator drain your fan motors let let me know and I can help you Krazytech
Mar 27, 2008 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
112 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
