Question about Xerox Phaser 3100MFP
Printer not printing show receiving file - Xerox Phaser 3100MFP
Have messed up my communications with both printers somehow-happened after upgrading Norton--they wont help.
delete the printers, then click start and type regedit in the search box. when the registry comes up click edit and select find. type in the model of the printer in the search box. delete any key that comes up. use "find next" in order to get all instances of the printer model. reinstall the printer and you should be good
Oct 14, 2014 | HP Touchsmart 300-1003 Amd Athlon Ii X2...
Processes but won't print
Sometimes a plotter will show that is receiving data from the computer but will not print. I assume this is what you are describing. This can be caused by a couple of things. The first suspect is a corrupt file. Try a smaller file to see if it will print. If it does, the problematic files are probably from Photoshop or a CAD program. If a file has more than one level when it is sent to the plotter, the plotter has a hard time digesting it. Try "flattening" the file (makes a single level) and then send it to the plotter.
Another possibility is that the printer driver is no longer matched to the computer operating system or is simply corrupt. Go to HP.com and get the latest driver for the plotter. Windows XP Pro 64 drivers work well with W7 and 8.
Lastly, the Jetdirect card could be faulty. Reseat or replace the card.
Jul 09, 2014 | HP DesignJet 1050c plus InkJet Printer
Printer is showing the message Receiving Data: Please Wait and not in function from 15min.
Does the job finally print? I had a few customer files that took 45minutes to rip.
Feb 25, 2011 | Xerox DocuColor 12 Printer
When print a file, the printer screen show ''Data Received'', So I can not print anything
the printer is missing something. Check if there is paper. also check to make sure you printed the right size paper. If you printed 8.5 x 11 sheet make sure that paper is in your tray or if you printed a different size make sure that paper is there. Than if all is good just restart your compouter and printer and it should be fine.
Jul 16, 2010 | HP LaserJet 5200 Printer
I have riffile my smasung ml-1640 printer cartage three time then it show red light but printer works ok, after 2100 pages printed its not working properly, when i give command to print any file no error...
By deepak_compu on Oct 06, 2009
i have riffile my smasung ml-1640 printer cartage three time then it show red light but printer works ok, after 2100 pages printed its not working properly, when i give command to print any file no error show,but print not come. and when i print a test page from printer button it gives print. but on paper write like this toner exhoasted so what i do for this problem please give me soltuion of this problem
Oct 06, 2009 | Samsung ML-1640 Monochrome Laser Printer
Lexmark Optra 1275sc - 900 Service - Software Error
I have the same problem, but the error only occurs when I try to print a .pdf file (Adobe Reader) using the "Lexmark Optra SC 1275 PS" driver. For some reason the PS driver didn't like .pdf files! My solution was to always print .pdf files using the alternative " Lexmark Optra SC 1275 (MS)" driver, which Lexmark also offers on its website.
Apr 01, 2009 | Lexmark Optra SC 1275 Laser Printer
My Inkjet 2800 won't print DWG. (CAD) files. I have no problem with other files; word, excel, photos ... When I try a CAD file, the printer shows "printer error."
Does the printer show you Printer error with number and letters following it? Prior to printing, check the 'print preview' to see how the layout of the printing is showing. If the CAD drawing is not adjusted to fit on the paper in the printer, you may from time to time get a printer error.
Feb 03, 2009 | Computers & Internet
Posted by rhung33 on Jan 16, 2009 Under Window DOS prompt and Unix Sun Solaris 8 Station , using LPR -p command to print txt file to cause Lexmark T644 printer '' Flushing buffer '' and...
The printer can't handle the data it received and flush it out of its buffer. Goto Menu->Settings->Postscript Settings and turn "Print PostScript Erro" on. When the same print job prints, you should get a page printed out telling you what the printer doesn't like. You may also want to try forcing the printer into Postscript mode. Your PS file probably contains a PJL to set the device to PS mode before it prints. When the printer expects PCL data and received PS data(or vise versa), you can get this behaviour
Jan 16, 2009 | Lexmark T644 Laser Printer
Printer
try printing a test page. Make sure you have the right driver for your printer. Make sure all connection are secure and tight.
Mar 27, 2008 | Compaq Inkjet IJ650 Printer
Computers & Internet Logo
24 people viewed this question
Top Xerox Computers & Internet Experts
Jack McCann
Jack McCann
steve morris
steve morris
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
