Question about Canon PIXMA MP150 All-In-One InkJet Printer
Mp 150 scanner only scans 1 page, then says buffer is full ...
Since I can't find the buffer, I can't empty it ...
Ria
  • ria1simons May 13, 2009
    Hi, when I go to MP navigator, I only have the choice between "scan photo/document" and "open existing data", I don't find the SCAN/IMPORT nor OPEN SCANNER DRIVE ...
    looking forward to hearing from you,
    kind regards
    Ria
  • 67 Answers
Power up printer ,then Press&hold(STOP/RESET)button for 5 sec. Then restart printer.
Go to MP NAVIGATOR.Select SCAN/IMPORT,>OPEN SCANNER DRIVE>ADVANCE MODE>SIMPLE MODE.>select OK.I think it fix your problem.
Posted on May 13, 2009
  • Debajyoti Biswas
    Debajyoti Biswas May 13, 2009
    Hi Ria,
    at first you uninstall Canon MP NAVIGATOR & reinstall it. Then SCAN . I think it'l work.
    Inform me what happen.
    -Dev
Hi, I scan documents (recto and recto-verso) using the InformatikScan software and the scanner Canon DR-9080C. When I scan for ex. 30 pages, after 10 pages the scanning process slows down in...
The scanner creates a Raster Image and if it is grey or color, the size is big. After a few images are scanned, the 'buffer' inside the scanner is full. It may take more time to process the scanned image by the scanner if it is 24 bit color. The image is sent to the computer Harddisk and if the disk is full or if it had not been defragged for a long time, the sectors may not be contiguous for speedy writing, This will slow up the scanning. Ensure the disk has large space. 'Scan ahead' slows down scanning speed. (Without scan ahead, the next page is fed only after processing, whereas when selected, just after the previous page is scanned, the scanner start the next one)
S. Mohan, India, Chennai
Jul 04, 2011 | Canon DR-9080C Path-Through Scanner
My Cannon Pixma MP500 multi-function printer randomly scans only part of the document on the glass. Sometimes it does get it right; that is it correctly scans the whole page, but very often, the scan...
Try to adjust the scanner resolution
Solution: Adjusting Output (Scan) Resolution (Windows) - MP150 / MP170 / MP450 / MP500 / MP800 / MP950
Adjusting Output (Scan) Resolution By changing the resolution, you can set how clear the image is going to be.
The higher the resolution, the clearer (but the larger) the scanned image is.
The resolution can be changed before scanning. (Note)
If the resolution is doubled, the image data will be quadrupled.
If the data is large, problems such as slow processing speed or lack of memory may occur.
To change standard scan settings using MP Navigator, click here
To change more advanced scan settings using the scanner driver, click here
Using MP Navigator
  1. Place the document face-down on the platen glass.
  2. Launch MP Navigator.
    1. On the Windows desktop, double-click the 'MP Navigator 2.0' icon.
    2. Alternatively, in the Windows taskbar, click 'Start', click '(All) Programs', 'Canon Utilities', 'MP Navigator 2.0' folder, then 'MP Navigator 2.0' icon.
  3. Click 'Scan Photo/Document'.
    Display varies according to the printer model.
  4. When the Scan Photo/Document window is displayed, click 'Specify'.
  5. When the Scan Settings window is displayed, select the resolution in Scanning Resolution drop-down.
    Select from the following scanning resolutions:
    [Text(OCR)]: 300/400/600
    Other: 75/100/150/200/300/400/600
  6. If necessary, set other items as well.
  7. Click 'OK'.
  8. In the Scan Photo/Document window, click 'Scan' to start scanning.
Using the scanner driver
  1. Launch MP Navigator.
  2. Click 'Scan with Scanner Driver'.
  3. Change the resolution.
    According to your purpose, set the resolution in Simple Mode with ease, or in Advanced Mode with a detailed setting.
    To set the resolution in Simple Mode:
    (A) Select the 'Simple Mode' tab.
    (B) In Destination drop-down, select the resolution which suits the purpose.
    To set the resolution in Advanced Mode:
    (A) Select the 'Advanced Mode' tab.
    (B) In Output Resolution drop-down, select one of the preset resolutions, or enter a number from 25 to 19200 to specify your favorite resolution.
  4. In either Simple or Advanced Modes, select other settings as required and then click 'Scan' to start scanning.
Aug 13, 2008 | Canon Office Equipment & Supplies
IT WILL SCAN FAST AFTER 10 PAGES IT WILL RUN SLOW
Your disk must be full or you need to do a 'defrag' on the volume where you are storing the data. Initially it is stored in the buffer and when the disk writing is slow, scanning speed is affected. Clean the disk for faster scanning.
S. Mohan, Chennai, India
Mar 23, 2010 | Canon DR-9080C Path-Through Scanner
Canon DR-7580 will scan first 12-14 pages rapidly then pauses, scans a page, pauses, scans a page... I have the exact same scanner hooked to another pc that is exactly the same.. and it flies through the...
Your hard disk must be almost full. Direct the scanning software to send data to a hard Disk location where you have enough space.
S. Mohan, India
Feb 01, 2010 | Canon DR-7580
CANON MX 320 SCANNER PROBLEM
You need to control the scanner thru your PC with canon software that came with your scanner otherwise you cant scan anything..first open the printer/scanner software ,select scanner,then place your document and command "scan" on your PC..thats it..
Jan 05, 2010 | Canon PIXMA MX310 All-In-One Printer
I want to scan documents with my Pixma MP 150
Scanning using the Operation Panel 1. Place the document face-down on the platen glass.
2. Press the [Scan] button on the machine.
MP Navigator starts on the connected computer. You can scan in documents placed on the platen glass using MP Navigator.
Oct 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Ricoh MP4000B
hi
a rijas working in dubai
my Gestetner MP 4000B nw its showing waste toner bottil is full please advice me how to solve dis problem
Feb 18, 2009 | Office Equipment & Supplies
Scanning with Canon Pixma MP450
I just did it then! With help from solution posted Feb 08 leave the acual scanner alone can be done from the computer. Steps:
1. Go to - start - control panel - printers & hardware - scanners.
2. Once inside the scanners folder just click once on the scanner icon (mine is called WIA Canon) so it is highlighted.
3. Then click on the toolbar 'File' > 'scan', then select the correct program from the list (mine was MP Navigator 2).
4. Use the MP Navigator program to select "scan photo/document", follow the instructions. At the bottom if the window that is open you can change the document type to PHOTO or DOCUMENT!
This is where the problem lies it is scanning the document as a photo which is why it is coming out as multiple documents.
Feb 06, 2008 | Office Equipment & Supplies
PIXMA 150 PRINTER AND SCANNER
Update Drivers http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=116&modelid=12764#DownloadDetailAct
What Scanner software are you using?
Was it created to work with Vista?
Otherwise you could purchase, new scanner software such as Nuance ScanSoft OmniPage 16, right now you can get it with Paperport 11 added in for FREE.
Nov 26, 2007 | Computers & Internet
Scanner to Pc File Size and Volume Problems
Hello We have been having this same problem when scanning Black and White as well. We have just played around and have changed one of our settings that has seemed to solved the problem for now. Try Properties (on scan settings) then more then click on - Detect Page Size - Image Width instead of Guide Plates Hope this works for you to
Jan 18, 2007 | Canon DR-9080C Path-Through Scanner
Canon PIXMA MP150 All-In-One InkJet Printer Logo
115 people viewed this question
old marine
old marine
