Question about Tally T5023 Plus Matrix Printer
Interface at tally 5023+ - Tally T5023 Plus Matrix Printer
Error message setup to address the power of the printer
If there is a message on LCD display to "SET THE ADDRESS" the printer will be fitted with a CO AX/Twin Ax Interface
Press CLEAR to CLEAR the error, then enter the menus on the printer and set an address for the Co-Ax/Twin Ax interface, if you are using this the address would need to match the system set up.
If you are not using Co-Ax/Twin Ax set a random address to clear the error.
Perhaps consider removing the interface if you are not using it
Feb 19, 2013 | Tally Line Matrix T6100 Printer
Offline status
The most likely cause for this OFFLINE status on the PC is which interface is selected on the printer.
I think the printer defaults to Serial interface, so if you are using USB ensure you select the USB interface via the control panel on the printer, similarly if the connection is parallel ensure the parallel interface is selected.
If the connection is serial, ensure the cable is of the correct pin configuration and ensure the serial interface is set up correctly.
May 25, 2012 | TallyGenicom Tally 5040 Passbook Matrix...
Tally mt661 printer gives data overrun error after printing a page or two, how do i solve the problem?
The Data Overrun error is normaly associated with the incorrect serial interface settings on the pritner or the serial cable may have the wrong pin configuration or be damaged in someway.
I would recomend checking the serail interface settings including the follwoing settings; Parity, Protocol, start bits and stop bits
Feb 09, 2010 | Tally MT661 Printer
Our 5040 tally printer is not being detected by a computer running on Xp and we have tried both parallel and usb cables.
I would guess that the printer is set to use the Serial Interface. I think this is the default interface setting on the 5040, hence the USB and parallel interface will be disabled.
You can change which interface is active from within the printer menu, once you have enabled the USB interface the PC should then detect the printer when you plug it in.
Details on entering the Menu on the 5040 can be found on the Dascom web site; http://dascom.firma.cc/support2/technical_notes/serial_matrix/5040/5040_tn004.htm
Oct 08, 2009 | TallyGenicom Tally 5040 Passbook Matrix...
Tally t2133 by hp print server
Access the the JetDirect settings, this is normally done by accessing a web page on the print server (enter the IP address of the print server in a web browser) Locate the Parallel Interface settings for the print server and set the following type of options; Speed of Connection- Set to the lowest available Bi-Directional Communication- Disable this you may need to select a standard parallel intrface type
Oct 07, 2009 | Tally Computers & Internet
My Acer 5100-5023 will not power on with power the
Your ac adapter maybe producing to low voltage.It may be having a hardware conflict such as a bad video card,a Hdd thats seizing,bad CPU,or even a heat effected motherboard.Excessive heat being the cause of most of the above problems.
Jul 28, 2009 | Computers & Internet
Tally9's features
Tally uses the latest technology to provide features in a simplified manner. It is a robust system that is easy to use.
Multilingual Business Accounting and Inventory Management Features
  • Multilingual Support: Tally can now be used concurrently in the language of your choice. Tally's interface is now available in Bahasa Melayu besides English and the Indic languages Hindi, Kannada, Bengali, Gujarati, Marathi, Tamil, Punjabi, Telugu, Malayalam and Hinglish (colloquial)
  • Payroll: Payroll in Tally enables users to set up and implement simple to complex salary structures. You can align and automate payroll processes and directly integrate them with main stream accounting applications. Tally Payroll also supports configurable formats for payslip printing; flexible salary/wage, attendance, leave and overtime registers; gratuity and expat reports
  • FBT (Fringe benefit tax): FBT in Tally is a one time, easy to enable configuration. It supports Challan management and printing for prompt and accurate filing of tax. On entering the transactions, Tally automatically calculates the FBT and generates the reports
  • VAT Composition Returns: VAT Composition Returns in Tally provides fast and error-free voucher entry with complete tracking of each transaction. It supports the printing of VAT Composition Returns of any state in which VAT has been implemented. The Composition Rate of VAT is automatically recognised based upon turnover and the tax payable is calculated automatically and shown in the Return Form
  • Excise for Dealers: Excise for Dealers in Tally generates Excise Invoices for Traders, Tracks Purchase Invoices during sales and duty credit availed and passed on. It also maintains the Excise Stock Register and generates Quarterly Returns
  • TDS (Tax Deducted at Source): Tally allows you to configure TDS ledgers by specifying the Nature of Payment and Assessee Types, along with the Rate of TDS. It determines user-defined expense/payment types with user-defined rates. TDS can be deducted automatically based on pre-defined rates, once the transactions exceed the threshold limit. You can generate Challans, the Form-16A Certificate as well as the quarterly and annual returns. Tally also generates e-TDS files in NSDL compatible formats
  • Synchronization: Synchronization in Tally helps you transfer data between two or more locations (Example: When a Branch Office and the Head Office of a company reside in two different locations). Synchronization can be done, both ways (For Example: You can transfer the data from Branch Office to Head Office or vice-versa).
  • E-mail reports and documents directly from Tally
  • Publish reports in HTML on Web or Intranet and share them with suppliers, customers or your own staff
  • Direct web browsing capability from within Tally that avoids switching between programs
  • Exchange data with other systems using XML. Tally gives you the means to collaborate with others and share information like never before
  • ODBC connectivity opens up Tally. This makes Tally fields in ODBC to be compliant with programs like MS Word and MS Excel. This enables you to integrate Tally data dynamically into other ODBC systems. It even designs a form like remittance advice and imbed fields like Customer name and address, account balances and so on, in Excel/word
Jul 11, 2009 | Tally Intelliprint ML450 Laser Printer
Data overrun
I would hazard a guess that the printer is connected via the serial interface.....
If this is the case you either have a problem with you serial interface settings or the serial cable pin configuration does not match the printers serial interface pin configuration..
I would recommend printing a MENU print on the MT661 and check the serial interface settings these NEED TO MATCH THE HOST SYSTEM
To print a menu print.
  • Put the printer OFFLINE
  • Press MODE
  • Press the DOWN ARROW to HELP
  • Press ENTER
A menu print will be printed look for things like Protocol, Baud Rate, Data Bits, Stop Bits etc
These need to be set to match the host computer system.
Jul 07, 2009 | Tally T2250 Matrix Printer
Service manual
Pls help me I have a lot of printing work to be done be4 tomorrow
I have Tally 6125 printer that I use to print bills for the community about 30 000
Copies a week just yesterday that is start to print these things when ever you give any print command
Main CPU Software: PSI 21 2.2d
Ctrl CPU Software: Control E3.12
Interface : serial Parallel
The Tally Printer can print can print this messages in 1 min without a spot
Pls want can I do to stop this
Dec 13, 2007 | Tally Office Equipment & Supplies
Tally T5023 Plus Matrix Printer Logo
23 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
