Question about Gale 3070W Subwoofer
Gale 3070 sub woofer staying in stand by - Gale 3070W Subwoofer
3 Suggested Answers
rulds2008
  • 3866 Answers
SOURCE: what is a suitable gale gold woofer replacement?
Really does not matter the point is you can rebuild the woofer for less then replacing with a new one but to each his own on this. But as long as its the same size anything would do for this monitor speaker.
I do not mean to sound generic but its true a woofer is a woofer it is what it is sure there are brands out there but they all work basically the same.
All your doing is buying the name.
Thanks please do click the thumbs above to give me a postive rating for my efforts today,
Posted on Feb 13, 2010
Testimonial: "thanks for your help."
  • 19 Answers
SOURCE: I have a gale 3070 sub woofer. When I connect it to the power with no audio connection being made, the inner fuses blow. can anybody help
if a fuse keeps on blowing there is a problem with the amp, Take it in to be repaired, Or just get a different one, It will probally cost you less just to get a different one,
Posted on Dec 03, 2012
Nov 29, 2012 | Gale Audio Players & Recorders
What is a sub woofer pre-out ?
Sub-Woofer pre out is for connecting that terminal to the input terminal of any sub-woofer. The sub woofer which it should be connected must be an active type [that is, there must be independent amplifier section built it with that sub-woofer; not mearly a crossover network].
Oct 22, 2012 | Denon RC-920
My amplifier for gale 3090subwoofergot damaged, the speaker and the box still intact. I need replacement
It will be very difficult get the exact replacement for the subwoofer you have. If you sech in the internet you will get lot of subwoofer modules. Buy one which will fit in the dimension of the existing amp module..
Check the link for sub woofer modules
Subwoofer module
This module will be perfect for you if the dimentions are correct. If not then you have to do some cuts on the box to suit the same.
Module
Mar 31, 2012 | Audio Players & Recorders
I have a active sub woofer (akari bazooka) but the only connections available are the speaker connections. The front of the sub woofer has volume adjustment. How can I connect this sub woofer to my Harman...
hi,
You can't connect the pre out of your AVR to this sub woofer. Do one thing connect the frond left/ right channel speaker "B" out of harman kardon to the sub woofers left right speaker in put. you can connect the speaker out "A" to your normal left right speakers. Remember to switch Speaker "A" and "B" in ON position in your AVR. Also do one thing go to the speaker setup of AVR and switch OFF (slelect NONE) the sub woofer.This will disconnect the sub woofer pre our and the sub frequency will mix with frond left right channels.
ok
May 20, 2011 | Harman Kardon AVR 135 Receiver
What is a suitable gale gold woofer replacement?
Feb 13, 2010 | Gale Gold Monitor Speaker
My gale 3080 sub has a bad mains hum
Check that it properly grounded so that you don't have "ground loop hum" and that you have no power cords crossing other connections.
Oct 12, 2009 | Gale 3080W Subwoofer
Sub woofer 15 inch
Dont want it to grid that is bad." need a rebuld!" did you know that a speaker can turn by warping over timemaking the sub grind as it goes up and down.Should repair it asap, before it gets to a point where you have to just part with it because it is not fixable
Feb 25, 2009 | Car Audio & Video
Connection of a subwoofer to Yamaha ZX-V490
Get a powered sub-woofer that has speaker level inputs, then run your front speaker wires into the sub-woofers speaker level input and then run a set of speaker wires from the sub-woofers speaker wire output to your front speakers. This is a common way to use a sub-woofer with a receiver that doesn't have a sub-woofer output.
Most powered sub-woofers have these connections, just check it out first before you buy one. They look like speaker jacks on the back of the receiver.
Let me know if you have any other questions.
Jan 02, 2009 | Audio Players & Recorders
No Power - LED not lit.
Open up the back of your gale 3080 and check the 2 fuses situated near the transformer.They look like 2 silver cylindrical shapes.Check that they have not blown if they have the will cost you around £2 to replace.Better than the 50 quid you will pay when you take it to your hi fi dealer to open up the back of it.
Aug 12, 2006 | Mordaunt Short 309W Subwoofer
Gale 3070W Subwoofer Logo
19 people viewed this question
Top Gale Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Gale Audio Player and Recorder Expert? Answer questions, earn points and help others
