The problem was the Landery was not warm enough when the wash step finish because this the program not finish . and sensor of balanse change to be disableThe problem was the Landery was not warm enough when the wash step finish because this the program not finish . and sensor of balanse change to be disable
You can't post conmments that contain an email address.
It means you have a computerized machine that only a tech with diagnostic equipment can fix. (Even knowing what the code means doesn't necessarily mean you can know what to fix).
unplugging the appliance for 10-15 minutes should automatically release the door unless the appliance is still full of water. If it is then this needs to be drained out manually by lowering the waste hose into a bucket until the water level is below the door seal
1. Rotate the wheel one to the right (cotton)
2. hold "eco perfect" down while rotating the wheel one more time to the right.
3. Now press on the watch until the display says 0
4. Turn the wheel one more time to the right and do the same thing
Try this procedure to deactivate child lock on your washing machine:---
On Siemens washing machine to deactivate child lock set program to Easy-Care and hold option down arrow for 5 seconds.---------------- set mode to rinse & then hold option down arrow for 5 seconds (toggles on/off).-----------------Set the mode to cottons, (dial clockwise once) -Press and hold the option down touch button for 5 seconds or until you see the magic message 'Child lock released'.-----------Check out.This will help.Thanks.Helpmech.
