Question about Home
My creda 950dl is running cold water and the overheat light stays on
2 Suggested Answers
packrat1948
  • 528 Answers
SOURCE: i have a creda 550c
Go through this link below and it should get it going for you.
http://www.creda-showers.co.uk/clientfiles/File/Manual%20downloads/Creda%20550C%20handbook.pdf
Posted on Feb 09, 2011
I have a DeLonghi DNC65 dessicant dehumidifier about 4years ol. It runs for about 2-3minutes then the alarm light comes on and then it switches off. It is operating in a room which is 15 deg. C. Is this...
Ignore the first comment, Desiccant dehumidifiers do not have Freon, or a compressor...
The warning light coming on after a few minutes could be one of a few things (but probably most likely due to overheating or the detection of something not right in the unit operation. Most likely faults include:
1) failure of main fan motor (this would cause eventual overheat)
2) failure of heater blower motor (this would cause an overheat)
3) clogged desiccant wheel (restricting air flow and causing overheat)
Generally the warning lights only come on if an overheat occurs, If the heater has failed these units usually continue to run, albeit cold, and with no water being extracted.
Another culprit could be the water level cut of switch being faulty.
Feb 05, 2014 | Dehumidifiers
Overheat light won't turn off, strange boiling sound.
it may have calcium build up in the valving.. may need to run some chemical thru it..
Jan 25, 2014 | Home
Can my creda excel 1200 be converted to fill with hot water instead of cold water
Unfortunately it will need cold water for the rinses. Also it controls the temperature of the (hot) water itself which it would not be able to do if fed with water that was too hot- for delicates for instance ;-0(
To use your hot water would require a hot AND cold fill washer, sorry!
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 09, 2011 | Creda Washing Machines
Why does my creda shower say overheat when i turn it on
This could be caused by reduced flow through the shower. Make sure that the shower head is not blacked with Scale, and that your water pressure is not running lower than usual.
Jul 16, 2010 | Home
We have a second hand Creda Simplicity W100 washing machine and want to know if it needs to be connected to both the hot and cold water supply or if just the cold can be connected
yes you can just connect the cold water side however you will need to cap off! the hotwater side due to a reverse flow issue when the tub is filling
Jan 17, 2010 | Creda W100FW Front Load Washer
Overheat and no heat
try either heater core or the fluid needs to be flushed and replaced with new
Jul 20, 2009 | 2001 Jeep Grand Cherokee
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
