Question about Samsung SyncMaster 193P 19" LCD Monitor
Syncmaster 193p not working
3 Suggested Answers
  • 123 Answers
SOURCE: Samsung SyncMaster 193P, screen completely dead.
In regards to your monitor issue, you can follow these steps
1. try to check if the monitor is on
2. check the cable connecting your monitor and tower ( CPU )
3. try to restart pc to check if you'll be getting any message on screen like "no signal"
4. try to check the brightness of your monitor from the screen adjustment buttons located either from the side or at the bottom of your monitor
If your monitor is still not working chances are that your monitor is broken and you need to have it replace. Hope this help you a bit. Thanks for using Fixya. Have a great day. :)
Posted on May 19, 2011
budmrtn
  • 11361 Answers
SOURCE: need power supply for syncmaster 193p
http://www.ac-power-adapter.com/Laptop/Samsung/ac-power-supply-adapter-for-samsung-syncmaster-193p-193p+-lcd.html
Posted on Sep 30, 2011
Samsung SyncMaster 193P, screen completely dead. Small blue power light comes on.
Same problem with my samsung 193p.only i got no picture in a background even when i was using flash lite. These procedure helped me.
Quote:
"I just finished fixing my Samsung 193p LCD with similar problem. The problem was a black/blank screen as if it was off. But if you are going to use a bright flash light there was data in it. So I suspect it was the inverter.
Procedures made.
1. Disconnect the power adapter and the D-sub cable.
2. Remove the small philip screws at the back of the LCD and remove the cover.
3. Remove 4 philip screws.
4. Disconnect the 2 data cables.
5. Openning the white cover is tricky. Use a flat screw driver and press it at the bottom middle part and use a credit card and pry from the middle part going to left or right side.
6. Remove the philip screws (black) around the LCD.
7. Remove the 4 philip screws and 4 at the middle part.
8. Be careful removing the switch cable. It is very fragile one of the 4 wires might come out (I did but fix it).
9. The Inverter board is at the left side. Take and remove the 4 inverter cables and the white wide cable.
10. This is another tricky part. Near the white cable there is a FUSE (brown in color). Check if it is open. If yes, You can use 2 think wires and solder on both ends. (Be careful the size of the fuse is soooo small like a half grain of rice). Or if you have a car fuse you can also use it.
11. Resolder the 6 terminals of the each transformer. There are 2 transformer so 12 terminals in all.
12. Assemble the parts back and you are done.
Good Luck. Happy fixing.
Roan
Triangle Tech Whiz"
Here is link to see broken fuse f201
http://photobucket.com/images/Inverter+fuse+F201?_escaped_fragment_=
May 19, 2011 | Samsung SyncMaster 193P 19" LCD Monitor
When I booted up my PC 4 days ago, my Symcmaster 193P monitor started immediately blinking continuously and very fast; it did so on the POST screen and went on after booting in Windows too. It stopped and...
Yes i do agree with you there is no problem with a graphic card,and i suspected it to be a problem with the cable which is used for connecting but it was fine when you swapped the monitors however i would still suspect on the slot where the cable is connected,may be you should try samsung service center before you decide.
Post back for more solutions we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 09, 2011 | Samsung SyncMaster 193P 19" LCD Monitor
193P Samsung monitor went to black as I was using it. No display, however blue light on power button is lit, indicating power is on.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 27, 2010 | Samsung SyncMaster 193P 19" LCD Monitor
Monitor wont come out of standby or sleep mode
Is there a signal going to the monitor? Do you have the monitor set to the correct input? Does your computer or other device work with other monitors? It is either likely you have the monitor set to the wrong input (if it has more than one), or you have a loose video cable (be it vga or dvi or hdmi). Less likely but also possible, your video card in your computer is dead. and then another also less likely possibility: the monitor is now a giant paperweight. Sorry if that is bad news to you.
Solutions:
1. Check that monitor has power (I know dumb question but I always have to ask) same with computer or device.
2. Make sure video cable is correctly inserted into correct jacks on computer and monitor (if in doubt of current cable try a different one)
3. Make sure if the monitor has multiple inputs try all of them, usually a monitor will have a MENU OR OK OR INPUT OR SOURCE button on the monitor you can use to set the inputs and/or other settings.
4. Try a different device on the monitor like another computer. If another device works then you should begin investigating the device and/or computer for issues.
May 20, 2010 | Samsung SyncMaster 193P 19" LCD Monitor
When monitor power button is pressed, a small white image appears and alternates briefly between an alalog and digital icon in black then the screen goes blank, no color.
My issue is similar.. however after trying a couple of times it will work. (yes everything is plugged in) It will function for a good 10 minutes before just powering off (blackout) screen.
If you attempt to turn it on after it blacking out, the blue led for the power button will blink a couple of times and it will remain off.
However if you wait 5-10 minutes and turn it back on, it will repeat itself...
I have it hooked up to a radeon X1650 graphics controller as a secondary digital controller, and its hooked up by VGA cable.
I also have two other displays besides this one (one primary and extended that dont have any issues whatsoever.. they continue to function while the syncmaster 193p takes its time snoozing.... please help.
Mar 17, 2009 | Samsung SyncMaster 193P 19" LCD Monitor
Samsung 193p 19" monitor died
Procedures made.
Roan
Triangle Tech Whiz
Dec 03, 2008 | Samsung SyncMaster 193P 19" LCD Monitor
Black Out
Hi Detrix, Check with www.lcdrepair.net if you want a repair. Something is wrong with your LCD controller and or GUI interface circuit or the circuit supplying power to it. If your technically endowed, you may want to open the monitor case and clean the dust and lint from around the circuits using a Small paint brush to sweep away any built up dust. These circuits take the Signal from the computer and controls the 2.5 million pixels on the LCD screen. Dsut can cause major problems with handling all that data. Give it a shot, what do you have to loose, its not dangerous if the monitor is unplugged.
Oct 09, 2007 | Samsung SyncMaster 193P 19" LCD Monitor
Samsung SyncMaster 193P 19" LCD Monitor Logo
24 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
