Akai tem64chsaau - Heating & Cooling
Need replacement remote control 5.1 Akai HHT-006
This company or eBay
AKAI TV Remote Controls ' AKAI Replacement Remotes for TV, DVD ...
https://www.replacementremotes.com/AKAI/Remote-Controls/
  1. Cached
ReplacementRemotes.com offers AKAI remote controls for sale online including remote controls for TV, DVD Player, TV/DVD Combo and many more. Missing: 5.1
Akai TV Remote Controls ' eBay
www.ebay.com > ... > Akai TV Remote Controls
  1. Cached
  2. Similar
AKAI KC02-A2 OEM Replacement TV Remote (LCT3701AD,LCT3201TD,LCT2701AD) ... Akai Samsung TV Remote Control Replacement BP59-00069A. $9.99. Missing: 5.1
replacement remote control 5 1 Akai HHT 006 Google Search
Apr 14, 2017 | Akai Televison & Video
I have a AKAI LCT3701AD 37 inch TV don't have the original remote control but bought a universal remote control but is not working Why?
YOU WILL STILL NEED TO PROGRAM THE NEW REMOTE FROM THE MANUAL THAT CAME WITH THE REMOTE. NORMALLY THIER ARE TWO WAYS TO PROGRAM A REMOTE EITHER MANUALLY OR TO DO IT AUTOMATICALLY. YES THE ORIGIONAL REMOTE IS ALREADY SET UP FOR YOUR MODEL OF TV BUT WITH THAT SAID TRY TO PROGRAM IT BY BOTH PARTS OF THE MANUAL. i AM USING A 55 INCH SMART TV AND HAVE DONE THIS AND ON OTHER SMART TV'S. ALSO YOU CAN GO TO THE WEBSITE OF THE REMOTE THAT YOU PURCHASE AND LOOK FOR VIDEOS ON HOW TO SET IT UP. IF YOU NEED MORE HELP LET SOMEONE HERE KNOW. GOOD LUCK.
Jan 23, 2017 | Akai Televison & Video
AKAI REEL TO REAL MODEL 1700 OPERATOR'S MANUAL
Here you are Andrew. That is a blast from the past!!
Service Manual and Owner's Manual!
Akai 1700 Manual Stereo Tape Recorder HiFi Engine
Jan 23, 2016 | Computers & Internet
Is this model AKAI TEM-64CHSAAU an inverter or non inverter plz? How do you tell?? Cheers
There is no listing for that model akai
read the comments on akai and you will find like I did that Akai do not make air conditioners as the company is bankrupt and the line is chinese made using the brand name
spares will be virtually non existent and the purchase may result in an "iffy" situation if it fails
Google akai air conditioners and get opinions before you buy this
May 28, 2015 | Akai 2.6kW Reverse Cycle Inverter Split...
Aai have the following AKAI Audio Stereo System and no Idea how to connect them. Please help Akai Model AP-D210 turntable Akai model CS-F14 Stereo cassette deck Akai model AT-K110 Fm Am Tuner Akai...
In general, outs to ins.
If nothing else, get the manuals for the preamp and the EQ. You'll probably have to pay for them.
Google it.
Akai PR-A04 preamplifier << This is the control center and where everything comes together.
Akai AP-D210 turntable (ONLY to jacks that say "PHONO"
Akai EA-G40 Stereo Graphic Equalizer (in the Tape 1 Out/In set)
Akai CS-F14 Stereo cassette deck (in the Tape Out/In set of the EQUALIZER) *
Akai AT-K110 Fm Am Tuner (to the Tuner inputs)
Akai DT-100 Audio Tuner (to the Aux inputs)
Akai PA-W04 Amplfier (to the amp outputs)
* This will allow you to Equalize the Tape on the Record or the Playback side.
Read some audio magazines or websites. Get to understand Tape Monitor Loops.
Don't use excessive EQ.
Mar 17, 2011 | Akai Audio Players & Recorders
I need akai part number ms244708 for a 4000d
If you look around you will likely find many many Akai 4000 series reel decks for sale..some for parts.. Akai 4000 series decks used basically the same mechanism and same parts... 4000d, DS, DS II, DB, Incidentally, the Akai 1700, 1710, 1722, 1731 used the same basic mechanisms as the 4000. .
Oct 24, 2009 | Audio Players & Recorders
Part Number for AKAI PDP4206EA
Here are some links for most of the boards for this Akai model # PDP4206EA from a major parts distributor:
Akai PDP4206EA Replacement Part ATSC Digital / HD Tuner Board
Akai PDP4206EA Replacement Part Main Board Assembly
Akai PDP4206EA Replacement Part NTSC Analog Tuner Board
Please note: The X-SUS and Y-SUS boards and power supply board are no longer available and the video board is part of the main board assembly. Hope this information helps.
Feb 04, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Damage lamps interior around the screen AKAI LCT3285TA LCD 32"
You can purchase parts for your television at:
circuitcity.partsearch.com/Model/Akai/Akai/LCT3285TA.aspx
or
www.looking4parts.com/search/?custid=4582&PIndex=47
or
tigerdirect.partsearch.com/Search/Model/Akai/Akai.aspx
or
www.shopjimmy.com/searchparts.cfm?make=Akai
or
www.partstore.com/
or
www.akai.com/
Jan 17, 2009 | Akai LCT3285TA 32 in. LCD Television
Remote Control Programming
GE Universal remote only $12.00 at Target works on my Akai LCD HDTV, this remote also has learning capability but the third code under Akai worked!!!
Jan 24, 2008 | Televison & Video
Heating & Cooling Logo
106 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
