E20 aeg washing machine
E20 code but machine constantly pumps and wont stop
    Genius:
  • Washing Mach... Master
  • 1,474 Answers
Sounds like water leak under machine, Polystyrene Float switch activated keeping pump on thus avoiding flood.
Posted on Nov 26, 2013
4 Suggested Answers
  • 17 Answers
SOURCE: zanussi electrolux washing machine zwf1431w
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
Posted on Dec 17, 2008
  • 44 Answers
SOURCE: AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
Posted on Mar 21, 2009
  • 53 Answers
SOURCE: Error E20
zanussi error E20 suggests a pump/draining problem. remove pump/filter and clean it all out. its located at the end of the drain hose at the bottom of machine. power off. it might need replacement.
Posted on Nov 01, 2009
Testimonial: "Thank you so much - exactly right"
Remove housing
How to replace a washing machine door seal on an AEG ...
? 5:38
https://www.youtube.com/watch?v=KlAXmnKJQ9k
Aug 17, 2009 - Uploaded by eSpares
This video will show you how to remove and replace the door seal. ... Do you have video repair instructions for AEG washing machine OkO ...
AEG removing drum Washing Machines Questions ... - Fixya
www.fixya.com/tags/removing_drum/washing_machines/aeg
AEG washing machines removing drum related questions and answers. ... into thehousing and get the object out. well as we say in my town you got a "toston" .
Aeg/electrolux lavamat 76810 waschmaschine E20 - YouTube? 0:28https://www.youtube.com/watch?v=1WX5rKxFrXsMay 3, 2015 - Uploaded by jusuf jerkovicAeg/electrolux lavamat 76810 waschmaschine E20 ... front load washer from not draining -- washing machine error code e20 - Duration: 2:52.washing machine error code e20 - YouTube? 2:52https://www.youtube.com/watch?v=2B7FxovrxKoOct 25, 2014 - Uploaded by teppichkopfSave some money and fix it yourself. Totally bizarre how stuff gets stuck in the drain!
Dec 21, 2015 | AEG Washing Machines
My machine comes up E20 towards end of program what does this mean
Really need the make and model of your machine as different manufacturers use the same code to mean diferent things. Hotpoint/Indesit/Creda generally use E20 to mean there is a problem with temperature sensing (Which generally indicated that the water heater element has failed. Zanissu/AEG Lavmat use E20 to indicate that the empty pump is blocked (Usually behind a kick plate at the bottom of the machine or a flip open door, you will find a cover that looks a little like a fuel cap). AEG also use E20 to indicate a door lock fault on some models. Personally, the fact that it is near the end of the cycle would indicate to me you have a blocked empty pump
Sep 26, 2015 | Washing Machines
How can I correct error code 25 on an AEG OK-LAVAMAT 74640 update washing machine mean?
Family error code "E20" means difficulties in draining, but I never heard for error code E25 on this model. Could be : E21, E23 and E24 error code.
Dado
Aug 24, 2014 | AEG Washing Machines
I have a aeg 72360 update washing machine and it keeps stopping and coming up E20. It will not spin
make sure the drain pump is operating correctly or if so, check the motor brushes.
Aug 09, 2010 | AEG Lavamat 72640 Front Load Washer
The code E20 is showing on my w/machine,whats the problem?
e20 on AEG Elecrolux and zanussi is machine not draining efficently. blockages in the machine or drain can cause it. if your model has a filter or coin trap clean that out. or dismantle the pump to look for something jamming the impellor. may need a need pump.
Aug 06, 2010 | Washing Machines
Aeg 72630 won't spin
most likeley cause are worn out carbon brushes in the main motor. have you seen any error codes e52 relates to the motor brush problem. e20 is inefficent draining caused by blockage in the pump chamber acces in the plinth area/ or in hoses or drain connection
Jul 21, 2010 | AEG Washing Machines
Dear ladies and gentlemen, our problem is, that we have a full mashine stopp with e20 accuring on the led before the detenser enters the toumble. our mashine is an aeg 16809 e20 thanks for your fast reply
You've answered your own question. E20 is a draining failure. Blockage in the sump hose, pump, drain hose or faulty pump. Clear the blockage or replace the pump if faulty and you'll clear the fault.
May 16, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Hi
regards
Mar 21, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
My aeg washer dryer comes up with e20 flashing i have checked the pipes, changed the pump cleaned the bottom filter, pump is now working but e20 fault still comes up half way through the wash cycle... how...
I had the same problem (E20) for a long time and tried everything in the manual before I called AEG to have someone stop by and fix it.
He took the whole top off as well as the back and pulled out all this fuzz that was stopped somewhere. He said it normally comes from using too much detergant and also from not letting the machine run empty every now and then....but it doesn't say to do this in the manual. And anyway, I can't imagine that using too much wash powder made 1/2 kg of fluff.
I still have a guarantee on the machine, but they say that because it is my fault that I got E20 I have to pay for the repairment myself.
I actually think that they build the machine purposly in this way to keep up the money flow. I have an attorney on the case now.
Dec 21, 2007 | AEG Lavamat 16810 Front Load Washer/Dryer
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
