Question about Canon imageRUNNER C3200 Copier
Canon IR-C3200 When trying to copy from platen glass the DADF-K1 tries to feed.
  • rrodoni May 08, 2009
    Problem Solved. Found a hole punch knockout covering DADF-K1 paper sensor. Thanks.
  • 34 Answers
HIT THE RESET BUTTON TWICE AND THEN TRY AGAIN.
Posted on May 08, 2009
The document feeders jams with the first page. I tried to recreate the problem others have experienced. I took fresh paper and loaded the document feeder. It happened to me with the first page too. Any...
first clean the paper pick-up, feed and separation roller in the middle of DADF. If they are to smooth and worn out you need to change them.
Also check for foreign materials inside.
Hope that helps!
PS it also can be the problems with dadf pickup clutch.
Apr 29, 2011 | Canon imageRUNNER C3200 Copier
E 000732-0001 IN CANON iRC 3200 .
Here are some possible solutions
getfile.asp?rid=1258 March 3, 2009 getfile.asp?rid=3215 Product : imageRUNNER C3200 / 2620 / 3220 Title : E732 and E733 are Displayed, when Copying off the Glass or when using the DADF
Error :
Error codes of E732 and E733 are displayed, when copying off the glass or when using the DADF. The Control Panel would go blank and the processing data light would continue to blink. After a few minutes in this state; the copier was rebooted and the codes would resolve themselves, but would eventually return.
Workaround :
First, try reseating all the connectors to the Reader Controller, Interface PCB, and DDI-S PCB. Next,
check for proper voltage to all three boards.
In this case, a defective DC Fuse PCB caused the error codes. An intermittent loss of voltage to the Reader Unit caused the machine to code out.
Note:
The part number for the DC Fuse PCB is FG3-3020-020.
Canon USA, Inc. Systems & Technical Support Division
Dec 30, 2010 | Canon imageRUNNER C3200 Copier
My canon ir 3200 have a code error E 732 I dont now what to do
Error :
Workaround :
Note:
Nov 12, 2010 | Canon imageRUNNER C3200 Copier
When making two sided copy, a messae is given like "Remove doc. on glass"
please be specific, did you put original in dadf ( auto feeder ) or on copy glass?
Aug 06, 2010 | Canon iR 2020i Laser Printer
The screen says the Paten glass needs to be cleaned. What is the paten glass? Also when copies are made a black line is showing up on the edge of the copy.
platen glass means that you need to clean the copy glass - glass where you put the originals for copying.
If you have an auto document cleaner there is also small glass on left side of "platen glass" wich is seen when you open the copy machine cover or dadf.
The black line is probably from dirt on copy glass, I pressume because courectour liquid ( most common ). use some stronger detergent or wd-40 to disolve the dirt and clean with glass detergent and dry it.
If you still have the black line try to print something from machine.If you do not have it on print its the copy glass problem - clean it - again.
Pls.rate
May 09, 2010 | Canon imageRUNNER 1023iF Black and White...
Keeps stating remove paper from platen glass before copying when trying to use the feeder. Nothing on the platen glass.
First you must lift the dadf all way up, because (from front looking) on left side under /by dadf hinge is white flap.This flap registers the lifting and pulling down of dadf.Probably is only that.
...but check if its broken or stuck,...
Or you have broken sensor or some part in sensors, or piece of paper, or similar in dadf
Feb 18, 2010 | Canon ImageRunner 2020i Copier
Black lines on my copies
Do you have dadf installed?
If Yes run a copie from it and second from platen glass.If you have lines on dadf copy but not on copie from glass, you should very good clean the left narrow glass (dadf glass).
But if you have lines on both copies you should check/ replace drum unit, but be sure thath fixing film unit is ok.
Jan 07, 2010 | Canon (6981A002AA) for imagerunner 2200,...
I have started getting streaks on Image Runner 2020
Try to print something, if there is any streaks?If no the problem is in copy glass (dadf or platen glass).
If there is streaks on print also,it could be the drum unit ( pull the drum unit out and see if on drum surface is any black streaks), fixing film is worn out, and in the worst case you have problem with toner unit ( on toner unit you have current leackage ) and you need (in best case) clean the contacts on toner unit, and in more expencive case tochange the toner unit.
Oct 01, 2009 | Canon imageRUNNER 2020 All-In-One Laser...
No gradition
try replacing the transfer belt cleaning blade.
Apr 14, 2009 | Canon imageRUNNER C3200 Copier
Canon imageRUNNER C3200 Copier Logo
140 people viewed this question
old marine
old marine
