Question about Canon DR-5010C Scanner
My windows server 2008 can't detect canon dr 5010 c
Twain canoscan
It looks like the manufacturer has what you need - http://www.usa.canon.com/
Nov 26, 2013 | Canon DR-2010C
I have a canon dr 5020 that just started scanning slowly
Check if there is enough disk space in the comp target area. Run defrag and scandisk.
S. Mohan, india
Mar 01, 2013 | Canon DR-5020 Path-Through Scanner
How to get canon mf toolbox to with windows server 2008?
Somebody who need windows key click: www.vanskeys.com to got. here i got a working key on my windows about activator. and after i used my windows works properly. hope it help you.
Jan 19, 2013 | Office Equipment & Supplies
Error code 5010 is showing on my printing and i don't know how to fix it.
I pressed the reset button - as recommended for the cartridge to be detected and ..miracle: the cartridge problem vanished as well as the error 5010 message!!!!!!!! I printed a document with no problem...
Hope this has helped you... Thanks...
Jul 20, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Cannot detect other printer in remote desktop connection
Hello my friend, regarding on your problem kindly check your system particularly your windows 2008 server OS. Kind reinstall the printer drivers then then shared it. Then after you share the printers kindly check the ip address of your windows server 2008 OS then go to the workstation Computer then click start button found in your task bar manager then click run. Then kindly type the "\\IP of your windows server 2008" where your printer drivers installed then enter. As soon as you can log in the Windows server 2008 menu environment then if you can find or see the printer icon then click the printers icon then right click then click connect. Let the system automatically installed the printer driver to your workstation computer. then as soon as your system finished installed the printer drivers then try to run and print if you can now print using network LAN.
Hope this solution able to solve your problem. If you need more assistance kindly rely to this post.
Thank you.
geo_jonas
Jul 17, 2009 | Office Equipment & Supplies
Canon mp-830 error code 5010
That code is a scanner error. The scanner unit can not detect the home position or the scanner unit warming up is not done properly at power on. Most of the time the Scanner unit needs to be replaced.
Nov 10, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon DR-5010C Scanner Logo
15 people viewed this question
old marine
old marine
