Question about Dell Computers & Internet
Dell laptop blue line screen
Heloo there i have dell latitude e5420 3 yrs old laptop while watching video it keeps crashing and i get blue screen with physical memory dump what should i do
  • 16 Answers
Seems you may have issue with the video player software program install an other video player like VLC. If the problem persists you may have issue with your hardware. Try one or all of these see if it helps:
1)Try using the laptop without the battery for a while if you do have battery on. Also try these:
2) Go to Bios you should be able to find memory diagnostics if not you would need to create a Hiren bootable CD there is diagnostic tools there.
3) You could try checking the harddrive for bad sector - right click on the drive letter (e.g. drive C) in my computer then go to Properties --> Tools --> Check choose both options will ask you to restart let the scan run while restarting.
4) If you have 2 Rams on the laptop takeout one and use only one do with both see if the problem is with one of them.
Posted on Nov 26, 2013
Benimur
  • 6966 Answers
SOURCE: BEGINNING DUMP OF PHYSICAL MEMORY
Hi, Normally a blue screen of death (BSOD) with memory dump is indicative of a fault in the: Hardware- 1. Possibly memory; 2. video; or 3. motherboard. In some instances, Software- a. Drivers; or b. the Operating System itself. You may want to check the memory installed in your laptop. Some versions have them underneath the keyboard while most would have it at the bottom covered by a lid/plate secured with 1 or 2 small screws. The memory will spring out if you unlock the two side clips. You need to clean the little gold contacts with a pencil eraser. Re-insert back securely and try again. If the above does not correct the BSOD, you may need to replace them. Hope this be of some help/idea. Post back how things turn out or should you need additional information. Good luck and kind regards.
Posted on Oct 05, 2007
  • 16 Answers
SOURCE: 2 problems in one
Depending on what operating system you are using, I suggest repairing the operating system. For windows xp here is a guide that you can follow http://www.michaelstevenstech.com/XPrepairinstall.htm.
For windows vista
http://www.bleepingcomputer.com/tutorials/tutorial148.html
Posted on Apr 16, 2008
Riztech
  • 731 Answers
SOURCE: Blue screen physical dump error
Hi
They virtual memory should have been exceeded the limit.
Step 1:
Power Drain:
1.Disconnect all the cabled from laptop, including Memory card and wireless card(wi-fi)
2.Take out the batteries
3.Press and hold the ON button for 30 seconds
4.Put the batteries in and boot the laptop.
if its does not works
Step 2:
Upgrade the RAM memory of the Laptop
Thanks
Riz
Posted on Jan 13, 2009
acdr
  • 1913 Answers
SOURCE: blue screen on my inspiron 6000
your hard disk has some eror it must need fixing.u can format your harddisk with win xp recobery disk.
Posted on Mar 16, 2009
mopar2009
  • 32 Answers
SOURCE: inspiron 600 m Dell blue screen
Try this: Reboot and select Recovery Mode, then from the c:\windows prompt type: chkdsk
Let it run through checkdisk then try it should boot up.
Posted on Sep 15, 2009
Dell latitude 120l reboots in f8 screen then flashes blue screen or no boot able devices over n over
The operating system is crashing while starting, try to repair windows or format it again
Sep 07, 2013 | Dell Inspiron 3500 Notebook
Solid blue screen
Too many possibilities for a blue screen.
If the computer attempts to boot and only goes to a blue screen, i'd check re-seating your memory module. If your blue screen is from a computer crash, it could be fixed the same way but more likely else. A) Make sure your computer is not overheating.
B) Make sure that the the computer has been de-fragged, this is a normal maintenance that should be done monthly at least.
C) Next option is the program your using installed correct.
D) Has the computer been crashing to a blue screen may need to be re-installed...
Good Luck
Feb 11, 2013 | Dell Latitude D630 Notebook
Dell latitude e6400 freeze
might your memory is low or need replacement.
Jul 19, 2012 | Dell Latitude E6400 Notebook
I have a dell laptop an the pixels r goinjg out i dnt want to buy a new computer. if u press the screen it works otherwise it freezes the screen then the screen is covered in different colored lines. im...
Hi matt d224...
.I included a couple of links to some parts for the D420
There is one test to determine if it is the screen causing the problem or maybe the lcd converter.
Plug an external monitor into your laptop and see if the picture is good...if it is then replace the lcd screen.
If there is still no picture then the problem is probably the lcd inverter needs replacement
Please take time to rate me
Dell Latitude D420 replacment lcd screen:
http://www.laptopscreen.com/English/model/Dell/LATITUDE~D420/
Lcd Inverter replacment:
http://www.yallstore.com/laptop-lcd-inverter-replacement-for-dell-latitude-d420-141-p-1275.html
Youtube video "How to replace a Dell Computer screen";
http://www.youtube.com/watch?v=P7LVbOT5DnQ
How to replace a lcd inverter...this one is for a 630, but your will be the same:
http://www.youtube.com/watch?v=_ILAkFWp3gQ
Sep 11, 2011 | Dell Latitude D420 (DELLD420) PC Notebook
Blue screen when boots up how do i restore computer to factory settings
Hello:
Start your Latitude and maybe a blue bar will appear at the top of the screen like: www.dell.com. Inmediately you see this, try to press F11 to begin the restore utility. Or simply keep pressing this key just after you switch on the laptop.
I hope this helps. Thanks
Feb 14, 2011 | Dell Latitude C400 Notebook
I am getting the blue screen of death..booted into safe mode, command line entry. its still working..has not crashed Reload XP??
Just remove the unwanted software which you installed last. and refix your ram ..thats it.. it will work
Jan 12, 2010 | Dell Latitude D600 Notebook
Blue screen on dell latitude laptop. At the
try booting of cd..if that dont work you probably need to replace the hard drive
Nov 16, 2009 | Dell Latitude C610 Notebook
My Dell Latitude D600 is crashed when it tries to start up it will have a blue screen that says SYSYEMROOTSYSTEM32CONFIGDEFAULT. WHAT DO I DO?
You will need to run the OS installation disc and try to repair the installation. If it does not have an installation disc then the harddrive may have a built-in recovery system to bring your laptop back to working order. When you first boot up the computer watch the screen for instructions on what button to push for system setup or recovery. It might be F10 or F12. I would try to boot into safemode before the recovery so you can back-up any files you have that you do not want to lose.
Sep 21, 2009 | Dell Latitude D600 Notebook
Computers & Internet Logo
50 people viewed this question
Alun Cox
