Question about Canon PIXMA MX300 All-in-One Printer
Scanning error code 2,119,0
I've just set up my canon pixma MX300 4-in-1 and when i try to scan it keeps giving me the error message above saying that the scanner is in use by another user. i'm at home and the only one connected to it. Please help!!!
  • 52 Answers
SOURCE: OS X 10.5 Leopard & Canon PIXMA MP510
hi i am a certified Canon4.gif repair tech for this printer. if you follow the link below this will take you to Canons support site where you can download the software for your printer. hope this helps
http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Posted on Jan 09, 2008
SOURCE: pixma mp600r scanning setup
Try turning off the windows firewall.
If that works, then add the Canon scanner app to the list of applications that are allowed through the firewall, then turn the firewall back on again.
Posted on Feb 02, 2008
  • 30 Answers
SOURCE: Scanning with Canon Pixma MP450
Are the bits actually being scanned about 4inches by 6inches. If so it sounds like your scanner might be set to 4x6 mode. If you look on your control panel of your printer there should be an option for the paper size and it is probably set to 4x6. If you change that back to A4 or normal then it will be fine.
Posted on Feb 07, 2008
SOURCE: canon pixma mp830 will not scan
I am experiencing the same problem, from the equipment id does not scan
Posted on Jun 09, 2008
solofixya
  • 34 Answers
SOURCE: Canon PIXMA MP145 Scanner Problem
Take it to a Canon Repair company, It has a 1 year warranty and needs to be replaced or call 1-800-ok canon.
Posted on Nov 10, 2008
Support code 2700
From Canon:
2700 Description
This error occurred due to one of the following reasons -
  • An error occurred while copying.
  • The document is still in the ADF.
  • An error occurred while scanning and the document is still in the ADF.
Resolution
  1. When copying, press the [OK] button to dismiss the error, and try to copy again.
  2. If the document is still in the ADF, press the [OK] button to feed out the document.
  3. When scanning, press the [Stop] button to cancel, and then try scanning again.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility.
Feb 15, 2015 | Canon PIXMA MX340 Wireless Office...
Code:7,202,15- My Canon MX-870 (Twain) gives me this error code when I try to resizew in B/W or grey scale. No problem in color.
"Internal error occurred. Scanner driver will be closed. code 7,202,15"
Received the above error while inserting scanner image using MS Word with Canon printer/scanner Pixma 439.
The solution is via the following MS Word software choices:
From Word tool bar choose: INSERT/PICTURE/FROM SCANNER/then one of two choices, either: WIA-WIA Canon MX430 Series, or choose CUSTOM INSERT (Preferable).
R
Aug 21, 2012 | Canon PIXMA MX870 Wireless Office...
Scanner gives me code 5,145,61 how can fix it ?
RE: Scanner gives me code 5,145,61 how can fix it ?
I was using wireless router and receive exactly the same error code as above.
SOLUTION: Turn-off printer/scanner; reset or turn-off the wireless router power and then turn-on again. Turn-on the scanner. Start scanning.
Mar 11, 2012 | Canon PIXMA MP495 InkJet Printer
Wen i try to scan my photoes an error message pops up...... SnanGear error code 2,140,2. It says printer is in use or an error has occured. Check status. Scanner driver will be closed
Stop your printer running while you are scanning photos.
It defines error because your printer and scanner running simultaneously.
Eject your printer while scanning.
Jan 07, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Error code U052; keeps saying incorrect printhead installed - the printhead has never been changed
Per Canon's website, and this just worked for my mp620:
Turn the printer on.
Open the cover.
Remove the ink cartridges.
Remove the printhead.
Re-install the above (this resets the printhead).
Close the cover.
Printer should initialize and go to home menu screen.
Nov 24, 2010 | Canon PIXMA MP620 All-In-One InkJet...
I cant scan from my printer.. keeps giving me a error
Reinstall your software on your computer. Make sure you connect your computer to your printer at the time when it asks you to - and after it says, "Ok," try again to scan.
Using Photoshop or another program to scan from is helpful. If you use this for scanning, make sure you download the TWAIN support for scanning from Photoshop.
Nov 16, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Error code 2,155,0 . Printer using same cable works without error on my desktop PC (windows XP) but gives the above error code on my laptop (Vista home) when scanning using MP Navigator 2.2. Printer goes...
It seems that the printer has communication problem with the computer. If you are sure your USB cable is good than it might be the board of the printer is faulty
Jan 03, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Trying to scan, but keep getting error code 2,162,0 My scanner printer - my Canon 4370 won't scan. Printing and copying is working fine.
I finally got a solution to my problem, which is the same as this one. When trying to scan via USB, you have to make sure the unit is set to USB. On the top panel just above the LCD display, is 3 buttons, Copy, Fax, Scan. Hit the SCAN button, till the display says USB SCANNING. Then try to scan again. Good luck!!
Apr 23, 2009 | Canon ImageCLASS MF4370dn Laser All-in-One...
Error message code 2,140,0
I had a similar problem (error Code:2,140,2) in Canon PIXMA MP250 all-in-one, and it was solved when I replaced both ink cartridges which were in low ink (almost without ink). I know an scanner problem is not supposed to be in relation with ink or printer problems, but that's the way I've fixed it. Good luck!
Mar 16, 2009 | Canon PIXMA MP240 All-In-One InkJet...
Canon MP830 error code 1,0,0
Hhmmm, I would try deleting the reinstalling the driver. Check the manual and see if you can reset the unit to factory defaults. Is it just scanning to a file that causes the error or does copy or send fax also cause the error?
Nov 03, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MX300 All-in-One Printer Logo
496 people viewed this question
old marine
old marine
