Question about Kyocera Fs-1300d Printer
Reset kyocera fuser - Kyocera Fs-1300d Printer
Kyocera c6000 call service
fuser error ,1087 1087 , then 163 reset ,may be prompted to turn off and on again. if it does not reset you need a new fuser assy
Mar 05, 2015 | Kyocera Office Equipment & Supplies
How can i reset the code error sc543 for kyocera fsc1020mfp
To enter the maintenance mode menu use the following procedure:
1. Turn the main switch ON.
Take the following steps in sequential order.
2. Press "Clear/Stop"
3. Press "1".
4. Press "0".
5. Press "7".
6. Press "Color Start".
The LCD display will show "Maintenance Mode".
With the up or down key find the Engine Maintenance and press OK. Then with the keys search for Fuser SC Reset and press OK. The fuser error will be resetted.
Also in the same menu (Engine Maintenance) you' ll find and this one option Replace Fuser (Resets the maintenance counter for the fusing unit.This item appears only when the fusing unit life is almost expired or has expired.)
Oct 02, 2014 | Kyocera Office Equipment & Supplies
How to reset c6000 error on Kyocera M2535dn?
try replacing the fuser it says broken fuser heat wire
Jul 23, 2014 | Kyocera Office Equipment & Supplies
Kyocera xerox machine c-6 400 error
fuser related
=clear jam if any.
=reset error
clear - 1-0-8-7-1-0-8-7 -- 163---ok
=replace fuser if damaged
Jul 09, 2014 | Kyocera TASKalfa 180 Copier
What is C6030 on Kyocera Km-C2520
6030 Broken fuser thermistor M wire
*35/37 and 45/47 ppm printers (EUR/
USA model) only
Input from fuser thermistor M is less than
1 (A/D value) for more than 3 s.
Poor contact in the
fuser thermistor M
connector terminals.
Reinsert the connector (See page P.1-5-19).
Broken fuser
thermistor M wire./from the manual try replacing thermistors then reset the code or just replace fuser then reset the code
from the manual sadjnbdsvknsdlkvnsdv
Apr 12, 2014 | Kyocera FS-2000D Laser Printer
Kyocera km 2035 has error c-6
The error codes for Kyocera Mita are usually in this format: X-XXXX.
I am assuming the error is C-6XXX so i'm going out on a limb to say it is a fuser error. Check the power source for your copier. Make sure you have a good earth ground. Reset the fuser error. If it does not reset then replace the fuser.
Dec 03, 2013 | Kyocera Office Equipment & Supplies
KYOCERA ECOSYS FS-1118 ERROR-C-6400
Error code relates to the fuser unit.Suggest that it is replaced.
Nov 16, 2011 | Kyocera FS-1118MFP Laser Printer
C6000 on Kyocera KM-3050
you can try to reset the error code by going into
simulation mode
at the machine punch in 10871087
once in simulation mode.. go to sim 163
that's a fuser reset
execute that..
if problem persists you need to replace fuser
Mar 10, 2010 | Kyocera Mita KM-1815 All-In-One Laser...
Showing 'error occured call service person c6400'
Defective power supply board. or Defective engine board
May 31, 2009 | Kyocera FS-1118MFP Laser Printer
Kyocera Fs-1300d  Printer Logo
26 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
