Question about Whirlpool ED2FHKXRL 23 cu.ft.Satina Side by Side Refrigerator 220-240 V
Whirlpool ED2FHKXRL frost
Can someone please assist me. I am at my wits end! This fridge is disastrous. Nothing but issues. I called the repair man out just before the Warranty ran out and the same issue still exists however now out of warranty. Freezer section works fine. Fridge section does not keep entirely cold. Top section warmer. Cannot feel much cold air coming through the top vent from freezer however when you open the freezer door, you can then feel the cold air coming through. When you press on the button in the freezer as though the door is closed the air is still blowing cold. It is only when the door is physically closed the airs stops blowing. The vent half way down the fridge constantly clogs with ice. I have blow dried the vents to ensure all ice melts (which I was advised to do my the repair man). I have turned the fridge off to ensure the hoses aren't clogged with ice. I have cleaned the coils under the front of the machine. Anyone have any other suggestions? Would be most appreciated :)
    Genius:
  • Whirlpool Master
  • 1,474 Answers
Could be short of gas or a partial blockage, Best try shutting down for at least 24 hrs ,this will I hope help to clear any blockage when motor restarts Good luck
Posted on Nov 26, 2013
  • 794 Answers
As I was looking up the specs and going through the troubleshooting process regarding your problem, I quickly recognized that your refrigerator is designed to work on 220-240 Volts Alternating Current [VAC] load using a 50 Hertz frequency [cycle] grid; which begs me to ask the question, 1.) Do you live outside the United States?
Because if you live in the U.S or Canada for example, our electrical systems run on 60 Hertz frequency grids- and our refrigerators and freezer appliances are 120VAC.
And I know many European countries use green "smart" plugs which is okay to use on resistive loads like small heaters and incandescent lamp fixtures, but not on motorized appliances like refrigerators or electronics- since refrigerators have several motors in them, and the more modern ones have electronic components as well; this can be a problem; because green plugs and power converters have been known to cause all kinds of problems in fridges, such as moisture buildup due to slower fan speeds, and compressor starting and heating problems.
2.) Are you using any green plugs
3.) or any power converters?
Hoping to hear from you soon.
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: FREEZER COLD REFER WARM
Check out these tips...they can help you figure out whats going wrong...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Aug 12, 2010
Ice machine wont dump ice on sears kenmore side by
Ice forms are 32 degrees but ice maker don't dump till 25 degrees. Get that guy back out there. Obviously you have a bad defrost heater.
Jul 17, 2009 | Refrigerators
Freezer is not freezing its cold like the fridge but thats it. tha fridge is running
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | Refrigerators
I have the top mount refrigerator - 4years old. Ice maker was installed then removed because it broke about 2 years ago. Suddenly I am getting a huge amount of water in the crisper drawer but no other...
Apr 01, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerator is freezing everything top to bottom wondering if there is an air filter that I could clean as we have had some drywall done recently and thought maybe something is restricting air flow.
Apr 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water dispenser keeps running
Apr 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
We have a bosch air flow fridge freezer
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Mar 14, 2009 | Bosch Refrigerators
Freezer side works fridge side doesnt
    click on the required option.
Feb 20, 2009 | Kenmore Refrigerators
Frost in freezer
YOU NEED TO CHECK IF THE DAMPER CONTROL IS NOT CLOSED SHUT THAT CAN BE THE REASON FOR THE FRIDGE NOT COOLING.YOU MIGHT NEED THE ASSISTANCE OF A REPAIR MAN TO ASSIST YOU.
GOOD LUCK.
MOHAMED
Sep 06, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Samsung frost free fridge freezer - RL39WBSW
Dear friend,
ngfam at you service! happy to assist!
Sounds like two separate problems!!!
Do not delay!
Call service before you have bigger problems and a bigger expense!
Below I gave you a nation wide service thats very good!
We sell appliances for 65 years and I recommend this nation wide Factory repair service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 14, 2008 | Samsung RS2630SH Side by Side Refrigerator
Whirlpool ED2FHKXRL 23 cu.ft.Satina Side by Side Refrigerator 220-240 V Logo
99 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
