Question about Garden
Manual ryobi chainsaw
How to replace chain
  • 528 Answers
Chain replacement is basically the same on all chainsaws. Loosen the side retaining nuts on the cover over the chain. Now loosen the chain tension screw ( usually a flat headed screw) at least 4 full turns. Put the saw on its side with the blade up. Remove those side cover nuts and the side cover - the blade should sag as you remove the nuts. push the blade towards the engine, paying attention to the direction of the teeth on the chain. remove the chain and clean out the junk from behind the chain around the sprocket and from the inside of the side cover. The emergency brake band is located inside the cover - make sure you clean out the debris from around the band, tensioner screw assembly, and cover. Re-install the new chain, orienting the teeth in the correct direction. Re-install the side cover, making sure the tensioner pin goes into the hole in the bar ( blade). Slightly tighten the side nuts, then re-tension the chain until you can just pull the teeth off the bar. tighten the nuts, being sure you don't over tighten them ( a little past snug is good). Run the saw for a few minutes ( doing 1 cut will speed this step along). Loosen the side cover nuts and re-tension the chain, the re-tighten the nuts.
Hope this helps!!
Posted on Dec 02, 2013
4 Suggested Answers
Mike258
  • 1498 Answers
SOURCE: Ryobi 14 inch electric chainsaw won't cut with new chain
Hi Rossmac,
Both the smoke and it's lack of cutting ability are symptoms of the same problem. The Chain is dulled. Instead of cutting, it's just rubbing on the wood and heating up. It's also not a big deal to fix..
Your options are:
  • Replace the Chain
  • Have the Chain sharpened
  • Sharpen it yourself
To sharpen it yourself, you will need a narrow round file that will fit inside the Chain teeth. Each tooth has a two cutting edges, get the file a position that matches the tooths angle of attack. Don't over do, three to five swipes of the file should do it on each surface.
You will see they alternate directions. You may find it easier to do all the teeth in one direction (skipping every other tooth) then do the other direction. Up to you.
When you are done, check the level of your chain oil. Since it did get hot, you might manually oil the chain before trying out your handi-work.
Go cut some wood.
Mike
Posted on Dec 21, 2008
  • 15 Answers
SOURCE: ryobi pcn3335 chainsaw manual
Call Ryobi Technologies 800-825-2579
Posted on Jan 28, 2009
  • 583 Answers
SOURCE: my ryobi chainsaw rcs 2040 keeps stopping but
RYOBI----- with the motor running at high revs the chain stops indicates that the sprocket behind the centrifugal clutch is worn out or the centrifugal clutch itself ,or the clutch shoes are worn out the way to tell is to remove the bar and chain and have alook where the chain was conected to the saw, i think you will see the sprocket is buggered and as that is attatched to the clutch drum that will have to be replaced along with clutch springs and shoes, i think you have been running the chain a bit too loose or not running it at realy high revs ,which is what they are designed to do ,cme back to me if you feel the need
Posted on Sep 21, 2009
I am looking for a Ryobi chainsaw 356mm manual. Model CS214
Contact Ryobi via their website and they will send you the PDF - http://ryobi.com.au/
Oct 06, 2011 | Ryobi 18-inch Electric Chainsaw Chain Saws
No local Ryobi dealer; what other brand chains will fit my 18" Ryobi ?
Any saw service dealer can fit a chain to your saw. 'Oregon' saw makes bars/chains for about any saw made in the last 50 years or so. Just take the chain itself in to get a replacement. Good luck!
Nov 18, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Where are the oiling ponts to the bar to the ryobi 16 inch petrol chainsaw?
Hi
It's Lisa?
On an electric chainsaw there usually aren't what you would call oiling points.Somewhere,probably on the rear or one side of the case will be a bulb.It's also the screw on cap for the oil reservoir.
You fill that up with chainsaw bar oil,and as you use the saw every few minutes push the bulb down 2-3 times and it applies oil to the chain and gear in the case.The chain transfers the oil to the bar.
If this helps,would you rate my post please?
Thanks Bob
By the way,if you give me your model number I can look for a manual somewhere.No promises though,Ryobi likes to sell their manuals rather than download them.
Aug 16, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
I have a ryobi chain saw PCN 4545 - won't fire. Is there soemthing simple I'm not doing. Has worked efficiently for 2 years. Don't think it's flooded. Does it have a spark plug ? Would appreciate soem...
A COMMON PROBLEM FOR A CHAINSAW OVER 2 YEARS OF AGE IT IS USUALLY THAT A WIRE HAS BUSTED THAT NEEDS REPLACING CHECK FOR ASSISTANCE IN THE MANUAL IF YOU STILL HAVE IT THERE SHOULD BE AND AFTER CARE PHONE NUMBER FOR FURTHER ASSSISTANCE
Oct 03, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Fix the tension tightener for ryobi chainsaw
the nut like end of the tention bolt should fit into a hole in the bar. Then as you unscrew the bolt later one it ill push the bar farther away from the bolt heal thus tightening the chain
May 03, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Garden Logo
100 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
