Question about Stanley Bostitch N88rh Framing Nailer Driver Piston 158582
I have just bought a used Bostitch N70 coil nailer,it was used for making pallets it goes fine except I don't know how to adjust the nail depth. I am going to use it to replace my deck timbers (treated pine) and also to build a new timber fence,I want to use 50mm nails (dome head gal plated) that came with the gun,but the nails go 1/2 way through the boards is this a trial and error pressure issue?
    Habit-Forming:
  • 174 Answers
Put a air regulator on the compressor and drop your pressure down till you get the depth you want .
Posted on May 30, 2009
There should be a adjuster what slides back or forward on nose of gun
Posted on Dec 17, 2009
Bostich RN-46 seems to be over sinking the nails even went set to low depth
Adjust the air pressure on the regulator to about 90 lbs. or lower. maybe higher than 90 but that should help you set the depth.
Jun 05, 2014 | Stanley Factory Reconditioned Bostitch...
I Have a N80 Coil Nailer. It was given to me without the manual. I down loaded a manual, however it is not clear how to set the nail depth. Can you advise?
Bostitch nailers used three methods to adjust how deep the nail will set. On stick nailer, there are one or two screws on the lower contact arm allows you to shift up or down. On coil nailers and others , there is thumb screw on side or under the trigger. Finally on some coil nailers, there was a series of spacers that snapped onto nose of the gun. Good luck
Nov 21, 2012 | Stanley Bostitch N80s Nailer -rebuild...
How do i control the depth the nail shoots in a bostitch coil nailer
The bostitch nailer pictured along along with your question is a RN46 roofing coil nailer. It has a dial on the front of the nose for adjusting depth. Some older nailers (roofing nailers) do no have a means of adjusting so were set at the factory for best performance. The question of depth usually comes up when lower bumper fails and the nail is driven too deep. Easy test. Remove nails and find a very soft piece of wood. Dry fire the gun against soft wood and measure how deep the driver is entering the wood. Harder test. Remove the head and use any handy tool to push driver down to bottom. Measure how far the driver extends past nose (should be about 1/8 to 3/16). If more, replace the lower bumper. Good luck
Jun 21, 2012 | Stanley Bostitch Nail Gun
How do you adjust nail depth on Bostitch N80 framing nail gun?
i think this model has no adjustment. if it does it is on safety tip. if not you can only adjust air pressure.
Aug 05, 2011 | Stanley Bostitch N80CB Coil Framing Nailer
I inherited a Bosch T31 bradder and stapler. Couldn't get any help at Home Depot chosinga nails. Bought Porter Cable 16 Ga. 1" finish nails (PFN16100-1). Released arm and slid the nail carrier...
BOSTITCH T31-1 stapler & T31-2 STAPLER and NAILER. Both use 18 gauge (very fine gauge wire). Try using 18 gauge Bostitch staples (used in BT model bostitch staplers). Good Luck
Feb 03, 2011 | Stanley Bostitch N80CB Coil Framing Nailer
I have been installing a treated pine deck, but the nails are been driven in to far, i have tried adjusting the pressure from the compressor but have had no luck is there a depth adjustment on the gun?
Yes, there is a depth adjustment. Most of the Bostitch models have a push button on the left side near where the nails come out. With the air unplugged, push in this button and you can slide the head assembly up or down to make your adjustment. Slide it out for less depth. It sounds like maybe yours is fully seated, providing the maximum depth.
Dec 13, 2010 | Stanley Bostitch Coil Framing Nailer
I just bought a used Bostitch Coil Nailer. 3 1/4" nails work fine but the 2" nails will not keep feeding.
Check the spacing of the nail collation between the two nail sizes and also the spacing of the copper wires. Some nailers have a different setting for the check paws on the latch door to compensate for the thinner nails (too much clearance between the latch door and body of gun). Check manual at www.bostich.com for proper setting of check paws between nail types. Good luck
Oct 12, 2010 | Stanley Bostitch Coil Framing Nailer
Nail not going all the way in
sticking piston could cause this try some air tool lube and make sure that if there is a depth adjustment make sure its all the way down some bostitch havem
Jul 29, 2010 | Stanley Bostitch Coil Framing Nailer
Nail gun not putting nail in all the way
yes ,should be on head of gun,if not try turning air preasure up.
Aug 21, 2009 | Stanley Factory Reconditioned Bostitch...
Stanley Bostitch N88rh Framing Nailer Driver Piston 158582 Logo
1,495 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
