Towerstat rsp manual - Heating & Cooling
Hi ya;all how do I pair my towerstat ref to my boiler?
Frankly... "PAIRING" does NOT sound like the issue.
If you don't have your original thermostat (to go back to)... I'd suggest you push yours back over the counter... FROM WHENCE it CAME.
Perhaps to TRY ANOTHER... or buy a simple thermostat...
No bells, whistles... networks or friend cyber-neighbor (802.11 access).
Re-install it and establish that you have a well functioning & reliable system heating.
Towerstat specs indicate 434 Mhz... (below)
Being a RADIO-MAN my first inclination would be to look for
RADIO-INTERFERENCE...
BUT realistically...
why bother when there is a ton of SMART-Phone APPs that will RELIABLY provide GLOBAL remote...
(ALEXA / ECHO: talking interface)
rather than ROOM REMOTE... ??
SENSI, NEST & HONEYWELL ... just to skim the surface...??
(Sorry.. Can't help asking).
Towerstat Radio Frequency Programmable Room Thermostat - Features
  • Transmitter dimensions: 116 x 100 x 23.5mm, weight 126g;
  • Receiver dimensions: 91.5 x 91.5 x 42mm, weight 176g;
  • Power supply: Transmitter 2 x AA(LR6) batteries;
  • Receiver: 230VAC 50Hz;
  • Accuracy: + / - 60 seconds / month;
  • Temp. measurement: 0degC to 40degC in 0.5degC resolution;
  • Temp. accuracy: + / - 10 at 20degC;
  • Temperature Control: 7degC to 30degC in 0.5degC increments;
  • Span: 1, 2, 3, or 40C;
  • Air conditioner cycle time: 3 minutes;
  • Operation temperature: 0degC to 40degC;
  • Storage temperature: -10degC to 60degC;
  • Operating frequency: 434 MHz.
Amazon com wifi controlled thermostat
Sep 15, 2016 | Heating & Cooling
How do i programme my towerstat rf to come on monday to friday at 6am and go off at 8am. Thanks Julie (could someone possibly post a video on youtube)
It depends on what model you have. Not all models are able to program that. Call the manufacturer, they will be happy to help.
Oct 08, 2014 | Heating & Cooling
Lost manual for towerstat RF
try googling "towerstat rf"
Sep 21, 2014 | Water Heaters
What does the code no r sp mean?
no rsp = no response
So why do you get this?
On models not equipped with a tachometer "No Rsp" will appear when the tachometer identifier (T part of the "PssPt" sequence ) is selected, because you don't have a tach for it to respond.
If you're getting this code in any of the other identifiers, your "kill switch" is probably in the OFF position instead of the RUN position, where it needs to be.
Jun 05, 2014 | 2009 Harley Davidson FLHX Street Glide
Increase a signal with antenna
What makes you think you need an antenna with 20 dB of gain to get 300m with 2.4GHz?
If that's an RP-SMA connector on the card, try an (8 dBi) RE09P-RSP from l-com.com (about $40).
2 4 GHz 8 dBi Flat Patch Antenna 4ft RP SMA Plug Connector RE09P RSP
Apr 13, 2014 | Gigabyte GN-WPKG 802.11g/b Wireless...
Have right parts but connection is wrong on stator for rsp on kenmore oasis mod, 110.27087603 rsp #10183157 and stator #10419333
W10183157 is the proper one for this machine. If you removed the stator did you maybe get the plug behind the staor when you installed it and can not see it now? Just asking
Feb 06, 2014 | Kenmore Washing Machines
How to use a towerstat RF
www.tfc-group.co.uk/assets/graphics/static/tower_manual_on-off.pdf
Nov 15, 2013 | Computers & Internet
Heating & Cooling Logo
12 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
